20 Most Recent
Verge VMP508 CD Player Questions & Answers
Ebay is your best bet to find radio faces. Ebay.com and in the search bar type in the brand
Verge VMP508 CD...
Answered
on Dec 01, 2009
Wow I know its been a while but I can tell you how to change the clock on your radio. It can be done while the radio in on or off. To simplify this please turn radio off. The incorrect time should be displayed. There is a button that is the display (disp) located in the middle right of the face.( If for some reason the time is not displayed, press the disp button once or as many times needed until the time is displayed. Now let it go and continue from there.) Press and Hold this button down until the time begins to blink. Once it begins to blink let go of the disp button. Now the next button you are going to use is the 'skip' button (>>I) for the hr only and the (I<<) button for the min. You cannot go backwards only forward. You must observe the correct time of day or am/pm. The >>I and the I<< are far right and vertical to each other. Because one is for hr and the other is for min you can not go backwards only forwards. So hold down the hr button until it is the right am or pm and the right hr. The min is simpler since you don't have to worry about am or pm, just depress the button once it reaches the right mins in the hr. Hope this helps
Verge VMP508 CD...
Answered
on Oct 11, 2009
I am no way affiliated, but I get my car audio from Crutchfield and they have a HUGE range of adapters that come gratis with car audio purchase. However, you can get these adapters separately as I did when installing my wife's car audio. www.crutchfield.com.
Verge VMP508 CD...
Answered
on Apr 09, 2009
Mine was doing the same thing for a while. I put in one of those special CDs that have little tiny brushes on them that are used to clean the laser. And after that it worked. It still does it every once in a while, but not very often. It seems to like mp3 discs more than regular CDs. But be sure to DISABLE MULTISESION when you burn your mp3s. Otherwise it will DEFINATELY give you the error 2 message.
Verge VMP508 CD...
Answered
on Feb 28, 2009
Hey Guys ,
I was wondering if the solution given over here helped you. I am also having the same issue and my display is somewhat gone. It sometimes comes up on tapping the screen which makes me feel that the solution proposed over here could be of help.
Verge VMP508 CD...
Answered
on Aug 31, 2008
red is the hot wire black the negative orange or yellow the battery, the greens or blues or greys are the speakers the wires with a this thin black line are negative speaker
Verge VMP508 CD...
Answered
on Apr 06, 2008
go online to cicuit cty or look up online a store where they carrie that model they ussualy have a place wher u can input ur car model to see if it will fit
Verge VMP508 CD...
Answered
on Mar 29, 2008
i would go into one of those corner stereo shops.
Verge VMP508 CD...
Answered
on Mar 29, 2008
sounds like you dont have power to clock or memory wire (yellow)..also if it is a faceoff ..make sure contacts on both radio and face are clean ..
Verge VMP508 CD...
Answered
on Dec 16, 2007
manualy select the station you want, then press and hold the station pre set number on you unit for approximatly 5 seconds. job done
Verge VMP508 CD...
Answered
on Apr 24, 2007
You use the satellite tuner to change stations, not the head unit.
Verge VMP508 CD...
Answered
on Nov 02, 2006
The reason why your faceplate keeps on falling out for your car stereo is because that part needs to be replaced.
Car Audio &...
Answered
Yesterday
You need to unhook the speakers and try the power again. When the protection light comes on it either means that the speakers have to low of a resistance or are shorted or there is another issue with the power, We need to be sure it is not the speakers. If the light goes out, power it off and hook up ONE and try again then keep going till you find the bad one. You did not say what amp it is so that is all we can provide
Car Audio &...
Answered
Yesterday
Possibly a supply voltage is missing. Maybe the power switch is faulty, usually a MosFet switch on newer models.
Car Audio &...
Answered
3 days ago
