20 Most Recent ReCon 6.0 Programmable Rover Questions & Answers
Need manuel for smartlab robot
Do you find one? I’m looking too
8/18/2018 7:58:24 PM • ReCon 6.0... • Answered on Aug 18, 2018
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
3/28/2024 3:46:39 AM • Vehicle Parts &... • Answered on Mar 28, 2024
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
3/24/2024 2:38:44 PM • Vehicle Parts &... • Answered on Mar 24, 2024
3answers
What is hashtag
hash·tag noun
  1. (on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
    • the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
2/25/2024 9:46:45 AM • Vehicle Parts &... • Answered on Feb 25, 2024
Manual for XT-90LCD-autopage auto start
Yes
12/20/2023 6:51:49 PM • Vehicle Parts &... • Answered on Dec 20, 2023
Dynamite autopower DP-300 will not fully recharge no matter how long I leave it on the charger does not go above low charge
Hi, You need to check the output on the charger first, with a meter. Let me know and we will go from there.
10/22/2023 10:19:36 PM • Vehicle Parts &... • Answered on Oct 22, 2023
1944c Furuno radar array won't spin 7 years old. Just beeping
It seems like you're dealing with a technical issue related to a Furuno radar array. If the radar array is not spinning and is emitting a beeping sound, there could be several possible reasons for this problem. Here are a few steps you can take to troubleshoot the issue:
  1. Check Power Supply: Ensure that the radar array is receiving proper power. Check the power cables, connections, and any fuses that might be relevant. Make sure the power source is functional and providing the correct voltage.
  2. Inspect Mechanical Components: If the radar array won't spin, there could be a mechanical issue with the rotating mechanism. Check for any obstructions or debris that might be preventing the rotation. Lubricate any moving parts if necessary.
  3. Connection and Wiring: Examine the connections between the radar array and its control/display unit. Loose or damaged cables could cause communication problems and result in the array not spinning. Ensure all connections are secure and undamaged.
  4. Software and Configuration: Sometimes, software settings or configuration options can affect the operation of the radar array. Check the user manual or documentation to ensure that the radar is properly configured. Try resetting the settings to default and see if that resolves the issue.
  5. Error Codes or Messages: If the radar is emitting beeping sounds, it might be indicating an error condition. Refer to the user manual or any accompanying documentation for a list of error codes or messages and their meanings. This could help pinpoint the problem.
  6. Contact Support: If you've tried the above steps and the issue persists, it might be best to contact Furuno's customer support or a qualified technician for further assistance. They can provide more specific guidance based on the model of your radar array and the symptoms you're experiencing.
Remember, working with electronic equipment requires caution to avoid electrical hazards. If you're not comfortable troubleshooting the issue yourself, it's always a good idea to seek professional help.
8/9/2023 10:12:59 AM • Vehicle Parts &... • Answered on Aug 09, 2023
What does Fo4 mean on a Vector battery jump box?
The "F04" code on a Vector battery jump box typically indicates a fault or error within the unit or its connections. This error could be caused by a poor connection, a damaged battery clamp, or an issue with the box itself. To help fix the issue, try these steps:
1. Ensure the battery clamps are clean and not damaged.
2. Check the connections between the jump box and the battery terminals. Ensure the positive (+) clamp is connected to the positive terminal and the negative (-) clamp is connected to the negative terminal or a suitable ground location on the vehicle.
3. If possible, test the jump box on another vehicle to confirm it is working correctly.
4. If the issue still remains, consult the user manual or contact the manufacturer for further assistance or information on potential repair options.
6/14/2023 6:27:04 PM • Vehicle Parts &... • Answered on Jun 14, 2023
Warning lights ford transit orange oil can and spanner
The orange oil can and spanner warning lights in a Ford Transit indicate an issue with the engine oil or a general engine malfunction. Here are the possible reasons for each warning light:
  1. Orange Oil Can: This warning light typically indicates a problem with the engine oil pressure. It may mean that the engine oil level is low or that there is an issue with the oil pump or oil pressure sensor. Low oil pressure can lead to engine damage, so it is important to address this warning promptly.
    • Check the engine oil level: Ensure that the engine oil level is at the recommended level. If it is low, add the appropriate oil type and quantity as specified in the owner's manual.
    • Inspect for oil leaks: Look for any visible oil leaks under the vehicle. Leaks should be repaired by a qualified mechanic.
