20 Most Recent
Avery 8168 Inkjet Labels Shipping Permanent 3-1/2inx5in 100/PK WE Questions & Answers
How to print only one sheet at a time not all sheets
This can be a little tricky. If you haven't used any of the labels yet, simply put the address in the first label and simply print. The printer will print the address on the first label and all you have to do is remove it and put it in place. Next time you need to make another label, set up the program that you are going to use to print the label and once the "Avery 8168 Inkjet" label is on your screen just move the cursor to the second label (With Corel WordPerfect just hold the ctrl key and hit the Enter key) and print your return label. Using this procedure you can use one sheet of labels without having to print all labels at once or using a new sheet.
Personal Label printer looks like
Labels are a common cause of printer jams. As the label paper goes
through the printer, it is not uncommon for a label to peel off and get
stuck inside the printer. Even a small blockage like a label can cause
the entire printer to jam.
if u dont have warranty u can try this method..... if u have warranty dont hesitate to call avery
Inspect the roller for label pieces. Manually remove any pieces that are stuck to the
rollers. If adhesive residue builds up on the roller, please visit web site at
www.avery.com/labelprinter for cleaning instructions.
if the label is jammed The Status Light Indicator is RED
or will not stop flashing.
• Remove any jammed labels.
• If the feeder is clear of a jam or debris, press the
Advance button to feed labels.
• Turn the printer off and on.
High volume printing, 20 continuous labels or more,
may cause the Print Head sensor to pause printing if
the Print Head gets too hot. If this occurs, the printer
will automatically resume printing, within minutes,
once the Print Head cools down.
if that doesnt help....
• Press the Advance button.
• Lift the Peel Lever (up) and press the Advance
button.
• Make sure that the labels are rotating over the top of
the Spool (inside top door).
• Make sure that the label roll is properly feeding
through the Print Head Opening.
• Remove the roll and check for jagged edges,
shredding or jammed labels.
Check for jammed labels or a blockage of the label
feeder. make sure the print head is also clean...... agaion i must insist that u try opening ur label printer only incase ur warranty period is over.. opening the printer while ur warranty period is still intact will void ur warranty
if u found my adice helpful.... kindly rate my service........
thank you
good luck and have a nice day
I can't get Avery 8160
Its possible that you are trying to use software designed for windows XP or such, Vista will not normally work with earlier software. Check to see if there is vista compatable software available.
