20 Most Recent Polaroid 8-Inch Android 4.0 4 GB Internet Tablet with Capacitive Multi Questions & Answers
Settings for a tablet are rather basic. What you really need to know are the details of Android OS
Have manual and android tutorial here:
http://thevillagescomputerclub.yolasite.com/resources/PresentationsMTG/Beginners/Android_Tablets_For_Dummies.pdf
http://www.southerntelecom.com/polaroidsupport/downloads/pmid701c.pdf
Polaroid 8-Inch... | Answered on Jan 16, 2020
You cannot as it is on their end of the web and all you can do is decide to proceed or not
Polaroid 8-Inch... | Answered on Jan 01, 2016
There probably is an upward-facing arrow on the keyboard which you press to shift.
Polaroid 8-Inch... | Answered on Nov 19, 2015
Hi, I've had 2 of these before i got rid of them. I had to get my friend whose great with computers go in from his pc to open mine, so i could wipe the data before returning. If you call polaroid.com they can give you the steps to do this. Unfortunately it is fried, it may work awile after you get it open, but mine didn't. Hope this helps . I also found out this tablet is a starter tablet like something you buy for your kids 1st tablet. Good luck. JMF
Polaroid 8-Inch... | Answered on Jul 19, 2014
you need an addtional sd card to store your data. can use up to 32 GB micro SD card.
Polaroid 8-Inch... | Answered on Jun 06, 2014
Hi, My guess is that you don't have enough memory to hold any more data. Or the memory is bad and has to be replaced. Good luck.
Try holding the power button until it shuts off or prompts you to power off. If that doesn't work, try locating a reset button, if it has one, and press it with a pin or other small object. It can then be restarted and be back to normal.
Polaroid 8-Inch... | Answered on Jan 23, 2014
  1. Press your device's Home button.
  2. Press your device's Menu button.
  3. Tap Settings (or System Settings).
  4. Tap Application Manager (or Apps).
  5. Scroll to find the app you want to clean up, then tap the app icon.
  6. Tap Force Stop.
  7. Tap Clear Cache. Try using the app again to see if it's working fine.
  8. Still experiencing a problem? Go through steps 1-6, and then tap Clear Data.
    • Clearing the app data will remove any custom options and settings.
Polaroid 8-Inch... | Answered on Dec 02, 2013
Is there a 'reset' pin hole in the back by any chance? If so, gently insert the end of an opened paper clip into the hole and push in until you feel a button being pushed. Hold it there for about 10 seconds and then release. Your tablet should reset and start again.
Polaroid Tablets... | Answered on Jul 27, 2020
Polaroid 8-Inch Android 4.0 4 GB Internet Tablet with Capacitive Multi Logo
Popular Tags
49 questions posted
Top Polaroid Tablets & eReaders Experts
John mullen
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Tablets & eReaders
Most Popular Question
get operators manual
  • Tablets & eReaders
