20 Most Recent
Oakley Thump Pro Sunglasses Questions & Answers
Can't load more music on thump pro
Run the batteries completely dead, then recharge them again. If that fails, check the manufacturer's website for a firmware or driver update.
Oakley thump pro speaker repair
You can't purchase parts for these units,you maybe able to send it to oakley to have it repaired. They will do repairs on them unlike the Orkr pros that use Motorola electronics and won't be serviced by Oakley at all.
Oakley dart replacement lens
Hi
I have seen this many times with this same pair of glasses. The lens is defective however Oakley only has a one year warranty so unless you can provide Proof of purchase there is not much they will to for free. You should be able to obtain an RA# and send your glasses in for lens replacements.
Need a batteryu for my O ROKR Bluetooth sunglasses
Hi I'm not sure if you have found the battery yet..but they are available on eBay. You need to know that this is a on going problem with this product and in most cases won't fix the problem. In most cases its the ribbon inside the left side thats become corroded and has failed. I had 2 pair that did the same thing and Oakley said the same thing ...SORRY WE DON'T REPAIR O ROKRs.TRY TALKING TO MOTOROLA. then motorola said talk to Oakley. It was a classic case of pass the buck.I think this problem led to Oakley discontinuing sales of the O ROKR line of bluetooth Sunglasses. They were just to sensitive to sweat damage as they weren't sealed to well.
Is there anyway to tighten my Oakley hinjinx
I' ve never heard "hinjinx" before and even did not find it in my dictionary, but I suppose you mean the hinges and synthetic temples of the sunglasses. I would advise you to go to an optician who will bend the synthetic temples using hot air, so that they get tighter and hold better without hurting you behind the ears. This service should be provided free of charge.
In case the temples are metal with synthetic tip ends, the optician also can bend them to fit exactly the way you want. ( free of charge )
Oakley screw fell out
1. PLACE THE FRAME ON A FLAT SURFACE WITH THE SCREW HOLE FACING UP.
2. TAKE THE SMALL SCREWDRIVER AND INSERT THE REPLACEMENT SCREW INTO THE HOLE.
3. TURN THE SCREWDRIVER CLOCKWISE TO TIGHTEN THE SCREW UNTIL IT IS SECURE.
4. ONCE THE SCREW IS IN PLACE, MAKE SURE IT IS TIGHT ENOUGH TO HOLD THE FRAME TOGETHER.
3/28/2024 10:20:58 AM •
Clothing...
Answered
6 hours ago
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding
3/8/2024 1:22:32 PM •
Clothing...
Answered
on Mar 08, 2024
