20 Most Recent Rotel RX-950AX Receiver Questions & Answers
IC901 12volt regulator is defective, may test good but change it.
Rotel RX-950AX... | Answered on Feb 20, 2020
Stab in the dark here, but I don't see any screws in the main board in the left rear viewed from the front. I have a dead one here. Standby light only. I'm guessing relay unless I am looking in the wrong place for the missing *****. Please advise.
Rotel RX-950AX... | Answered on Sep 26, 2017
If the Unit Powers On then most probably the Fuses could have gone bad You will be able to replace the Main Fuse yourself but REPLACE WITH THE SAME KIND OF FUSE in terms of RATING
Rotel RX-950AX... | Answered on Jun 25, 2015
there would be life in the old girl it just depends how much you love her and how much you are willing to spend to get her fixed ?? some old rotels are still fetching good money so it might be worthwhile getting a quote
Rotel RX-950AX... | Answered on Aug 10, 2012
You cannot fix the receiver unless you are a technician with the proper tools and circuit diagrams. I would think it worth the cost of repair though.
Good Luck
BB
Rotel RX-950AX... | Answered on Mar 22, 2011
The URC database should have codes for that unit. The software for programming the MX-900 has it. Which remote are you trying to program?
Rotel RX-950AX... | Answered on May 12, 2009
Hello Ruben, so you do not open the CD holder tray of your Rotel, the problem is that the belt that transmits the rotation of the engine to the mechanism of the car, may be stretched and therefore the car does not open, this is the most common fault in this type of CD players
You should replace it, if you can not do it, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Ruben, por lo que cuentas, no se abre la bandeja porta CD de tu Rotel, el problema es que la correa que trasmite el giro del motor al mecanismo del carro, puede estar estirada y por lo tanto el carro no se abre, esta es la falla mas habitual en este tipo de reproductores de CD
Deber?s reemplazarla, si no puedes hacerlo, busca un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
https://elektrotanya.com/rotel_rcd-951-tm.pdf/download.html
http://bwgroupsupport.com/downloads/manuals/rotel/RCD-951-OM.pdf
Rotel Audio... | Answered on Jun 04, 2019
hi
it sound to me that when you biamp and driving speaker and woofer , you are over loading the fuses , suggestions
uprate the fuses till they stop blowing
Rotel Audio... | Answered on Dec 21, 2017
Probably the EEPROM, the heart and brain of the appliance.
I had the same issue with my AIWA, could not figure out the cause, took it in, tech told me EEPROM is blown.
Not economical to repair.
Rotel Audio... | Answered on Nov 20, 2017
Your changer has lost its mind and is doing crazy things.just like mine. Software issue not repairable.. Go shopping.
Rotel Audio... | Answered on Sep 13, 2017
15 questions posted
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Rotel Audio Players & Recorders
Most Popular Question
electric storm audio went out any way
  • Audio Players & Recorders
