20 Most Recent Sony Alpha DSLR-A580 Body Only Digital Camera Questions & Answers
tip
Transcode/Convert AVCHD MTS/M2TS Video to FCP Apple ProRes 422 without rendering...
<b>Apple ProRes 422</b> is a standard-definition and high-definition lossy video compression format developed by Apple Inc. for use in post production. It was introduced in 2007 with Final Cut Studio 2 and is comparable to Avid's DNxHD codec which has the same purpose and uses similar bit rates. Both are DCT basedintra-frame-only codecs, and are therefore simpler to decode than distribution oriented formats like H.264. FCP/FCP7 is Mac based editing software which supports transcoding AVCHD MTS/M2TS to Apple ProRes for further editing. <br /><br /><b>AVCHD MTS/M2TS</b> files produced by HD camcorder like Panasonic HDC-TM700, HDC-HS700, HDC-SD700/SD600, Sony CX350, Sony CX550, Canon HF200, etc are not the preferred formats by FCP/FCP7. Even you will have problem for transferring and logging these MTS, M2TS videos. <br /><br />So the program you need is a great <b><a href="http://www.aunsoft.com/video-converter-mac/">Mac MTS Video to Apple ProRes 422 Converter</a></b>. With it, you can convert any HD camcorder 1080 60p/50p, 1080i AVCHD (*.mts, *.m2ts), 720p AVCHD lite files to Apple ProRes 422 for editing with Final Cut Pro, Final Cut Pro 7 on Mac. <br /><br />Below is the step-by-step guide for you to quickly <b><a href="http://canon-videoconverter.com/2011/06/transcodeconvert-avchd-mtsm2ts-video-to-fcp-apple-prores-422-without-rendering-on-mac/">Transcode/Import AVCHD to FCP Apple ProRes 422 Codec (*.mov)</a></b> for editing. <br /><br />Step 1. Download MTS/M2TS files to Apple computer. <br />Connect your AVCHD camcorder c to Apple computer via USB cable, find the .mts, *.m2ts files from the camera folder like PRIVATE &gt; AVCHD &gt; BDMV &gt; STREAM. Then copy and transfer the .mts, *.m2ts files from camera to the Apple hard drive disk. <br /><br />Step 2. Import MTS/M2TS files to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the <b><a href="http://www.aunsoft.com/video-converter-mac/">best AVCHD to FCP Apple ProRes Converting software</a></b>, and click the "Add" button to load AVCHD .mts or .m2ts videos. You may also directly drag and drop the AVCHD video to application UI for importing files. <br /><br />Step 3. Choose Final Cut Pro-Apple ProRes (*.mov) output format. <br />Click the "Format" option and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The Mac MTS/M2TS Video to FCP Converter will convert AVCHD to Apple ProRes 422 MOV with high quality. (<b>Tip:</b> The Apple ProRes (*.mov), DVCPROHD (*.mov), HDV (*.mov) formats under Final Cut Pro output profile are available when your FCP is installed on Mac). <br /><br />Step 4. <b>Convert AVCHD MTS/M2TS video to Apple ProRes (*.MOV) for Final Cut Pro</b>. <br />Click the convert button under the preview window, and the Mac MTS/M2TS to FCP Converter will start the conversion from AVCHD to Apple ProRes MOV for Final Cut. <br /><br />After the conversion, you can easily import <b><a href="http://www.aunsoft.com/video-converter-mac/">Apple Prores 422 to Final Cut Pro without rendering</a></b> for editing. <br /><br /><b>Tips:</b> <br /><br />If you would like to edit AVCHD MTS/M2TS with FCE/iMovie, Avid, etc, you can convert MTS/M2TS to Mac itself bring format like Apple Intermediate Codec, DV PAL/NTSC, DVCPRO NTSC/PAL, DVCPRO50 PAL/NTSC (*.MOV) for FCE and iMovie, or transcode MTS/M2TS to Avid DNxHD (*.mov) for Avid on Mac.
tip
Convert TM900 1080/60p and 1080/50p AVCHD MTS footage to ProRes 422 for Editing...
Edit TM900 1080p 28Mbps AVCHD MTS to ProRes 422 in FCP
The HDC-TM900 High Definition Camcorder is a HD offering from Panasonic.While you record 2D videos in 1080/60p (1080/50p for PAL model) at 28Mbps with Panasonic HDC-TM900 .If you would like to put the AVCHD videos from TM900 to Final Cut Studio for editing, a third party software shall be needed to handle the 1080/60p and 1080/50p footage to ProRes 422 for FCP 6/7. Aunsoft Video Converter for Mac is the recommended Panasonic TM900 AVCHD to ProRes converter for high quality video editing on Mac with less compressed Apple ProRes format.
Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Here is the step-by-step guide for you to Convert,import and edit Panasonic HDC-TM900 MTS to Apple PreRes 422 MOV to Final Cut Pro/FCP7 without rendering on iMac/MacBook Pro with Mac OS X like Snow Leopard.
Step 1. Load Panasonic HDC-TM900 videos to Aunsoft Video Converter for Mac.
Run Aunsoft Video Converter for Mac as the best MTS video to ProRes converter on Mac, click the "Add" button and you can browse the TM900 28Mbps videos for conversion.
Step 2. Choose Apple ProRes for Final Cut Pro.
Click the "Format" option, and navigate the mouse cursor to Final Cut Pro > Apple ProRes 422 (*.mov) as output format. The video to ProRes 422 converter will transcode Panasonic HDC-TM900 1080p AVCHD to Final Cut Pro native format.
Step 3. Choose 1080p size with 60 or 50fps.
Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution. Click the drop-down box for frame rate, and choose 60fps or 50fps as output video frame rate. The frame rate option depends on your source videos in NTSC or PAL model. Click the OK button to save the changes and the Mac AVCHD video converter will convert 1080p AVCHD videos to 1080p ProRes 422 Mac FCP compatible native format.
Step 4. Convert 28Mbps MTS to Apple ProRes for FCP.
Click the convert button under the preview window, the conversion from Panasonic TM900 AVCHD to ProRes 422 MOV Final Cut Pro Native Format will start immediately.
After converting and merging the Panasonic HDC-TM900 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920×1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro.
tip
EOS Converter-Transcode Canon DSLR 550D Video to ProRes 422 in Full HD 1080p for...
Convert/Import Canon Rebel T2i/550D 1080/30fps H.264 MOV to ProRes 422 Codec for FCP 6/7 <br /><br />Canon EOS Digital Rebel T2i / 550D recorded videos are saved in H.264 for image and linear PCM for audio. You can choose different recording modes like full HD 1920&times;1080p at 30/25/24 fps, HD/SD 1280&times;720p/640&times;480 at 60/50 fps. Even though the videos are saved in .mov format, you may also face problem importing the video to Final Cut Pro. So you need a Mac Canon EOS Video Converter for converting and importing 550D1080p MOV for Final Cut Pro without rendering. Aunsoft Video Converter for Mac is the recommended <b><a href="http://www.aunsoft.com/video-converter-mac/">Mac Canon EOS Converter</a></b> for you to edit Digital Rebel T2i / 550D videos. <br /><br />Below is the quick guide for those who have a hard time editing Canon EOS Digital Rebel T2i / 550D H.264 MOV files to ProRes 422 at 30fps in Final Cut Pro 6 or 7. <br /><br />Step 1. Download Canon 550D MOV files to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b><a href="http://canon-videoconverter.com/2011/06/convertimport-canon-rebel-t2i550d-108030fps-mov-to-fcp-with-prores-codec/">Canon EOS Rebel T2i H.264 MOV to ProRes MOV converter</a></b> on Mac OS X. Click the "Add" button to import .mov files from the camera. <br /><br />Step 2. Choose MOV format with ProRes 422. <br />Click the "Format" option, and navigate to Final Cut Pro &gt; Apple ProRes 422 (*.mov) as output format. The Mac Digital SLR camera video converter will convert H.264 mov to prores 422 mov. <br /><br />You may notice that there are also other options like Apple ProRes 4444, Apple ProRes 422 (HQ), Apple ProRes 422 (LT), Apple ProRes 422 (Proxy), DVCPRO HD 1920*1080 30fps etc. <br /><br />Step 3. Choose 1080p size with 30fps. <br />Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution and 16:9 aspect ratio. Click the drop-down box for frame rate, and you can choose 30fps. <br /><br />Step 4. <b>Convert DSLR video to ProRes 422 HQ MOV for FCP.</b> <br />Click the convert button under the preview window, the <b>Mac Canon 550D DSLR video converter</b> will start <b><a href="http://prores-converter.com/2011/06/eos-converter-transcode-canon-dslr-550d-video-to-prores-422-in-full-hd-1080p-for-fcp-editing/">converting DSLR video to ProRes 422 in full HD 1080p for FCP editing</a></b>. <br /><br />After the conversion, you can import ProRes mov to Final Cut Pro without rendering.Hope you enjoy the optimal way to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Canon H.264 mov to ProRes 422 for FCP 7 and 6</a></b>, so that you can edit the H.264 files easily.
tip
Best Conversion to ProRes 422-Convert/Merge Flip Videos to ProRes MOV for FCP on...
