20 Most Recent
Zenith Z52Z95D TV Questions & Answers
My son purchased a rear
I HAVE A 48" REAR PROJECTION (SONY) THAT WAS PURCHASED IN 1997. IT FINALLY WENT OUT LAST WEEK. PARTS ARE NO LONGER AVAILABLE UNLESS YOU WANT TO PAY A HEFTY PRICE. I AM NOT GOING TO REPAIR MINE AS IT IS NOT AFFORDABLE TO DO SO.
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
How do I get the Zenith DVD player to work on a DVD/VCR combo
If you are trying to use the player and switch between DVD and VCR there is usually a button on the front of the player and a matching one on the remote.
VCRs are becoming very rare now so most TVs don't have the connectors for them. How old your TV is will control how you do this. Older HD TVs are fitted with a SCART connector, ( a large, chunky, rectangular connector with lots of pin holes), or RCA connectors, (3 round pin connectors coloured red, white and yellow).
*Note* Make sure you use the 'OUT' connectors on the VCR and the 'IN' connectors on the TV.
Some newer TVs will let you connect through a 'screw in' Satellite/'CABLE TV wire connector.
