20 Most Recent
Zenith A36B41W 36" TV Questions & Answers
lost red colour means red gun is not working pls try to check resolder red driver ic in the neck board
Zenith A36B41W...
Answered
on Aug 27, 2010
See this link:
http://www.zenithservice.com/index_b2c.jsp
According to the specs page for this TV, it weighs 144 lbs.
Zenith A36B41W...
Answered
on Aug 16, 2010
Check the fuse inside the TV. If fuse blows, there is a problem elsewhere.
The initial spark you are mentioning is due to degaussing coil. This is not routed through fuse.
Zenith A36B41W...
Answered
on Apr 07, 2010
I suspect the high voltage portion of your power supply is starting to fail.
Normally, I would expect this kind of repair to be performed by a professional in a shop senerio.
There could be other causes and you will probably received several alternative view points here.
Thanks for using fixya.com
a
Zenith A36B41W...
Answered
on Oct 25, 2009
your problem is due short circuit in horizontal section of tv
your problem & smell is due to horizontal section failure.
in that section
1 flyback transformer & horizontal output transistor might be faulty.
but remember to check power supply is normal other wise it may fail again.
for skilled technician it is not a major problem &easy to fix at fair cost.
good luck.
Zenith A36B41W...
Answered
on Sep 07, 2008
tv repairman came to house with a wrapped cable demagnetizer, plugged it into the electrical outlet, waved it around in front of the tv screen, and the color returned to normal. Sounds magical, but that's exactly what happened to correct the color, and it has remained perfect since then
Zenith A36B41W...
Answered
on Jun 20, 2008
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Zenith A36B41W...
Answered
on Jun 04, 2008
There is a coil in the set with a magnet glued to it, called the horizontal linearity coil. Sometimes the coil "sings", making a squeeling sound. I have seen this many times, and there really isnt anything actually electrically wrong with the set. To stop the squeeling the coil should be replaced.
Zenith A36B41W...
Answered
on Jun 26, 2007
First thing to dois unplug the set for a GOOD 24 hurs
Zenith A36B41W...
Answered
on Sep 14, 2006
First thing to do is take out the batteries out of the remote. Did it stop? Yes? Replace the remote control. Did not stop? Ok unplug the set for at least 3 to 4 hours. Did it stop? Good! No? It did'nt Stop? You have a problem with the Display Ic, and thats all built into the Microprocessor IC circuit. You will need to call in a pro to assit you with this repair, as there are no user serviceable parts inside of these sets. good Luck
Zenith A36B41W...
Answered
on Aug 05, 2006
A common practice in the TV industry is to include the size in inches in the model number. Often, a model will be made in different sizes, for example, z42pj240 may have a z50pj240 family member. They will use the same main circuit boards and remote controls. Check the list in your universal remote control manual for a variant like that.
Zenith Televison...
Answered
on Mar 29, 2021
If you are trying to use the player and switch between DVD and VCR there is usually a button on the front of the player and a matching one on the remote.
VCRs are becoming very rare now so most TVs don't have the connectors for them. How old your TV is will control how you do this. Older HD TVs are fitted with a SCART connector, ( a large, chunky, rectangular connector with lots of pin holes), or RCA connectors, (3 round pin connectors coloured red, white and yellow).
*Note* Make sure you use the 'OUT' connectors on the VCR and the 'IN' connectors on the TV.
Some newer TVs will let you connect through a 'screw in' Satellite/'CABLE TV wire connector.
Zenith Televison...
Answered
on Nov 20, 2020
1) tune the desired station frequency
2) while the frequency is being displayed, quickly press the memo set/clock adjust button.
3) press the desired preset button
4) press the memo set/clock adj button again
5) the station will be stored
Zenith Televison...
Answered
on Apr 24, 2020
