20 Most Recent
Zenith Z32X31D 32" TV Questions & Answers
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
I need to get a
I'm sorry, but it appears that Zenith's support site is down. I'd suggest you wait and try again. If you really need to contact Zenith, you can do so at 1-877-993-6484.
Why my TV does not
Assuming that you don't even have a standby light on the led.
Here are some DIY steps that may help you fixing the problem.
- Check the power cord - check the cord it might be opened (no continuity).This is due to frequent bending and pulling.
- Check the internal fuse - sometimes the fuse fail because of the power surge, replacing with new one cure the problem. However if the fuse blew again then this is an indication that you have a shorted parts on the power supply. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
- If the fuse is intact then you have a faulty in the power supply or on the load. You might have an open fusible resistor,open volt regulator ic, shorted H-out IC.
The #3 should be done by an expert or qualified technician because isolating the problem on the regulator section is technical.
But first check if the unit is under warranty then avail it because the manufacturer will fix it for you for free or a little charge only.
Have a nice day!
Thanks for using fixya.
Everthing won't be completely shown on my
It sounds like you have the picture"ratio" set or adjusted wrong, find the button on your remote labeled "ratio","format","wide" any of those,then just press the button multiple times until you get the full picture that you are looking for. If you have digital cable or satellite those receivers also have picture format adjustments in their menu system that need to be set for your type of TV screen(wide 16:9 or standard 4:3). If you need help, your cable company or satellite provider can assist you with info. Good Luck ! P.S. don't forget to refer to your owners manuals.
PIP change
you can change the channel of the small screen .just read the user manual of your tv.to your problem is only in the remote control
Zenith 32" NO audio
it is likely the audio amplifier is defective.have your technician replace the audio amplifier IC.
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
