20 Most Recent Jensen VM9424 Car Video Player Questions & Answers
Hello lumberjack623,
When the jensen starts acting this way, it is simply a power problem. The device is not receiving power from the main source. The battery is weak and need to be charged before the unit can turn on once again. The battery power is too low to turn the unit on.
Try to check the power source or the connection to the power source. It is not charging the players battery. You need to have the connection port replaced. Also the power connection needs be checked.
The battery is simply weak that is why it goes right off when it comes on.
Hope this was helpful to you. All the best Elect_Comp
Jensen VM9424... | Answered on Dec 30, 2018
Rca jacks either are lose or either one burnt out
Jensen VM9424... | Answered on Mar 15, 2018
The screen has a connection for each line on the display and the soldier on some of these connections has gone intermittent. When the unit becomes warm enough, the soldier expands and the connections become more consistent.
If you're skilled, this can be repaired. If not, either replace the unit or take it to a reputable technician.
Jensen VM9424... | Answered on Nov 01, 2017
CHECK THE CLOCK BUTTON SOUNDS LIKE ITS STUCK. IF ITS A TOUCH FACE SET THE TIME THEN MAKE SURE YOU GET OUT OF THAT PROGRAM AND GO SOME WHERE ELSE IN THE SYS. IF THAT DONT WORK SEND IT IN FOR WARRANTY REPAIR,
Jensen VM9424... | Answered on May 06, 2012
you have to turn off the gps time there is a setting in the menu that you turn off navigation sync or something like that. Go to setup and nav time. It is whatever setting has to do with navigation time
Jensen VM9424... | Answered on Mar 27, 2012
Make sure the fan opening at the rear of the unit is not obstructed. It cannot cool itself is this opening id blocked.
Jensen VM9424... | Answered on Sep 13, 2011
Jensen VM9424 Car Video Player Logo
33 questions posted
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
Muntejaya Ginting
Muntejaya Ginting
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
jensen vw9424 navi unit doesn 39 t keep
  • Car Audio & Video
