20 Most Recent Zenith Z25X22S 25" TV Questions & Answers
Since you had been started that fixing,,you may try replacing some electrolytic capacitors near on that vertical IC?..,Dods
Zenith Z25X22S... • Answered on Sep 28, 2013
if you are conected via an RGB or an RGBHV cable, check that one of the R (red), G (green) or the B (blue) is short it.
Zenith Z25X22S... • Answered on Jan 16, 2013
need code for a 1997 Z 25 X 22S Zenith TV .
Have the remote , bought used tv , but remote is not working . It has a prgram buttom on top left of remote
Zenith Z25X22S... • Answered on Mar 15, 2011
many new TV's having vertical hold most of the case you need service mode to change the setting
Zenith Z25X22S... • Answered on Aug 27, 2010
you have to change color system of dvd(ntsc, pal,) normally dvd remote will p/n button..press it to change color system,,otherwise u have to change color system of ur tv
Zenith Z25X22S... • Answered on Mar 15, 2010
The converter box simply installs between your Antenna and your TV (tune to channel 3 or 4) http://digitaltips.org/docs/FlosTips.pdf
A dvd that does not Record is designed to simple install into a separate Input connection on the TV (do you have a VCR/DVD combo?)
Do you have an older TV with only one "Input" for a cable connection? (no Red/Yellow/White Inputs) if yes you may need to take a trip to Radio Shack
Zenith Z25X22S... • Answered on Mar 12, 2010
Most original remotes are non-programmable. I would get universal for $5-10
Zenith Z25X22S... • Answered on Jun 11, 2009
This is a problem with the vertical circuit. If you can solder, you should be able to fix this. With teh unit unplugged, open up the back and locate the vetical IC. This should be a small flat IC attached to a heatsink with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering hte pins. If that fails to resolve the problem, replace the IC. I will look up your specific model and try to get more details.
Dan
Zenith Z25X22S... • Answered on Sep 16, 2008
check the crt cap that is connected to your picture tube...it may be greenish inside...try to change the crt...and adjust the focus...
Zenith Z25X22S... • Answered on Sep 03, 2008
On the inside of the TV, there will be a knob with a RED cap on it, labeled vertial position. (it actually looks like a variable inductor)
With an allen wrench (possible 1/4) give it a half turn in either direction and see what happens. On the Z25x22S model, the vertical and horizontal position adjustments should be right next to eachother, but on the model i worked on, there was no variable pot for the horizontal position.
Hope this helps!
Zenith Z25X22S... • Answered on Aug 12, 2008
TRY TO USE RF CONVERTER
Zenith Z25X22S... • Answered on Jul 06, 2008
how is the 200 volt supply to the video output transistors??
measure the collector voltage of the video output transistors with the crt board on and off the crt. if voltage goes up when crt board is off then crt shorted
Zenith Z25X22S... • Answered on Apr 30, 2008
I cleaned a terminal inside my remote. It worked. I simply pushed 2, then Enter,
3, then Enter. I clicked Menu, scrolled down to Auto Demo, clicked arrow pointing right, and then entered "Off". Everything is solved.
BevN
Zenith Z25X22S... • Answered on Feb 26, 2008
on your remote there is a menu button press that and do a channel search it should fix the problem
Zenith Z25X22S... • Answered on Feb 16, 2008
as you say that it is old tv so there is a possibility that there may not be audio video socket where dcd player can be connected. OR You will have to purchase one video RF converter.RF converter contains one video input in yellow color & two audio input in red & white colour & one cable connector as output. Connect the dvd output to this converter & tune tv program in which place you receive dvd signal.
Zenith Z25X22S... • Answered on Dec 06, 2007
How old is the set? If picture is really very blurry, Try adjusting 'focus'. You can find this conttrol generally at the rear of the set. Otherwise,. if you know solid state electronics, Check the Focus control on the FBT. It is also possible that the CTR Base is faulty. Replacing this helps.
Zenith Z25X22S... • Answered on Apr 05, 2007
A common practice in the TV industry is to include the size in inches in the model number. Often, a model will be made in different sizes, for example, z42pj240 may have a z50pj240 family member. They will use the same main circuit boards and remote controls. Check the list in your universal remote control manual for a variant like that.
Zenith Televison... • Answered on Mar 29, 2021
Televison & Video Logo
23 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
dvd viewing shows in black white
  • Televison & Video