    • Faulty oil pressure sensor: If the oil level and leaks are not the issue, there may be a problem with the oil pressure sensor. A diagnostic scan should be performed to determine the exact cause.
  2. Spanner (Wrench): This warning light indicates a general engine malfunction or a fault in the vehicle's electronic system. It can be triggered by various issues, such as a problem with the engine management system, emission control system, or other related components.
    • Check engine codes: Have the vehicle's onboard diagnostic system scanned to retrieve any stored error codes. These codes can help pinpoint the specific issue causing the warning light to illuminate.
    • Seek professional diagnosis: Based on the retrieved error codes, a qualified mechanic will be able to diagnose and address the underlying problem.
It is important not to ignore these warning lights, as they indicate potential issues that require attention. Continuing to drive the vehicle without addressing the problem could lead to further damage or breakdown.
5/10/2023 10:13:19 PM • Vehicle Parts &... • Answered on May 10, 2023
Where is the valet button on the 474p remote car
Find the control unit and follow the 2 lead wire to the valet button. They can be placed anywhere the installer decides to install them, usually hidden as part of the security system.
3/31/2023 8:21:03 PM • Vehicle Parts &... • Answered on Mar 31, 2023
2011 mercedes ml350 bluetec starter relay location
It will be in the fuse box in the engine bay. Usually a small, square, black plastic block. It is the one marked in the photo. I've included a web page for more information. https://fuse-box.info/mercedes-benz/mercedes-benz-m-class-w164-2006-2011-fuses-and-relay cd99b25e-b03d-465c-8023-ef4b42c75f67-undefined-undefined-0.jpeg
3/25/2023 7:43:33 PM • Vehicle Parts &... • Answered on Mar 25, 2023
Avital remote starts up and shuts off
If your Avital remote start system is starting up and then immediately shutting off, it could be due to a few different issues. One possibility is that there is a problem with the system's wiring, which could be causing a short circuit or other electrical issue. Another possibility is that there is a problem with the ignition switch or other components in the vehicle's electrical system. To diagnose and fix the issue, it is recommended to bring your vehicle to a certified installer or mechanic who has experience with Avital remote start systems. They can perform a thorough inspection of the system and vehicle to determine the root cause of the issue and recommend the appropriate repairs.
3/3/2023 9:25:07 PM • Vehicle Parts &... • Answered on Mar 03, 2023
Divoom bluetune solo crackles when charging with ac adaptor whilst operating
Crackling sounds can be caused by a number of factors when using a speaker, including interference from other electronic devices, damaged speakers, or connectivity issues. In this case, it seems that the issue may be related to the power source. It is possible that the AC adapter is not providing a stable and consistent power supply to the speaker, which is causing the crackling sound. Alternatively, there may be an issue with the charging port on the speaker, which could be causing the sound. To troubleshoot the issue, try using a different power source, such as a different AC adapter or a USB port on a computer, and see if the crackling sound persists. If the issue persists, it may be necessary to have the speaker examined by a professional or contact the manufacturer for assistance.
3/2/2023 10:17:08 PM • Vehicle Parts &... • Answered on Mar 02, 2023
Avital remote starter starts then shuts off and starts up
It's not picking up the Tach signal. Check that specific wire to make sure it's installed properly with a good connection. Since this wire goes into the engine compartment you may want to look for damages to the wire caused from other moving parts or possibly even damage from rodents.
2/27/2023 11:40:12 PM • Vehicle Parts &... • Answered on Feb 27, 2023
Whats the torque specs for toyota vista with 4s fe engine
You've got to be more specific. Torque setting for what? Heads, lug nuts...they're all different.
1/23/2023 11:53:55 PM • Vehicle Parts &... • Answered on Jan 23, 2023
Avital 7352L MANUAL
HOW TO SET TIME OF START TIME
1/8/2023 9:52:32 PM • Vehicle Parts &... • Answered on Jan 08, 2023
AS 9903 Car Alarm
Reverse engineer the problem. When did it stop working? Where were you or who drove the vehicle and what happened that may have caused it to stop? Has the battery in the remote just been changed ? Maybe an alarm installer needs to have a look ?
12/2/2022 12:02:07 AM • Vehicle Parts &... • Answered on Dec 02, 2022
ReCon 6.0 Programmable Rover Logo
1 questions posted
Top Smartlab Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Smartlab Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Smartlab Vehicle Parts & Accessories
Most Popular Question
need manuel smartlab robot
  • Vehicle Parts & Accessories
