20 Most Recent FoodSaver Food Saver V3835 Vacuum Sealer Regular & Wide Mouth Jar Sealers Access Questions & Answers
Have the same problem. I'm looking for a solution too. The tray is dry and clean as a whistle. I cleaned all elect. connections and even dryed it all around with a hair dryer.
FoodSaver Food... | Answered on Oct 08, 2013
Did it ever work? Try another receptacle and if that doesn't make a difference you probably need a replacement.
FoodSaver... | Answered on May 03, 2020
Odds are it is dirty and the vacuum sensor is plugged. That makes it think the vacuum is complete. So it seals. Check the instructions or a youtube and clean it. You need to use the exact cleaning instructions. Odds are that will fix it.
FoodSaver... | Answered on Oct 21, 2019
Request from Foodsaver
FoodSaver... | Answered on Sep 12, 2019
Hi, if you go to YouTube, you will find a video showing you what to do,
I hope this helps
FoodSaver... | Answered on Apr 23, 2019
It is a heating element and heating elements fail. Contact the maker to see if they do spare parts. The only thing you can do is check the contacts on the end to make sure they haven't failed.
https://www.google.com/search?safe=off&ei=-AeQXLTWE-T45gKVh6CQCQ&q=foodsaver+vacuum+sealer+550+replacement+parts
FoodSaver... | Answered on Mar 18, 2019
NEEDS A NEW HEAT RIBBON WE DO NOT SELL THINGS OR MAKE THEM HERE
FoodSaver... | Answered on Feb 23, 2019
You can probably get one from the manufacturers web site.
FoodSaver... | Answered on Dec 22, 2018
Chances are that you foam gasket are not doing their job anymore. You can make a test by humidifying them with a paper towel. If it's works, you are due to replace them. They will usually last about 2 to 3 years depending on the use.
They are available through ebay or Amazon
FoodSaver... | Answered on Nov 26, 2018
The black foam seals are not doing their job anymore then. You may humidify them with a paper towel for a quick but it won't last. The vacuum sealer is expected to reach a certain level before automatically sealing it.
There is foam replacments available through ebay and amazon.
There's could be several elements to look into;
-is the vacuum still working or it stopped.?
.if it stopped without sealing chances are that the heating wire is broken.
if it's still try to vaccum, the seals probably not doing their and the expected vacuum levels are not reached.
To test that you can moister the foams seals with a paper towels.
If that worked, think about replacing the seals.
To deal with the sealing wire, you usually have to pull off a teflon tape to see it. I do believe that you can have a replacement for the wire. I personally never had to replace one.
bad heater element or debris on heat edges
FoodSaver... | Answered on Sep 03, 2018
Order the service manual directly from FoodSaver.
FoodSaver... | Answered on Jul 02, 2018
FoodSaver Food Saver V3835 Vacuum Sealer Regular & Wide Mouth Jar Sealers Access Logo
2 questions posted
Top FoodSaver Kitchen Appliances - Others Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Jim Busse
Jim Busse
Level 1 Expert
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • FoodSaver Kitchen Appliances - Others
Most Popular Question
tray full light go off tray empty
  • Kitchen Appliances - Others