The <b>Flip Video</b> is a camcorder for digital video created by Pure Digital Technologies. Variants include the Flip Ultra, the Flip UltraHD, the Flip MinoHD (1hr), the Flip MinoHD (2hrs) and the Flip SlideHD. The great Flip Video camcorders record videos in 640&times;480 resolution at 30 frames per second, using the MPEG-4 ASP video compression. The high definition versions record at 1280 x 720 resolution using H.264 video compression, AAC audio compression and the MP4 file format. <br /><br />However, Flip Video can not edit in iMovie, FCP, FCE etc. How to convert Flip Video to iMovie, FCP, FCE etc for editing Flip Video easily? <br />Now with <b>Aunsoft <a href="http://www.aunsoft.com/video-converter-mac/">Mac Flip Video Converter</a></b>, you can convert Flip Video, Flip HD Video files to Apple ProRes 422 MOV, ProRes 4444 MOV, Apple Intermediate Codec MOV etc with no loss of quality for above uses. At the same time, you can get perfect video/audio synchronization, fast conversion speed and editing your Flip Video by trimming, cropping, merging, adding watermark, effecting and more. <br /><br />Below is the step-by-step guide for you to quickly <b><a href="http://canon-videoconverter.com/2011/06/best-conversion-to-prores-422-convertmerge-flip-videos-to-prores-mov-for-fcp-on-mac/">convert Flip Video to ProRes Codec on Mac</a> (*.mov)</b> for editing in Final Cut Pro. <br /><b>Step1:</b> Download, launch the Aunsoft Flip Video Converter and add your Flip Video files to the program. <br /><b>Step 2. Choose Final Cut Pro-Apple ProRes (*.mov) output format.</b> <br />Click the "Format" option and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The Mac Flip Video to FCP Converter will <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Flip Video to Apple FCP ProRes MOV</a></b> with high quality. (<b>Tip:</b> The Apple ProRes (*.mov), DVCPROHD (*.mov), HDV (*.mov) formats under Final Cut Pro output profile are available when your FCP is installed on Mac). <br /><br />Step 3. <b>Merge Flip footage Video files. (optional)</b> <br />Tick the checkbox for "Merge into one file", and the Flip Video to FCP Converter will join and combine the video clips into a single file as output. <br /><br />Step 4. <b>Convert Flip Footage Video to Apple ProRes (*.MOV) for Final Cut Pro</b>. <br />Click the convert button under the preview window, and the Mac Flip Video to FCP Converter will start the conversion from Flip MP4 Video to Apple ProRes MOV for Final Cut. <br /><br />After the conversion, you can easily <b><a href="http://www.aunsoft.com/video-converter-mac/">Import Apple Prores MOV to Final Cut Pro without rendering</a> for editing</b>. <br /><br /><b>Tips:</b> <br />If you would like to edit Flip MP4 Video with FCE/iMovie, Avid, etc, you can convert Flip Video to Mac itself bring format like Apple Intermediate Codec, DV PAL/NTSC, DVCPRO NTSC/PAL, DVCPRO50 PAL/NTSC (*.MOV) for FCE and iMovie, or transcode flip videoS to Avid DNxHD (*.mov) for Avid on Mac.
tip
Convert and Merge Panasonic TM700/HS700 MTS to ProRes MOV for FCP 7 on Mac
More Article about ProRes Converter: <br /><a href="http://www.aunsoft.com/mac-avchd-videos-to-prores-422-converter-m2ts-to-prores-422-quicktime/">Convert M2TS to ProRes</a> <br /><a href="http://www.aunsoft.com/transcode_convert_avchd_mts_m2ts_to_fcp_fcp7_apple_prores_422_on_mac/">Convert AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_transfer_panasonic_hs60_mts_to_apple_prores_422_mov_for_editing_on_final_cut_pro/">Transcode Panasonic 1080p AVCHD to ProRes</a> <br /><a href="http://www.aunsoft.com/no_loss_of_quality_mts_to_prores_conversion-edit_panasonic_tm900_mts_on_fc_studio/">No Loss of Quality Panasonic MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_nikon_d5100_h264_to_prores_for_editing_on_fcp/">Convert Nikon H.264 MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_canon_eos_t2i_canon_7d_mov_to_prores_mov_for_final_cut_pro_on_mac/">Convert Canon EOS MOV to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_deinterlace_sony_hxr-nx5e_avchd_to_prores_mov_for_fcp_on_mac/">Deinterlace Sony AVCHD MTS to ProRes</a> <br /><a href="http://www.aunsoft.com/convert_bloggie_touch_full_hd_mp4_to_prores_for_final_cut_with_mac_sony_bloggie_touch_converter/">Convert Sony Bloggie Touch Full HD MP4 to ProRes</a> <br /><a href="http://www.aunsoft.com/apple_prores_422_converter_convert_and_playback_apple_prores_codec_movies/">Convert and Playback Apple ProRes Codec Movies</a> <br /><br /><b>Panasonic HDC-TM700</b> is the new model introduced in early 2010 with 32GB built-in Flash Memory. To maximize the beauty of Full-HD 1920 x 1080, 60 progressive recording*, Panasonic worked to develop the ideal camera system. <br /><b>Panasonic HDC-HS700</b>,New 1080/50p recording (Full-HD, 1920 x 1080, 50 progressive recording) conveys about twice the information of 1080i (interlace) recording to produce the ultimate beauty in image quality, exceeding even conventional Full-HD images. It minimizes afterimages and flickering caused by subject motion and renders crisp, detailed images. 64GB SDXC card can record approximately 27 hours 30 minutes of 1920 x 1080i High Definition video in HE mode, and approximately 5 hours 20 minutes of 1920 x 1080p full High Definition video in 1080/50p mode. <br />Final Cut Pro is supposed to support AVCHD Lite import, but it does not work very well.If you encounter any problem using GH2 AVCHD Lite on Mac, or want to edit TM700/HS700 1080p MTS in FCP/FCP 7, it is recommended that you convert TM700 Full HD to common MOV for FCP/FCP 7.So you may face the rendering problem when editing in Final Cut Pro. To avoid waiting for rendering in Final Cut when editing, it is recommended want to <b><a href="http://www.aunsoft.com/video-converter-mac/">Transcode AVCHD to ProRes 422 for Final Cut Pro</a></b> native format. <br /><br />Apple ProRes,Apple ProRes 422,Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br />Here is the step-by-step guide for you to <b><a href="http://prores-converter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert and Merge TM700/HS700 AVCHD MTS to PreRes 422 MOV</a></b> for Editing in FCP/FCP7 without rendering on iMac or MacBook Pro with Mac OS X like Snow Leopard. <br /><br />Step 1. Load Panasonic TM700/HS700 videos to Aunsoft Video Converter for Mac. <br />Run Aunsoft Video Converter for Mac as the best <b>TM700 AVCHD Video to ProRes Converter on Mac</b>, click the "Add" button and you can browse the TM700/HS700 1080p videos for conversion. <br /><br />Step 2. Choose Apple ProRes for Final Cut Pro. <br />Click the "Format" option, and navigate the mouse cursor to <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format. The video to ProRes 422 converter will transcode Panasonic DMC-GH2 1080 AVCHD Lite to Final Cut Pro native format. <br /><br />Step3. <b>Merge Panasonic 700 1080p AVCHD files. (Optional)</b> <br />Tick the checkbox for "Merge into one file", and the Panasonic TM700/HS700 1920&times;1080 AVCHD converter will join and combine the video clips into a single file as output. <br /><br />Step 4. <b><a href="http://canon-videoconverter.com/2011/06/convert-and-merge-tm700hs700-mts-to-prores-mov-for-fcp-7-on-mac/">Convert Panasonic TM700/HS700 videos to Apple ProRes for FCP</a></b>. <br />Click the convert button under the preview window, the conversion from <b>Panasonic Camcorder AVCHD to FCP Native Format ProRes 422</b> will start immediately. <br /><br />After converting and merging the Panasonic TM700/HS700 AVCHD files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video is in HD 1920&times;1080.Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
tip
Best Mac MXF File Converter-Import/Edit Canon MXF Files to ProRes 422 MOV to FCP
MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple Final Cut Pro. So Convert MXF file to FCP MOV Video is a necessary step to do if you want watch your video from your camcorder which export mxf file.
