20 Most Recent
Versace VE 4157 Sunglasses Questions & Answers
I want to know what
Frame Size: 65MM 17MM 125MM
Typically there will be three standard numbers imprinted on one of the temples or the bridge, indicating respectively the sizes of three frame parts. All sizes are marked in millimeter.
1. Lens size:
The first number 65 represents the lens size, which is also called eye size or lens width. Lens width is the most exact name of this size, describing precisely the distance between the vertical sides of a rectangle containing the lens shape. It is important to differentiate it from lens height. A large lens for a big guy usually has big sizes at both dimensions.
2. Bridge length:
The second number 17 represents the bridge size. Other sayings include bridge length and bridge width. In detail, it is the minimum horizontal distance between the nasal surfaces of the rims. This size varies only slightly because people's noses will hardly differ significantly. When the frame is sitting too high on the face, it is necessary to increase this bridge size. In opposite, a shorter bridge is needed when the frame sits too low on the face.
3. Arm length:
The third number 1125 describes the length of an arm or temple. This is the whole length of a temple, consisting of the length to the bend and the length of the drop.
Broken sunglasses
Depending on how they broke, us can use very strong glue or you can get a replacement piece, but more is needed to know exactly.
Oakley screw fell out
Here are a few steps you can take to address this issue:
Tighten Existing Screws: First, try tightening the hinge screws. Use a small, flat-head screwdriver to remove the rubber screw cover located on the hinge area. Then gently tighten the screws that hold the hinge in place. Be careful not to over-tighten them, as this can strip the screws.
Check for Replacement Screws: You can search for replacement screws specifically designed for Oakley Tie Breaker sunglasses. Some online retailers offer Oakley replacement screws that can help fix the problem. Look for screws that match the original ones in terms of size and design.
Sunglass Repair Kits: Consider using a sunglass repair kit. These kits often include various sizes of screws and tools for repairing sunglasses. You might find a suitable replacement screw in one of these kits.
Remember to handle the screws carefully and avoid overtightening. If you're unable to find a replacement screw, reaching out to Oakley customer service.
4/20/2024 10:49:19 PM •
Clothing...
Answered
3 days ago
What do you pack in your purse?
Here are list of things you can carry in your purse:
A makeup bag. I do my makeup on the go a lot, so a makeup bag is necessary for me.
A pair of earrings / jewelry.
Hair ties and bobby pins.
A hair brush.
A notebook / sketchbook.
A pen and a pencil.
Pack of tissues.
4/17/2024 7:09:47 AM •
Clothing...
Answered
on Apr 17, 2024
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
4/17/2024 7:05:52 AM •
Clothing...
Answered
on Apr 17, 2024
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding
3/8/2024 1:22:32 PM •
Clothing...
Answered
on Mar 08, 2024
Are you searching for Handcrafted Polki Jewellery in India?
Polki jewellery is a traditional Indian jewellery style that uses uncut diamonds in its designs. It is a popular choice for weddings and special occasions. There are many Indian jewellery designers and brands that offer handcrafted Polki jewellery, both online and in physical stores. Some popular options include Sabyasachi, Amrapali, and Tanishq.
2/25/2023 9:53:01 AM •
Clothing...
Answered
on Feb 25, 2023
