20 Most Recent Zenith A25A11D 25" TV Questions & Answers
Check for power supply failure.
Zenith A25A11D... | Answered on Sep 02, 2017
Ok that tells me something is wrong with the source of the video and sound then. What is the source you are trying to play? Is it coming from a cable / satellite box? For example can you get a DVD to play just fine on the TV? That would be a different source...
Thanks please let me know, just reply to my answer here and I can help you out.
Tim
Zenith A25A11D... | Answered on Nov 05, 2010
Sorry, I miss-read this post. I orginally thought it said your cable broke, meaning the coax that went to the back of the TV.
The coax input is more than likely a part of the main board. I am not a tv expert but as with laptops and input modules that break you have to soder the peice on or replace the whole board.
Easier to switch to a/v inputs as mentioned in Solution #1.
I could not find a spec sheet for your model but did find this for you to give you an idea on what is entailed in replacing a broken RF connection. This may or may not apply to your model, but here it is anyway.
http://www.youtube.com/watch?v=S9v-dUyzdrk
I would suggest letting someone who is qualified in TV repair fix it.
Here are the service manuals for your Zenith. Download both and then extract to your desktop for easy access. I downloaded and extracted myself to make sure it was a working copy so you are good to go.
Part 1:
http://www.eserviceinfo.com/download.php?fileid=34271
Part 2:
http://www.eserviceinfo.com/download.php?fileid=34270
Good Luck!
Zenith A25A11D... | Answered on Nov 10, 2009
If this model has a/v inputs you could use them and if you're on cable (direct cable not cable box) you could use a vcr to change channels - or you could remove the tuner and resolder the "cable plug" (RF connector) if it didn't crack the tuner circuit board when it came off.
try one of these, 10017, 10463, 11265, 10178, 10092
Zenith A25A11D... | Answered on Aug 08, 2009
Alot of Zeniths have menu for that, have you tried to press the channel up button?
Zenith A25A11D... | Answered on Jan 26, 2009
Hi, If you are comfortable working with a soldering iron, a continuity (VOM) multi tester and a fair knowledge of electronic components, then perhaps you can repair the missing color red. You have to open the unit, expose the small printed circuit board that is attached to the small end of the picture tube. There will be many components present but you will need to focus yourself on three (3) transistors that are bigger than the others sometimes with an aluminum heatsink. It is also possible that instead of 3 transistors you will have one power IC. In any case these control and provide the drive for the 3 colors of your picture tube: red, green and blue. One of them is either dead or suffers from cold solder to any or all of its pins/legs. You have to visually inspect the solder joints of these big transistors/IC and determine if any is dull in color, loose of simply not connected. You may even try the shotgun approach and solder each of the pins/terminals/legs just as long as you don't cross solder creating a short between pins/legs. If this works, you're set, if not: You have to check with the use of the VOM and determine which of the 3 transistor is defective. If you are familiar checking continuity of base to collector to emitter and reverse, again you're set, if not perhaps you check all three and compare which have the same reading from the same position and which is different. Pls keep in mind the transistors have forward and reverse bias readings. If able to determine defective component, desolder, replace and solder. If it were an IC, replace the entire pack. If the above would make you uncomfortable, pls ask for the services of a qualified TV repair man and explain your problem. Hope this works out for you and give you some ideas. Pls post again how things turn up, good luck and kind regards.
Zenith A25A11D... | Answered on Aug 12, 2007
https://www.manualsparadise.com/ShowProductsForModel.do?model=M25715316 they have service manual and schematics - sorry had no luck with a free one but the prices aren't too bad. Hope this helps :)
Zenith A25A11D... | Answered on Mar 13, 2007
1) tune the desired station frequency
2) while the frequency is being displayed, quickly press the memo set/clock adjust button.
3) press the desired preset button
4) press the memo set/clock adj button again
5) the station will be stored
Zenith Televison... | Answered on Apr 24, 2020
To set the Alarm press the Alarm Set button then use the set buttons on top change the Alarm time. Use the to change the Alarm time, when the Alarm time is set press and hold enter until you hear a beep. Press the Alarm On/Off button to select radio or buzzer for the alarm or alarm off.
http://portablemedia.manualsonline.com/support/zenith/clock-radio/zenith-1233a-how-do-you-set-the-time-on-the-clock-4514622
Zenith Televison... | Answered on Apr 23, 2020
Digit Zenith TV Converter Box Remote Codes
212
254
267
357
454
457
557
657
757
857
955
957
991
4 Digit Zenith Converter TV Box Remote Codes
1415
9910
5 Digit Zenith Converter Box TV Remote Codes
01414
51415
Zenith Televison... | Answered on Apr 22, 2020
No, the Zenith XBV443 can not record a VHS tape to DVD. This unit is a DVD Player/VCR recorder. It doesn't have the ability to burn data/files to disc. The manual is available at ManualsLib: https://www.manualslib.com/manual/267291/Zenith-Xbv-443.html . The DVDs that it can play are limited: https://www.manualslib.com/manual/267291/Zenith-Xbv-443.html?page=5#manual .
I wish that I had better news for you.
Zenith Televison... | Answered on Jul 23, 2019
Not available. All scam sites
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&ei=ZQjzXOHIDoHu_QaijLTgDQ&q=zenith+z711b+manual
Contact Zenith direct
Zenith Electronics LLC
2000 Millbrook Drive
Lincolnshire, Illinois 60069
(847) 941-8000
Licensing
Jack Kail, [email protected]
Broadcasting Standards and Technologies
John Taylor, [email protected]
Media/Press Inquiries
Kim Regillio, [email protected]
Consumer Inquiries
Zenith/LG Customer Service, 800-243-0000
Click here for online Zenith customer service support
https://www.zenith.com/contact-us-2
Zenith Televison... | Answered on Jun 01, 2019
Televison & Video Logo
11 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
zeneth a25a11d 25 tv broken cable
  • Televison & Video