And we know that Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Below is the step-by-step guide for you to quickly Convert/Edit MXF to Apple ProRes 422 (*.mov) Final Cut Pro on Final Cut Studio,Final Cut Pro 7 on Mac.
Step 1. Add MXF videos to Aunsoft MXF Video Converter for Mac.
Connect your MXF Camcorder to iMac with USB 2.0 cable or use card reader to transfer the .mxf files to Apple hard drive disk. Run Aunsoft Video Converter for Mac as the best Mac MXF to FCP Apple ProRes Converter . and click the "Add" button to load .mxf videos.
Step 2. Choose Apple ProRes codec for Final Cut Pro.
Click the "Format" option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) and navigate to the Final Cut Pro group, you will notice that there are profiles with Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), Apple ProRes 4444. Here we choose Apple ProRes 422(HQ) (*.mov) as output format. (The Apple ProRes 422 (Proxy) codec is intended for offline editing and contains 30 percent of the data rate of Apple ProRes 422, and I recommend you to select Apple ProRes 422(HQ), Apple ProRes 422(LT) MOV for outputting.)
Step 3. Merge Canon MXF files. (Optional)
Tick the checkbox for "Merge into one file", and the Mac MXF Video Converter will join and combine the video clips into a single file as output.
Step 4. Convert MXF to Apple ProRes MOV for Final Cut.
Click the convert button under the preview window, the Mac MXF Video converter starts converting MXF videos to Apple ProRes MOV, and joining the MXF files for editing in Final Cut Studio.
After Converting and Merging the MXF files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video .Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
tip
Convert Canon MXF files to ProRes 422 for Final Cut Pro X Editing and QuickTime...
Canon XF Plugin not work for FCP X-MXF files Import to FCP X for Convert MXF to ProRes <br />Best Canon XF video converter on Mac-Canon XF100 to ProRes for FCP X <br /><br />I have a Canon XF100 and would like to get the videos to FCP X. However, there is no Log and Transfer option, and the iSight runs when I click the camcorder button on FCP X. I googled and noticed that there is Canon XF plugin for FCP 7, but <b><a href="http://www.aunsoft.com/video-converter-mac/">Canon XF plugin not work for FCP X</a></b> yet. <br /><br />As Canon XF Plugin does not work for FCP X, I have to look for the workaround for editing Canon MXF files on Mac. I find Aunsoft Video Converter for Mac as a great tool to make the videos compatible to Final Cut X. It would <b><a href="http://prores-converter.com/2011/07/convert-canon-mxf-files-to-prores-422-for-final-cut-x-editing-and-quicktime-playback/">Convert Canon .mxf files to ProRes</a></b> 422 and ProRes 422 (HQ), so that I can import into Final Cut X, export ProRes 422 at the same settings as the original and play it with QuickTime. <br /><br />Below is the simple step-by-step guide to convert Canon MXF files to ProRes 422 for Final Cut X editing and QuickTime playback. <br /><br />First, download Canon XF100 videos to Mac with Canon XF Utility. You will get the folder with files like .CIF, .THM, .MXF and .SIF. <br /><br />Second, import .MXF files to Aunsoft Video Converter for Mac. Just run it as best <b><a href="http://canon-videoconverter.com/2011/07/convert-canon-mxf-files-to-prores-422-for-final-cut-pro-x-editing-and-quicktime-playback/">Canon XF video converter on Mac</a></b>, then click the Add button to import .mxf files or drag and drop the files to the application UI. <br /><br />Third, choose Apple ProRes with 1920x1080 output. Click the format option to choose Final Cut Pro &gt; Apple ProRes 422(*.mov) as output format. Click the Settings button to choose 1920x1080 as video size. <br /> <br />Fourth, click the convert button under the preview window to start converting Canon XF100 files to ProRes for FCP X. <br /><br />Soon after the conversion is done, you can import the <b><a href="http://www.aunsoft.com/video-converter-mac/">ProRes files to Final Cut X</a></b> and enjoy HD video editing and playback. <br /><br /><b>Tips:</b> <br />If you are using iMovie, Final Cut Express, just choose Apple Intermedia Codec as output format for HD video editing.
tip
Import/Convert Canon XF300 MXF movies to Apple ProRes for editing on FCP X
Edit Canon XF300 MXF on FCP X?Transcode MXF to Apple ProRes 422 First <br /><br />Are you trying to <b>import the HD MXF videos shot with your DSLR camcorder to FCP X</b>? If so, you must be extremely disappointed to see the mxf files being grey and cannot be imported. I have just encountered the same problem. <br /><br />I shot many mxf videos with my Canon XF300 and wanted to edit them on FCP X, but the problem is that FCP X refused to import them. I turned to Yahoo Answer and found Aunsoft Video Converter for Mac,it helps me <b>convert MXF files from Canon XF300 to Apple ProRes</b> easily. <br /><br />Following I would like to share the quick steps of <b><a href="http://prores-converter.com/2011/07/importconvert-canon-xf300-mxf-movies-to-apple-prores-for-editing-on-fcp-x/">Transcode Canon XF300 MXF to Apple ProRes for Editing on FCP X</a></b>. <br /><br />Step 1: Import MXF files from Canon XF300 to Aunsoft Video Converter for Mac <br />Run Aunsoft Video Converter for Mac as the best converter to transcode Canon XF300 videos to Apple ProRes 422.Cick the "Add" button to import mxf files from Canon XF300 to Aunsoft Video Converter for Mac. <br /> <br />Step 2: Choose Apple ProRes for FCP X <br />After the movies are loaded, click the "format" button and choose their export format "Apple ProRes 422(HQ) (*mov)". Click "Browse" to specify the output destination. <br /> <br />Step 3: Convert mxf videos of Canon XF300 to Apple ProRes 422 (HQ) for FCP X. <br />After setting the output format and destination, click the "Convert" button under the preview window and conversion from Canon XF300 mxf files to Apple ProRes 422 (HQ) starts immediately. It will complete in a few minutes. <br /><br />Then you can enjoy your time <b><a href="http://www.aunsoft.com/video-converter-mac/">editing HD ProRes movies on FCP X</a></b>.
tip
Convert/Import Canon HF M300 MTS Videos to ProRes for Final Cut Pro X with High...
