20 Most Recent Zenith A27A23W 27" TV Questions & Answers
manual
I cant get a pic w my satelite
Should go to coax fitting depending on output from sat---if there on catv and usually channel 3 or 4 whatever sat is set to out.Via the audio/video out to the same in on the set it goes to video.
11/5/2012 6:46:04 PM • Zenith A27A23W... • Answered on Nov 05, 2012
Zenith tv, model #b27a11z. My remote stopped
Hi Keith,First of all, thank you for posting your question here at Fixya.My first advice is to confirm if the remote control is not the issue here and ensure that the fault came from the TV itself. Point directly your remote control's infrared emitter(Sensor) to your cellphone camera and then press any button key at the remote control, you will be able to see the flash of an infrared through your camera if the remote control is working fine. Watch the video below to have an idea how you gonna do this.If you've confirmed that the remote control is not faulty, this is an indication that the problem is on the infrared receiver inside the TV. I would advice you to clean the TV's front panel infrared lens using a soft cloth, keep away all obstruction from the IR receiver, turn of the bright light in the room and check if the symptoms still persist. If yes, then the IR receiver inside the TV is already faulty and needs to replaced with a new one.mjsazon
1/21/2012 1:43:38 AM • Zenith A27A23W... • Answered on Jan 21, 2012
Tv sounds like it turns
You have several bad capacitors in your TV. There are in the deflection side of the board. I think there are three here. And check the vertical section, as there are three bad caps. You will need an ESR meter to find and replace these capacitors. The older Zenith are known for shut down due to weak and bad caps. Hope this clues you into the fix. Thanks for asking and show a few hands of support!
3/14/2011 10:08:34 PM • Zenith A27A23W... • Answered on Mar 14, 2011
Unable to turn off set up menu
go unplugg the tv and turn it on and bam fixed
4/8/2010 7:27:32 PM • Zenith A27A23W... • Answered on Apr 08, 2010
My tv popped last night ,then shut down with an
That's not a good sign. There are a number of parts in any TV that can put on quite a show when they fail. In many Zenith models, picture tube failure can cause this when high voltage gets back onto the circuit board. The glow you mentioned, if it was on the screen, is one symptom of such a failure.
Having this repaired is uneconomical. Labor alone may be $60 or more (I'm sure it will be...our shop charged that for a complex repair when I left the service business almost 10 years ago) and then you need parts. The repair bill could easily approach replacement cost, especially if it is the picture tube (and then it would cost more to repair than replace).
Use this as an excuse to treat yourself to a new TV. There's almost always a sale somewhere on small flat-screen models.
2/3/2010 1:57:53 PM • Zenith A27A23W... • Answered on Feb 03, 2010
2answers
Zenith A25A23W 27"
the code I found is 177
2/28/2009 6:37:35 PM • Zenith A27A23W... • Answered on Feb 28, 2009
4answers
Color mostly green
Sounds like tyo me that the picture tube is getting soft on ya!!. Its a common factor that occours with all tvs but mostly with zenith. A service tech might be able for a small fee rejuvinate the picture tube but theres never a warrantee with this type repair. Its not something a user should attemp to do as theres hi voltage inside this set even on the tube socket after its ubplugged for awhile. Seek the advise of a repair pro to see how bad the tube is. Good Luck
12/27/2008 7:54:42 AM • Zenith A27A23W... • Answered on Dec 27, 2008
A27A23W TV key circuit board
the keyboard on this is no longer available from what I see, here is the correct part number for assy. F-52954
12/3/2008 5:07:57 PM • Zenith A27A23W... • Answered on Dec 03, 2008
Tv picture is green
YES I HAVE HAD THIS TWICE AND NOW THEY TELL ME THAT THE CARD CAN NOT BE REPAIRED AGAIN. THE CARD HOOKS TO THE BACK OF THE PICTURE TUBE. I CAN NOT FIND A REPLACEMENT SO PUT IN THE TRASH.
7/28/2008 11:03:09 PM • Zenith A27A23W... • Answered on Jul 28, 2008
Hooked to cable...says no channel found
how old is this set? there were some certain years the auto matic scan didn't work, you must enter them under the manual way.
11/20/2007 4:56:27 AM • Zenith A27A23W... • Answered on Nov 20, 2007
Zenith A27A23W 27 Capacitor CX 3231 blew up
The little blue caps that burn up are 560pF 2KV caps
6/26/2007 6:03:56 AM • Zenith A27A23W... • Answered on Jun 26, 2007
Tv blew up
sounds like the typical power supply or sweep problem in the zenith chassis. depending on how old this set is will determin if its even worth trouble shooting or taking it in to be looked at by a pro. If your not experienced with tv repair i would call a repair shop or take it in as tv sets have high voltage stored in them even after they have been unplugged for a while. If youve tinkered with tvs in the past or know someone who does zenith tvs are made for a complete chassis exchange. you can Call PTS Corp at 1 800 844 7872 and see how much an exchanged referbished chassis would cost and go from there. Good Luck
5/24/2006 11:04:18 PM • Zenith A27A23W... • Answered on May 24, 2006
PLEASE, PLEASE HELP IF YOU
Whats the model number of your Zenith and I will try to locate a owners manual for you.
1/4/2024 2:58:37 AM • Zenith Televison... • Answered on Jan 04, 2024
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue: Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly. Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate. Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs. Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components. If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
3/19/2023 2:53:59 PM • Zenith Televison... • Answered on Mar 19, 2023
Zenith VR4206HF VCR Very Slowly Loads/Unloads Tape
eject motor weak or dirty
11/5/2022 4:21:46 AM • Zenith Televison... • Answered on Nov 05, 2022
I have a Zenith zp505 universal remote(silver w/out a code search botton) . I need the manual and codes for 4 digit codes
I have a sony bravia TV(MODEL:KDL50R550A) I dont know How to reprogram my ZP505 ZENITH Universal 5in1 remote control to it.
9/26/2022 5:02:53 PM • Zenith Televison... • Answered on Sep 26, 2022
My Zenith dvd vhs combo model number xbv 443 dvd tray won't open
you might have to initiate the tray opening mechanism and as it's trying pry the tray forward and force it open it might fix it.
9/18/2022 4:34:41 PM • Zenith Televison... • Answered on Sep 18, 2022
Televison & Video Logo
Popular Tags
16 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
unable turn off set up menu
  • Televison & Video
