20 Most Recent
Brother MFC 3220C All-In-One InkJet Printer Questions & Answers
clean the print head with water on a rag. it could need new cartridges also.
Brother MFC...
Answered
on Sep 26, 2012
Hi
If you open the cartridge door, the color coding is looks like violet color?. That is the magenta cartridge.
Brother MFC...
Answered
on Mar 18, 2011
where is the sevice button on the brother mfc665cw
Brother MFC...
Answered
on Jul 21, 2010
likely this is because Windows doesnt come with the drivers built in for your model of printer.
go here http://www.opendrivers.com/modeldriver/Brother_Printers_MFC-3220C-driver-download.html
or Brothers own website for their drivers - the link below is the portal page for your model printer;
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/model_top/colormfc/mfc3220c_eu.html?reg=eu&c=eu_ot&lang=en&prod=mfc3220c_eu
Brother MFC...
Answered
on Jul 11, 2010
Not good this is your printer head.
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Brother MFC...
Answered
on Apr 25, 2010
THE ERROR 41 INDICATES AN INCORRECT VOLTAGE COMMING FROM THE PRINTHEAD, THE PRINTHEAD WILL NEED TO BE REPLACED AND THE HEAD I.D. WILL NEED TO BE RESET, ALSO, BROTHER RECOMENDS THAT YOU CHANGE ALL OF THE INKS TO NEW INKS. THE RESETING OF THE HEAD I.D. CAN ONLY BE PREFORMED BY AN ATHORIZED BROTHER SERVICE CENTER. THIS REPAIR CAN NOT BE PREFORMED BY THE END USER. I HOPE THIS HELPS.
Brother MFC...
Answered
on Apr 11, 2010
Hi there
Brother MFC...
Answered
on Mar 01, 2010
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usuall y just after warranty has expired!
Brother MFC...
Answered
on Jan 10, 2010
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU!
Brother MFC...
Answered
on Aug 12, 2009
first, the error 41 will eventually come back sooner if not later.
error 41 means that your printhead is failing.
the error that its giving you now is that your black and cyan cartridges are empty. there are 4 colors in your prnter.
Brother MFC...
Answered
on May 31, 2009
Dont bother checking anything. It needs a new print head and 4 new
cartridges to prime it with. Call Brother and raise hell! there have a
been a huge amount of these head failures! a new head costs around
$100.00 but if you press brother will replace it. Including catridges it should come to around 150$
Brother MFC...
Answered
on Nov 06, 2008