Canon FCP X-Transcode/Edit Canon HF M300 MTS to ProRes 422 for FCP X <br /><br />To save the storage space of my Canon HFM300 and shoot more ,I used to copy the videos I like from the camcorder to my Mac and delete the others. Recently I want to edit the videos I shot in my graduation year with FCP X and then share the MP4 videos on youtube. The problem is that I do not have the whole BDMV folder and therefore, cannot import MTS Videos to FCP X on Mac. I tried many products and thanks to <b>Aunsoft Final Mate for Mac</b> - <b><a href="http://www.aunsoft.com/final-mate-mac/">2011 Best Import and Edit Software</a></b>, it helps me solve the problem. Following I am very glad to share my experience of importing MTS files with Aunsoft Final Mate for Mac and <b><a href="http://prores-converter.com/2011/07/editimport-canon-hf-m300-mts-videos-to-prores-for-final-cut-pro-x-on-mac-with-high-quality/">Import and Convert MTS files to Apple ProRes for editing on FCP X</a></b>. <br /><br />1. Import MTS videos from Aunsoft Final Mate for Mac. <br />One great feature of Final Mate for Mac is that it can import MTS files without the whole BDMV folder. Click the "Add A Path" icon to browse the Mac and select a folder where MTS video files are saved, then click "OK" to display the videos. The MTS files are imported to the Final Mate for Mac. <br /> <br />2. Create a movie for conversion. <br />Click the drop-down button of "Add A Movie" icon and choose "For Conversion" to create a blank movie. Then drag and drop the MTS files from Camcorder Tab to the blank movie. <br /><br />3. <b>Export Apple ProRes or Apple ProRes 422 for Editing on FCP X</b>. <br />Click the little icon on the right side of the movie and choose its output format as "Apple ProRes 422" under "final cut pro", click the "Export" button and Start <b>Convert Canon MTS to ProRes/ProRes 422</b> <br /> <br />4. <b>Edit Apple ProRes on FCP X</b>. <br />After conversion is completed, you can <b><a href="http://www.aunsoft.com/final-mate-mac/">Edit Apple ProRes on FCP X</a></b> and then share it to youtube. <br /><br /><b>Tips:</b> <br />Aunsoft Final Mate for Mac can only import videos of AVCHD, TOD, MOD temporarily, for videos of other formats like mxf, mov and mp4,you can use <b><a href="http://www.aunsoft.com/video-converter-mac/">Video Converter for Mac</a></b>to help you.
tip
50p/60p Converter-Transcode CX360 MTS to ProRes for FCP X Editing
Merge/Edit Sony CX360V 1920x1080 50p/60p AVCHD to ProRes 422(HQ)(*mov) on FCP X with Highest quality <br /><br />I used Sony HDR-CX360V to record 1920x1080 50p/60p AVCHD MTS files, which are not compatible with FCP X. So in order to edit the movies on FCP X, conversion from <b><a href="http://www.aunsoft.com/final-mate-mac/">MTS in 50/60 progressive mode to ProRes</a></b> is necessary. <br /><br />I've tried Clipwrap, Toast and Aunsoft to carry out the conversion. Clipwrap failed because it cannot export 50/60 progressive mode; Toast completed converting but the quality is badly affected. <br /><br />Only Aunsoft Final Mate for Mac successfully converted the 50p/60p MTS to ProRes 422 with no loss of quality. I really want to say that it is the best software to <b>Transcode Sony HDR-CX360V 1920x1080 50p/60p AVCHD MTS footage for FCP X</b> that I've ever used. <br /><br />Here is the step-by-step guide to quickly <b><a href="http://canon-videoconverter.com/2011/07/transcode-sony-cx360-50p60p-avchd-mts-footage-to-prores-422-hq-for-fcp-x-editing/">Convert/Edit Sony CX360 50p/60p MTS to ProRes 422 (*.mov) on FCP X</a></b>. <br /><br />1. Importing 50p/60p AVCHD MTS files to Aunsoft Final Mate for Mac <br />Use a USB cable to Connect Sony HDR-CX360V to Mac. Follow the popup window and wizard to complete the import. <br /><br />2. <b>Merging and converting 50p/60p AVCHD MTS files</b> to what you want. <br />After the MTS movies are imported, select one or several videos you would like to convert and then drag and drop them to Movies tab. You can choose the files to be joined as one whole, or create a single movie for each file. Then click the "set parameter" button. Choose Apple ProRes 422(HQ) (*.mov) under Final Cut Pro as its output format and choose "50" (or 60) for the frame rate. <br /><br />3. Export Apple ProRes 422(HQ) for editing on FCP X <br />After setting the output format and frame rate, click the "Export" button and conversion from <b>1920x1080</b> 50p/60p AVCHD MTS files to Apple ProRes 422(HQ)(*mov) starts. <br /><br />After the conversion is completed, <b><a href="http://www.aunsoft.com/final-mate-mac/">Import and Edit ProRes 422 (HQ) on FCP X</a></b>. <br /><br /><b>Tips:</b> <br />If you want to join/merge Sony HDR-CX360V AVCHD MTS clips and <b>play on WDTV Live with original quality</b>, you can use Aunsoft Final Mate to import MTS files and flawlessly export MKV without transcoding.
tip
Convert AVCHD Files to Apple ProRes 422 for FCP with Best Camcorder Software for...
Convert AVCHD Files to Apple ProRes 422 for FCP with Best Camcorder Software for Mac <br /><br />Do you have problems of importing AVCHD 1080/60p, 1080/50p, 1080/60i MTS or M2TS files to Final Cut Pro and want to find camcorder software on Mac OS X to <b><a href="http://www.aunsoft.com/final-mate-mac/">Transcode AVCHD files to Apple ProRes Codec</a> for editing in FCP without rendering</b>? <br /><br />As the best camcorder software on Mac OS X for Sony, Panasonic, Canon, JVC camcorders, Aunsoft <b>Final Mate for Mac</b> is featured with one most important feature for Mac users-help <b><a href="http://www.aunsoft.com/convert_avchd_files_to_apple_prores_422_with_best_camcorder_software_for_mac/">Convert AVCHD video footage to Final Cut Pro ProRes</a></b> formats including Apple ProRes 422 Codec, Apple ProRes 422 HQ Codec, Apple ProRes 422 LT, Apple ProRes 422 Proxy, Apple ProRes 4444 Codec. With Final Mate for Mac as the default camcorder software on Mac, you can choose preferable format for editing on Final Cut Pro without rendering. Final Mate for Mac also support converting AVCHD files to Apple Intermediate Codec(AIC)for editing in Final Cut Express or iMovie. <br /><br />The guide will share with you a easy and fast method of <b>Converting AVCHD files to Apple ProRes 422</b> with featured software for camcorder on Mac. <br /><br />1.Run <b><a href="http://www.aunsoft.com/final-mate-mac/">AVCHD to Apple ProRes Converter for Mac</a></b> and add AVCHD files. <br /><br />Launch Aunsoft Final Mate for Mac and add AVCHD files to the program by clicking on "Add" button to browser AVCHD file path on your local Mac computer. Then all AVCHD MTS/M2TS clips will show in Resource Tab of Final Mate for Mac. <br /><br />2.<b>Join AVCHD files and choose Apple ProRes 422 as output option</b>. <br /><br />Directly drag and drop AVCHD files from Resource Tab to Movies Tab or Timeline to create a new movie and join AVCHD files into one for converting to Apple ProRes 422 Codec. There will be a pop-out window during the process shown as following: <br /> <br />Please choose "Create A Single Movie" to merge all AVCHD video footage into one movie. <br /> <br />3. Start <b><a href="http://prores-converter.com/2011/06/convert-avchd-files-to-apple-prores-422-for-fcp-with-best-camcorder-software-for-mac/">converting AVCHD to Apple ProRes 422</a></b> <br />Click on Export button and follow <b>Export into Editor &gt; Final Cut Pro &gt; Apple ProRes 422 HQ(*.mov)</b> format to choose your output format for converting AVCHD to FCP supported format. <br /> <br />Confirm your settings and click ok to starting conversion. Minutes later, you can access combined Apple ProRes 422 MOV movie by clicking on "Browse for Export Path". Now you are able to edit AVCHD files on FCP without rendering with the help of Final Mate for Mac as the best camcorder software on Mac OS X.. <br /><br />Tip: If you use iMovie or Final Cut Express for AVCHD editing, you may be interested to know how to <a href="http://www.aunsoft.com/mac_convert_sony_hdr-tg5v_avchd_to_apple_intermediate_codec-aic_for_fce-imovie/">Convert AVCHD files to Apple Intermediate Codec for iMovie/FCE</a>.
