20 Most Recent Brother MFC 4600 Laser Printer Questions & Answers
hello
check you fuser kit if possible clean it with soft cloth it might be dirt on the fuser drum. and at the fuser drum you can see a small button with arrow you can slide this arrow to clean the fuser. if you clean the fuser and the printer still printing line on documents buy new fuser kit for your brother printer.
thnaks
Brother MFC 4600... | Answered on Mar 02, 2011
Your image drum most likely needs replaced. Oftentimes drums last about 3x longer than the cartridges but they do need replaced depending on how much the machine gets used. See if one is available from your local office supply store and it should help a lot!
Brother MFC 4600... | Answered on Mar 05, 2009
Some paper has torn or a part is broken, have a very good look for any loose bits of paper. Take the ink out if you need to. 90% chance you'll find a small bit of paper that's causing the rollers to resist and the printer to stop with the error.
Brother MFC 4600... | Answered on Nov 09, 2007
Here is the link to the manual; http://www.brother.com/E-ftp/info/mfc/mfc4600.html and here is the link to the driver downloads that i came across, in case you need them; http://www.brother.com/E-ftp/info/mfc/mfc4600.html Hope this helps :)
Brother MFC 4600... | Answered on May 18, 2007
4 Solutions of Brother Printer In Error State Windows 10:-
1. Beginning of all, you want to make sure that all the wires and joints of the printer are fit and don't have a loophole.
2. Make sure your machines connect correctly, try with Another USB port and the network or cable you use for the attachment has no problem.
3. Further, Switch off the printer and check for paper jams then close all trays accurately. If it has a paper jam gently remove it.
4. Verify if the printer is low on ink, refill it if it is. If you are using a WiFi printer, turn on the WiFi of the printer and the modem router.
The cause why you get this error state note on your Brother printer is either your printer is not connected perfectly, the printer jammed, low on ink, and any software changes. There can be other reasons as well, which can cause the problem of the Brother Printer In Error State Windows 10.
Full Blog - Brother Printer In Error State Windows 10
Brother MFC... | Answered on Aug 21, 2020
Download the file of flash9f.ocx https://unfitpc.com/flash9f-ocx fix the corrupt missing or invalid files in the system without facing the complication too much
Brother MFC... | Answered on Sep 27, 2018
brother print unable 1a
Brother MFC... | Answered on Aug 01, 2018
just simply remove purge unit on your machine then remove also cam sensor found on purge unit end clean by water.
Brother MFC... | Answered on May 20, 2018
The scanner bar & glass need cleaning with neat alcohol in very very small amounts, hope this helps...
Brother MFC... | Answered on Jan 25, 2018
Brother MFC 4600 Laser Printer Logo
6 questions posted
Norman  J Weimar Jr
Norman J Weimar Jr
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
mfc 4600
  • Office Equipment & Supplies
