20 Most Recent
Verge VGA300M Car Audio Amplifier Questions & Answers
Just got this at a sale for 10 dollars, not
First, boosting your original speakers is unreccommended, because the stock speakers are not made for a lot of power. The chances are, that if you hook that up to your stock speakers, you will blow the voice coil. Second, I would go to sonicelectronix.com for my connectors and power wires. They are a wholesale warehouse that have amazing deals on everything. Now lets get to the connectors you would need. You need a power and ground wire (recommend 4 gauge for that Amp). You will also need a a remote turnon wire, and a input cable (depending on your head unit.) Everything is pretty self explanitory when hooking it up, but if you need more help when it gets to that time, just email me, at
[email protected]
Connecting a subwoofer to a mono amp that has 2 sets of terminals
ok this gets confusing sometimes. Ok first look to see what ohm your subs are. If you have a dual 4 ohm sub When you run that on sub + to + and - to - then that will make that sub 2 ohm. its different on ohm if the sub is say a 8 ohm then putting the wires that way will bring that sub to 4 ohm. Now lets say you have 2 subs that are dual 4 ohm and wire both of them + to + and - to - and go bridge the amp which would be both wires from sub both + together and both - wired bridge on the amp will make it a 1 ohm to the amp. Please post what ohm your subs are and i can tell you alittle more about it
Jl 500/1 no sound
If all of your connections are correct you may have sustained damage to the driver amplifier that controls the subwoofer. If you have electronics experience and can get the schematic, you may want to trace the audio signal to see where it drops off. it is my guess that it will either a one of the pre-driver transistors, or at the main power driver MOSFET devices. In any event they will need replacing if they are bad. I don't they are bad because the light does not remain red so it might be on of the pre-driver transistors.
No sound
you may have a blown speaker...many cd decks will shut off their audio circuits when a speaker is blown to protect from shorting out. Go to the back of the deck and try disconnecting speakers one by one. You will have to turn the deck off and back on each time. Hope this helps!
Verge VGA300M Speaker terminals
Mono amps often have two sets of speaker outputs; this is just to simplify multi-speaker connections. The two positive and negative terminals are connected together internally, so they're effectively the same as one terminal. There's no difference between connecting both subs to the same positive and negative terminals, or using different terminals for each sub; electrically they'll all be connected together either way.
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