tip
AVCHD to FCP X-MTS/M2TS in 50/60 Progressive mode to FCP X for ProRes 422 (HQ)
HD Videos to Final Cut Pro X-Convert 1920x1080p 50/60 AVCHD files to ProRes for Final Cut Pro X Editing <br />Final Cut Pro X and AVCHD-Import 1080 60p HD Videos to ProRes FCP X Conversion <br /><br />The new Sony camcorders like Handycam HDR-CX360VE, CX700V, and Panasonic camcorders like HDC-TM900/HS900/SD900, TM700/HS700/SD700 support recording in 1920x1080/50p mode for PAL regions like UK, France, German, or 1920x1080/60p mode for NTSC regions like US, Canada. Even though <b>Final Cut Pro X</b> with the new UI is said to support AVCHD files natively, without transcoding to Apple ProRes, the 1920x1080p 50/60 AVCHD files still could not be detected/imported to FCP X. <br /><br />To edit the 1080/60p or 1080/50p <b>Camcorder AVCHD Videos to Final Cut Pro X</b>, the conversion from MTS/M2TS in 50/60 <b><a href="http://www.aunsoft.com/final-mate-mac/">Progressive mode to FCP X ProRes 422 (HQ)</a></b> or to Apple ProRes 422 is necessary. Aunsoft Final Mate for Mac is the recommended AVCHD to ProRes converter for Final Cut Pro X. It keeps better color than compressor. What's more, it can keep 50fps and 60fps in Apple ProRes. <br /><br />The guide below shows you how to <b><a href="http://1080p-converter.com/2011/07/avchd-to-fcp-x-mtsm2ts-in-5060-progressive-mode-to-fcp-x-for-prores-422-hq/">Convert and Edit 1920x1080p 50/60 AVCHD files to ProRes in Final Cut Pro X</a></b>. <br /><br />Step 1. <b>Import 1920x1080p 50/60 AVCHD files to Aunsoft Final Mate for Mac</b>. <br />Run Final Mate for Mac as the best <b><a href="http://www.aunsoft.com/final-mate-mac/">Final Cut Pro X and AVCHD</a></b>, which can import files from AVCHD camera and the separate .mts files on Mac hard drive. For files from camera, just use USB cable to connect camera to Mac, and you can select files to download to Final Mate for Mac with the wizard. Otherwise, go to the Resource tab, and click the Add file path button to browse the AVCHD folder with .mts or .m2ts clips. <br /><br />Step 2. Choose <b>AVCHD files to FCP X ProRes conversion</b>. <br />Select the files from the Camcorder tab or Resource tab, drag and drop to the Movies tab to create movie for conversion. You can choose the files to be joined as a movie, or create single movie for each file. In terms of joining as a movie, the files would play seamlessly. <br /> <br /><b>Step 3. Choose Apple ProRes 422 (HQ) with 50fps or 60fsp for FCP X.</b> <br />Click the Export button, and go to the third button for editing software. Choose Final Cut Pro &gt; Apple ProRes 422 (HQ)(*.mov) as the output format. Choose 1920x1080 from the drop-down list of the output video size, and choose 50 or 60 as frame rate according to your camera mode. <br /> <br />Wait for the conversion, and you can then import 1080 60p <b><a href="http://www.aunsoft.com/final-mate-mac/">HD videos to Final Cut Pro X</a></b> through the direct import and enjoy editing in FCP X. <br /><br /><b>Tips:</b> <br />If you face the problem that the resulting ProRes files have no video just sound in FCP X or QuickTime, just make sure you install the related ProRes codec for FCP X, or go to the guide: <b><a href="http://www.aunsoft.com/solve_no_video_problem_after_converting_avchd_to_apple_prores_for_fcp_x/">Solution to ProRes Video Issue in FCP X</a></b> on aunsoft.com.
tip
Mac MXF to MOV Converter-Convert MXF File to QuickTime MOV on Mac OS X
Best MXF to QuickTime MOV Converter on Mac OS X <br /><br />MXF is a "container" or "wrapper" format which supports a number of different streams of coded "essence", encoded with any of a variety of codecs, together with a metadata wrapper which describes the material contained within the MXF file. MXF has been designed to address a number of problems with non-professional formats. MXF file format is not compatible with many programs. So you may have problem to play, edit or use these format. So are Panasonic HVX200/HPX300 MXF files, P2 MXF files. <br /><br />Apple QuickTime movie is stored in the format of Apple QuickTime (.mov, .qt) which is a file format for storing and playing back movies with sound. Though developed and supported primarily by Apple Computer, the format of Apple QuickTime isn't limited to Macintosh operating systems. Apple QuickTime is also commonly used in Windows systems, and other types of computing platforms. In Windows, QuickTime movies usually appear with the .mov filename extension. <br /><img src="mxf-mov1.jpg" /> <br />With Aunsoft <b><a href="http://dts-ac3-converter.com/2011/07/mac-mxf-to-mov-converter-convert-mxf-file-to-quicktime-mov-on-mac-os-x/">Mac MXF Conversion</a></b>, we can convert mxf file to QuickTime MOV on Mac with best quality, fastest converting speed, excellent A/V sync and so on. And we also can use the Mac MXF File Converter to convert mxf file to friendly video formats just like mpg, wmv, mp4, mov, mpeg, dv, etc for playing on iPad, iPod, iPhone 4, iTunes, PSP, Apple TV, Android Phones, etc so that we can watch our favorite mxf conversion file everywhere. <br /><br />Follow the step to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert MXF files to QuickTime MOV</a></b> on Mac now. <br /><br />Step1: Download and install the <b><a href="http://download.aunsoft.com/video_converter_mac/videoconvertermac_setup.zip">best Mac MXF File Converter</a></b>, add your MXF file by clicking "Add" in the File menu or in the main interface. <br /><br />Step2: In "Format" drop down list box, you may select output format. The software allows setting different output formats according to different files. For example, I just set the QuickTime MOV as output format of the MXF file. <br /><img src="convert-mxf-to-quicktime-mov.jpg" /> <br />Step3: Now let's select the output folder by clicking the "Output folder" icon. <br /><br />Step4: Finally, click "Convert" in the main interface. After a successful conversion, click "Open" to check the QuickTime MOV files. <br /><br />If you're interested in converting MXF files to QuickTime MOV on Mac without losing quality, please visit: <b><a href="http://www.aunsoft.com/mac_mxf_to_quick_time_mov_converter_convert_mxf_files_to_mov/">Best Mac MXF to QuickTime MOV Converter</a> ; <a href="http://www.aunsoft.com/convert_p2_mxf_to_quicktime_mov_for_fcp_on_mac/">Convert P2 MXF to QuickTime MOV for FCP</a> ; <a href="http://www.aunsoft.com/edit_mxf_in_avid_media_composer_convert_p2_mxf_to_wmv_for_avid/">Convert P2 MXF to WMV for Avid</a> ; <a href="http://www.aunsoft.com/edit_mxf_files_in_adobe_after_effects/">Edit MXF Files in Adobe After Effects</a></b> .
tip
Convert/Join and Stream Sony CX700V AVCHD MTS to WDTV Live Plus Player with best...
Fix Problem Streaming and playing Sony CX700 1080/60p MTS to WDTV Live Plus Player <br />Stream the Merged MTS Videos from Sony HDR-CX700V Camcorder to WDTV Live Plus Player with best quality <br /><br />I use <b>Sony HDR-CX700 for recording 1920 x 1080 MPEG-4 AVC/H.264 MTS</b> files. And I have a <b>WD TV Live plus player and a WD TV Live Hub</b>. I use WD TV Live Plus Player to watch my cx700v camcorder recording mts files. Because of some pause in the process of recording, ssome mts files need to be joined into one big file. After google search, I downloaded a trial version of the tsmuxer, so I could merge my mts files together on my Mac OS X 10.5 Leopard. The process of merged files goes without mistake through tsmuxer program, but when I use the <b>stream play the lossless output mts files on WD TV Live plus player</b>, the files only play the first 10 seconds. <br /><br />I asked for some help to fix problem playing joined mts to wd tv on some forums and was recommended to try to convert the Sony cx700v mts to MP4 . So I search a best quality mts converter, some people recommended to try <b>Final Mate for Mac</b> which can help me to convert and merge mts files with highest quality. And I download a free trial version of Final Mate for Mac, so I could convert and join my Sony cx700 .mts files together. The files play fine without any problem. It offers the one fastest way to <b><a href="http://www.aunsoft.com/final-mate-mac/">convert and Combine MTS files</a></b> into big one for further streaming and playing on WD TV Live plus player with perfect quality . <br /><br />Here is the step-by-step guide to quickly <b><a href="http://sony-mts-converter.com/2011/06/stream-the-merged-mts-videos-from-sony-hdr-cx700v-camcorder-to-wdtv-live-plus-player-with-best-quality/">convert and merge Sony HDR-CX700V 1080/60p MTS to HD H.264 (*.mp4) for streaming to WD TV Live plus player</a></b> with highest quality on Mac. <br /><br />Step 1. Create a Movie for Converting Sony HDR-CX700 1080/60p MTS files. <br />Just select one or multiple video files you would like to convert and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created. <br /><br />Tips: You also can Click downlist of Add button and select for conversion. A blank movie is created. Then drag and drop your Sony HDR-CX700 60fps .mts files to such a movie for merging together and making a conversion. <br /><br />Step 2: Choose MP4 as WDTV Output Format. <br />Click the Export button and go to the Common Format.Choose the HD Video &gt; H.264 HD Video (*.mp4). <br /><br /><b>Tips:</b> You are free to set/adjust output MP4 files parameters (Bit rate - high quailty, Audio bit rate to 640000,Frame rate -30 , Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality. <br /><br />Step 3. <b>Export Merge MTS to MP4 for WDTV Live Plus in HD</b>. <br />Click OK to start and Convert and Join AVCHD MTS files from Sony cx700v camcorder to H.264 MP4 for WDTV Live Plus Player with highest quality. This <b><a href="http://www.aunsoft.com/final-mate-mac/">MTS Converter/Joiner</a></b> will be automatically output a complete big files with merged various mts files. <br /><br />After the conversion, you can <b>stream the merged mts videos from Sony HDR-CX700V Camcorder to WDTV Live Plus Player with best quality</b>. <br /><br /><b>Tips</b>: Before choosing output format, you also can click button to <b>cut/split</b> and click button to <b>delete</b> the unwanted .mts clips.
tip
Mac Canon DSLR Video Converter-Transcode Canon EOS 5D H.264 MOV to iMovie on Mac
Converting Canon 5D Mark II Videos to iMovie 8/9 on Mac with Best Quality <br /><br /><b>Mac DSLR Video Converter</b> functions as the <b>Mac Canon DSLR video converter</b>, Mac Sony DSLR video converter, Mac Panasonic DSLR video converter, Mac Nikon DSLR video converter, Mac Kodak video converter, Mac Flip video converter and even Mac iPhone 4 video converter for your Apple computer with PowerPC or Intel CPU. <br /><br /><b>Mac DSLR Video Converter</b> enables you to <b>import H.264 MOV videos from Digital SLR cameras</b> to editing software like iMovie 8/9/11,Final Cut Express,Final Cut Pro,Final Cut Studio,Adobe Premiere Pro,Avid etc. <br /><br /><b>Mac DSLR Video Converter</b> helps you organize DSLR recordings from camcorders like Sony VG10, Canon 600D in AVCHD MTS/M2TS, MOV formats, and <b>convert MTS/M2TS and H.264 MOV to Mac</b> editable format. <br /><br />Below is the quick guide for you to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Canon 5D Mark II videos to iMovie</a></b> with Aunsoft Video Converter for Mac OS X like Snow Leopard, Leopard and Tiger. <br /><br />Step 1. Import Canon DSLR MOV to Aunsoft Video Converter for Mac. <br />After the movie clips are transferred to Apple computer hard drive, run Aunsoft Video Converter for Mac as the best <b><a href="http://canon-videoconverter.com/2011/06/mac-canon-dslr-video-converter-transcodingconverting-canon-eos-5d-mark-ii-h-264-mov-to-imovie-on-mac/">Mac Canon DSLR Video converter</a></b>. Click the "Add" button to browse the Canon DSLR .mov files for conversion. <br /><br />Step 2. Choose QuickTime MOV format. <br />Click the "Format" option and navigate the mouse cursor to Common Video &gt; MOV - QuickTime(*.mov) as output format. The Mac DSLR movie converter will <b><a href="http://www.aunsoft.com/video-converter-mac/">transcode Canon H.264 videos to iMovie</a></b> supported videos with original resolution in 1920x1080. <br /><br />To change video frame rate, just click the "Settings" button and choose the frame rate option. <br /><br />Step 3. Convert Canon DSLR EOS MOV for iMovie. <br />Click the convert button under the preview window, and the Mac Canon DSLR movie converter will start <b><a href="http://www.aunsoft.com/video-converter-mac/">converting Canon H.264 MOV to QuickTime MOV</a></b> for editing in iMovie with high quality. <br /><br />After the conversion, just import the output videos to iMovie 8, iMovie 9 or even iMovie 11 for creating your own movies.
tip
Join/Combine Canon HF M300 AVCHD MTS raw footage-Stream Canon MTS to Panasonic...
Best Mac Manage MTS Converter-Cut and Join Canon HF M300 AVCHD MTS clips to Panasonic HDTV with Highest Qulity <br /> I am using Canon HF M300 to record videos and the camcorder saves AVCHD files in .mts format. The Canon VIXIA HF M300 captured 1920 x 1080 24Mbps Full HD Recording. I connect the Canon Camcorder to my Panasonic HDTV via direct USB. However, I found my shooting video of the HF M300 have some pause and interlace in the process of recording. So I need to delete much unwanted mts clips and join into one big files. So I asked for some help on some forums and was recommended to try freeware TSmuxer, TSsniper which can help me to <b>Split and Merge AVCHD MTS files</b>. But it is frustrated for Mac users because most of them can only work on Windows platform. Then one of my friend recommended to a new <b>MPEG-4 AVC/H.264 cutter/joiner software</b> for Final Mate for Mac exactly what I want - delete the unwant .mts clips and merge HF M300 1080/60p meaningful MTS files to one single MTS files without re-encoding. And I had succeed play those merged .mts files on my Panasonic TV. <br /><br />Here is the detailed guide introduces <b>how to split unwanted HF M300 record AVCHD .mts clips and join meaningful mts clips without conversion for playing on Panasonic HDTV</b> with Mac OS X Snow Leopard on iMac, MacBook, Mac Pro. <br /><br />Step 1: <b>Import/Capture Canon HF M300 Camcorder AVCHD files to Aunsoft Final Mate for Mac.</b> <br />Free Download Final Mate for Mac as a <b><a href="http://www.aunsoft.com/final-mate-mac/">Best Mac Manage MTS Converter</a></b>. When Aunsoft <b>Final Mate for Mac</b> is run, it can automatically detect and pop up a wizard for you to capture video from camcorder. The videos would be listed on the "Camcorder" tab. <br /><br />Step 2: Create a Movie for <b>cutting and joining HF M300 1080/24Mbps MTS clips</b>. <br />Click the Add movie button, and choose the" For Lossless Output", a movie about cut mts for lossless output will be created by default. Then select one or multiple mts video files you would like to split, join from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for no re-encoding will be created. <br /> <br />Step 3. <b>Cut off unwanted parts from raw MTS movie for store</b>. <br />From the timeline, to cut/trim the video, just play it and click the Split button when it plays to the frame you want, and then click the "Delete" button next to the <b>Split</b> button to remove the unwanted. And the Previous Frame and Next Frame buttons can help you locate each frame of the videos and cut with frame accuracy. <br /> <br />Step 4. <b>Join/combine HF M300 AVCHD MTS raw footage</b>. <br />To <b>join</b> another clip to the end of the movie, just select the file, drag and drop to the movie ID. The files will be joined into one file as output. <br /><br />Step 5. <b>Export One Big raw HF M300 MTS with no loss of quality</b>. <br />Click the Export button and you click the OK button, the Mac MTS/M2TS cutter/joiner will start merging large .mts files into one mts without conversion at the fast speed. The non-conversion process will prevent loss of quality when <b><a href="http://www.aunsoft.com/final-mate-mac/">Mac joining HF M300 avchd camcorder files for storing</a></b>. <br /> <br />After a few seconds, I <b>Connect Canon Camcorder Movies to my Panasonic HDTV</b> via direct USB. Then <b><a href="http://sony-mts-converter.com/2011/06/joincombine-canon-hf-m300-avchd-mts-raw-footage-stream-canon-mts-to-panasonic-tv-for-watching/">Stream Canon HF M300 MTS to TV for watching</a></b> with family. The output mts also can store the video on your home server, NAS or external hard drive.
tip
Best Mac Manage MTS Converter-Watch Merged Canon HF M300 AVCHD MTS Files on...
Split and Join Canon HF M300 Full HD MTS to Panasonic HDTV with no loss of quality <br /> I am using Canon HF M300 to record videos and the camcorder saves AVCHD files in .mts format. The Canon VIXIA HF M300 captured 1920 x 1080 24Mbps Full HD Recording. I connect the Canon Camcorder to my Panasonic HDTV via direct USB. However, I found my shooting video of the HF M300 have some pause and interlace in the process of recording. So I need to delete much unwanted mts clips and join into one big files. So I asked for some help on some forums and was recommended to try freeware TSmuxer, TSsniper which can help me to split and merge mts files. But it is frustrated for Mac users because most of them can only work on Windows platform. Then one of my friend recommended to a new <b>MPEG-4 AVC/H.264 cutter/joiner software</b> for Final Mate for Mac exactly what I want - delete the unwant .mts clips and merge HF M300 1080/60p meaningful MTS files to one single MTS files without re-encoding. And I had succeed play those merged .mts files on my Panasonic TV. <br /><br />Here is the detailed guide introduces how to <b><a href="http://canon-videoconverter.com/2011/06/split-and-join-canon-hf-m300-full-hd-mts-to-panasonic-hdtv-with-no-loss-of-quality/">Split and Join HF M300 record AVCHD .mts clips for Watching/Playing on Panasonic HDTV</a></b> with Mac OS X Snow Leopard on iMac, MacBook, Mac Pro. <br /><br />Step 1: Import/Capture Canon HF M300 Camcorder AVCHD files to Aunsoft Final Mate for Mac. <br />Free Download Final Mate for Mac as a <b><a href="http://www.aunsoft.com/final-mate-mac/">Best Mac Manage MTS Converter</a></b>. When Aunsoft <b>Final Mate for Mac</b> is run, it can automatically detect and pop up a wizard for you to capture video from camcorder. The videos would be listed on the "Camcorder" tab. <br /><br />Step 2: Create a Movie for <b>cutting and joining HF M300 1080/24Mbps MTS clips</b>. <br />Click the Add movie button, and choose the" For Lossless Output", a movie about cut mts for lossless output will be created by default. Then select one or multiple mts video files you would like to split, join from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for no re-encoding will be created. <br /> <br />Step 3. <b>Cut off unwanted parts from raw MTS movie for store</b>. <br />From the timeline, to cut/trim the video, just play it and click the Split button when it plays to the frame you want, and then click the "Delete" button next to the <b>Split</b> button to remove the unwanted. And the Previous Frame and Next Frame buttons can help you locate each frame of the videos and cut with frame accuracy. <br /> <br />Step 4. <b>Join/combine HF M300 AVCHD MTS raw footage</b>. <br />To <b>join</b> another clip to the end of the movie, just select the file, drag and drop to the movie ID. The files will be joined into one file as output. <br /><br />Step 5. <b>Export One Big raw HF M300 MTS with no loss of quality</b>. <br />Click the Export button and you click the OK button, the Mac MTS/M2TS cutter/joiner will start merging large .mts files into one mts without conversion at the fast speed. The non-conversion process will prevent loss of quality when <b><a href="http://www.aunsoft.com/final-mate-mac/">Mac joining HF M300 avchd camcorder files for storing</a></b>. <br /> <br />After a few seconds, I <b><a href="http://www.aunsoft.com/final-mate-mac/">Connect Canon Camcorder Movies to my Panasonic HDTV</a></b> via direct USB. Then <b>Stream Canon HF M300 MTS to TV for watching</b> with family. The output mts also can store the video on your home server, NAS or external hard drive.
tip
DLNA Conversion-Seamlessly Connect and Watch Droid X Videos to HDTV through DLNA
If you have a look at Motorola Droid X, you may notice the Droid X is compatible with DLNA service. DLNA, as the short term for Digital Living Network Alliance, is to make it possible to view media between PCs, mobile devices and other consumer electronics. If you have a home wired or wireless network, e.g. Wi Fi network and a DLNA-capable TV, you can stream music, movies and photos from Droid X to TV. DLNA make it an alternative method to watch Droid X videos on TV besides HDMI output with Verizon Gallery app. <br /><br />Since we may sometimes do not have DLNA PC or transfer videos from PC to Droid X, we may face the problem of putting movies to Droid X. Here the guide will include two parts: one for <b><a href="http://www.aunsoft.com/video-converter/">DLNA Convert Movies to Droid X</a></b> and the other for <b>Streaming Movies from Droid X to HDTV</b>. <br /> <br /><b>Part I. Convert/Transfer movies to Droid X</b> <br />We need a powerful video to Droid X converter on Windows computer to make most videos compatible to Droid X. Aunsoft Video Converter is the right choice for converting TiVo, MKV, MTS, TOD, AVI to Droid X MP4. <br /><br />Step 1. Run Aunsoft Video Converter as the perfect <b>Droid X video converter</b>, and click the "Add" button to load HD videos in formats like .tivo, .ts, .mkv, .mts, .avi, .rmvb. <br /><br />Step 2. Choose Motorola Android MP4 format by clicking the "Format" option and navigating to <b>Android &gt; Motorola Droid (X) H.264 Video(*.mp4)</b>. <br /> <br />Step 3. <b>Convert HD videos to H.264 MP4 for Droid X</b> by clicking the start button under the preview window. After conversion, connect Droid X to PC via USB cable, and transfer videos to Droid X under the DCIM &gt; Camera folder. <br /><br />Part II. <b><a href="http://www.aunsoft.com/stream_play_motorola_droid_x_videos_to_hdtv_via_dlna/">Seamlessly Stream Droid X Videos/Movies to HDTV via DLNA</a></b>. <br />The DLNA service could be used as a stand alone, or used in combination with HDMI. A home network (wired or wireless) or WiFi network shall be set up with your DLNA compatible TV and Droid X. <br /><br />Step 1. Turn on Droid X and the TV, and select DLNA application on Droid X to start sharing media files. If you get the message to turn on Wi Fi connection, just click Yes and go to the settings menu to turn on Wi-Fi. <br /><br />Step 2. From the DLNA screen, select "Share media", and select the media (Video, Music, Picture) you want to play in the "My shared media" screen. Then click OK. <br /> <br />Step 3. Wait for a few seconds for <b>Connecting Motorola Droid X to TV based on DLNA</b>, and a green DLNA logo will appear at the top of Droid X screen for <b>Sharing movies and other media files to TV</b>. <br /><br />With the steps above, you can easily <b><a href="http://canon-videoconverter.com/2011/06/dlna-conversion-seamlessly-streamwatch-droid-x-videos-to-hdtv-through-dlna/">Connect and Watch Droid X video on TV through DLNA</a></b>. Hope it helps you play around your Motorola Droid X Android phone. <br /><br /><b>You may have interest in:</b> <br /><a href="http://www.aunsoft.com/put_and_play_movie_music_on_motorola_droid_x/">Put/play videos on Motorola Droid X</a>, <a href="http://www.aunsoft.com/best_droid_x_video_converter_convert_avi_to_motorola_droid_x/">Convert AVI files to Motorola Droid X</a>, <a href="http://www.aunsoft.com/best_droid_x_video_converter_convert_mkv_files_to_motorola_droid_x/">Convert MKV files to Motorola Droid X</a>, <a href="http://www.aunsoft.com/top_droid_x_video_converter_convert_vob_to_motorola_droid_x/">Convert VOB Files to Motorola Droid X</a>, <a href="http://www.aunsoft.com/convert_and_mount_videos_to_motorola_droid_x/">Mount Videos to Motorola Droid X</a>, <a href="http://www.aunsoft.com/stream_play_motorola_droid_x_videos_to_hdtv_via_dlna/">Stream Droid X Videos to HDTV via DLNA</a>, <a href="http://www.aunsoft.com/convert_videos_to_droid_x_verizon_gallery_for_playback_on_tv_via_hdmi/">Play Droid X Gallery Video on TV via HDMI</a>. <br /><br />Do you want to know more info about 2011 new smartphones and tablets? please enter <b>Aunsoft<a href="http://www.aunsoft.com/smartphones_and_tablet/">Smartphone and Tablet Column</a></b>.
tip
Mac iPad 2 Blu-ray DVD Ripping Software-Rip Blu-ray to iPad 2 iOS 5
Downscale BD/DVD video to 1280x720 for iPad 2 with H.264 MP4 <br />Transfer Blu-ray DVD Movies to iPad 2-Rip/Stream Blu-ray DVD Movies to iPad 2 compatible MP4 format<br /> <br />The Apple iPad 2 has been unveiled, which is dual core, front and rear facing cameras, an all new A5 dual core CPU and a nine times more powerful GPU. With up to 10 hours battery life, 720p HD video support, 9.7 inch large screen. With such a cool tablet, you will not miss enjoying high quality Blu-ray/DVD movie for travel. But you can not play Blu-ray/DVD on iPad 2 directly. So how to let your iPad 2 become your Blu-Ray/DVD player with ease? The only way is to rip your favorite Blu-Ray/DVD movie from Blu-ray/DVD disc and then <b><a href="http://www.aunsoft.com/imedia-converter-mac/">Convert Blu-ray/DVD movie to iPad 2 compatible MP4 format</a></b>. <br /><br />Aunsoft iMedia Converter for Mac as a <b>Ultimate Blu-ray/DVD to iPad 2 Ripper</b> is powerful tool to remove the AACS(up to MKBv24), BD+, region code from any BD/DVD disc and rip Blu-ray/DVD to iPad 2 720p H.264 file for enjoying. Now just follow this guide. <br /><br />It is obviously that Blu-ray/DVD movies can not play on your iPad 2, so you need first rip your Blu-ray/DVD movie from Blu-ray/DVD disc and then convert it to iPad 2 compatible format, after that, using iTunes to transfer or sync. <br /><br />Step 1: Please download for free at: <b><a href="http://membercenter.aunsoft.com/download/?s=dc7edd5bce66308e4a77b3a84b500faa&n=www.aunsoft.com/imedia-converter-mac/">iMedia Converter for Mac</a></b>, install and launch. <br /><br />Step 2: Add Blu-ray/DVD movies into this <b><a href="http://www.aunsoft.com/imedia-converter-mac/">Mac iPad 2 Blu-ray/DVD Ripping Software</a></b>. <br />Click "BD/DVD Rom", "BD/DVD Folder" icon to load Blu-ray/DVD movies. You also can click the "IFO/ISO" button to load the .iso ,.ifo image file from your Mac computer for conversion. <br /><br />Step 3: Select subtitle for hard-burn into iPad 2 movie and audio track. <br />Click on the dropdown list of "Subtitle" and "Audio" respectively to select your needed subtitle and audio track. <br /><br />Step 4: Select iPad HD Video MP4 as output format. <br />Click the downlist menu of "Format" to select <b>iPad &gt; iPad HD Video MP4 for iPad 2</b>. For comparing H.264 MP4 and MPEG-4 MP4, you will get higher quality by choosing H.264 MP4, which is currently the best used format for the recording with its high quality and maximum compression. And choose HD H.264 MP4 can let you enjoy HD movie effect.The <b>Mac iPad 2 iMedia converter</b> will <b>Downscale BD/DVD video to 1280x720 for iPad 2 with H.264 MP4</b>. <br /> <br />Step 5. <b><a href="http://panasonic-avchd-converter.com/2011/06/downscale-bddvd-video-to-1280x720-for-ipad-2-with-h-264-mp4/">Convert BD/DVD files to iPad 2 iOS on Mac</a></b>. <br />Click the convert button under the preview window, and the <b>Mac BD/DVD to iOS 5 iPad 2 converter</b> will start converting Blu-ray/DVD Movies to iPad 2 format in 720p. <br /><br />When the conversion is done, use iTunes to <b>sync and transfer the 720p videos to iPad 2</b>. Then you can <b>Watch/Play Blu-ray/DVD Movies on iPad 2</b>. <br /><br />Tips: With this iMedia Converter for Mac software ,you also can convert and put/play TiVo, MKV, VRO, EVO ,AVI ,VOB .ect videos on iPad 2.It is a perfect combination of a Mac Blu-ray Ripper, Mac DVD Ripper and a Mac Video Converter.
tip
Import and Convert Sony DSC-HX5V AVCHD MTS to Apple ProRes Codec MOV for Final...
After recording your holiday videos using for example Sony DSC-HX5V, it would be nice to make a great home movie for sharing with family & friends. Sony HX5V is able to record 60 fields-per-second videos at 1080i (1,920 x 1,080 pixel) resolution with Dolby Digital stereo audio, using AVCHD compression. <br /><br />Regarding editing camcorder footage AVCHD files from Sony HX5V, the latest FCP 7 and iMovie 11 claims to give full support for the format but many people have experiencing difficulties either with importing process or output files. <b><a href="http://www.aunsoft.com/final-mate-mac/">Aunsoft Final Mate for Mac</a></b> is released for Mac users to better handle camcorder footage in a much easier and quicker way: <br />- Capture AVCHD MTS/M2TS files from camcorder <br />- Merge/Split in Timeline and <b>Convert to Apple ProRes codec for FCP</b> <br /><br />Aunsoft Final Mate for Mac is highly recommended to Mac users who are experience enormous inconvenience with AVCHD, TOD & MOD files from HD camcorder. It helps you directly capture video footages from Sony DSC-HX5V and then <b>Convert to Prores 422 MOV or AIC MOV without rendering on FCP/iMovie</b> on Mac. <br /><br />Here is the step-by-step guide for you to <b><a href="http://www.aunsoft.com/mac_convert_sony_dsc-hx5v_avchd_mts_to_apple_prores_for_fcp/">Import and Convert Sony DSC-HX5V MTS to Apple ProRes for Final Cut Pro</a></b> on Mac OS X. <br /><br />1. Capture/Import Sony HX5V AVCHD files to Aunsoft Final Mate for Mac. <br />There are two ways to import videos to Aunsoft Final Mate for Mac: you can directly capture video recordings from camcorder to the program or you can browser videos from your computer. <br /><br />- Capture Sony HX5V AVCHD videos from camcorder. <br />Connect camcorder to computer via USB cable, and then launch Aunsoft Final Mate for Mac in Application folder. With built-in wizard, you can easily to capture mts video files from HX5V to the program. Select "Import" instead of Backup to quickly capture videos from camcorder. You can find imported videos under Camcorder tab in the main interface of Final Mate. <br /> <br />- Import Sony HX5V mts videos from computer. <br />If you have already backup all your video recordings from HX5V to your computer, you can browse your video path and the software will automatically show your AVCHD clips in Resource tab. <br /><br />2. <b>Merge Sony DSC-HX5V AVCHD files into one movie for conversion</b>. <br />Click the drop-down button of "Add Movie" icon and choose "For Conversion" to create a blank movie. <br /> <br />Once you've imported your video footage, drag and drop the video clips from Camcorder Tab (imported from your camcorder) or Resource Tab (imported from your computer) to the blank movie in Movies Tab. In this way, all video clips will be merged as one single movie for conversion. <br /> <br />3. <b><a href="http://www.aunsoft.com/final-mate-mac/">Convert Sony HX5V MTS files to ProRes Codec MOV</a></b>. <br /><br />Click the Export button and choose "Export into Editor". Follow Final Cut Pro&gt; Apple ProRes 422 HQ (*.mov) to choose export format for further editing in Final Cut Pro. Or you can also choose QuickTime Movie Format &gt; Apple Intermediate Codec (*.mov) for editing in FCE/iMovie. Click OK to start converting HX5V MTS files to ProRes MOV. <br /> <br />When the conversion process is done, you can directly <b><a href="http://sony-mts-converter.com/2011/06/import-and-convert-sony-dsc-hx5v-avchd-mts-to-apple-prores-codec-mov-for-final-cut-pro-on-mac-os-x/">Import the output ProRes MOV files to FCP for editing</a></b> and make your great home movies. <br /><br />You may also want to know how to <a href="http://www.aunsoft.com/mac_convert_sony_hdr-tg5v_avchd_to_apple_intermediate_codec-aic_for_fce-imovie/">convert AVCHD to Apple Intermediate Codec</a> for iMovie/FCE or <a href="http://www.aunsoft.com/mac_merge-join_sony_cx360v_avchd_without_conversion_for_playback_on_dune_hd_player/">merge AVCHD without re-encoding</a> to preserve original quality.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
409 questions posted
Top Sony Cameras Experts
W.L.
matt
matt
Darran Hatten
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
mac driver download panasonic dmcsz02k
  • Cameras
