20 Most Recent Zenith IQB36B42W TV Questions & Answers
It sounds like you have problem with the switch on the tv itself. try opening the front panel where switch is located and check wiring or maybe change the switch which you can get it online.
Zenith IQB36B42W... • Answered on Jul 27, 2007
Open the TV amd turn it on in a position you can see the picture, possibly through a mirror. Now gently tap all of the metal heat sinks on the circuit board until you find the one that is sensitive it will have a small chip mounted vertically on it, with probably like 7-10 pins. The number on the chip will most likely be an "LA****" number. Now turn the circuit board (UNPLUG FIRST) over and resolder the pins. This is your problem 99% of the time. Be very careful there is High Voltage inside this TV.
Zenith IQB36B42W... • Answered on Apr 26, 2007
A common practice in the TV industry is to include the size in inches in the model number. Often, a model will be made in different sizes, for example, z42pj240 may have a z50pj240 family member. They will use the same main circuit boards and remote controls. Check the list in your universal remote control manual for a variant like that.
Zenith Televison... • Answered on Mar 29, 2021
If you are trying to use the player and switch between DVD and VCR there is usually a button on the front of the player and a matching one on the remote. VCRs are becoming very rare now so most TVs don't have the connectors for them. How old your TV is will control how you do this. Older HD TVs are fitted with a SCART connector, ( a large, chunky, rectangular connector with lots of pin holes), or RCA connectors, (3 round pin connectors coloured red, white and yellow). *Note* Make sure you use the 'OUT' connectors on the VCR and the 'IN' connectors on the TV. Some newer TVs will let you connect through a 'screw in' Satellite/'CABLE TV wire connector.
Zenith Televison... • Answered on Nov 20, 2020
1) tune the desired station frequency
2) while the frequency is being displayed, quickly press the memo set/clock adjust button.
3) press the desired preset button
4) press the memo set/clock adj button again
5) the station will be stored
Zenith Televison... • Answered on Apr 24, 2020
To set the Alarm press the Alarm Set button then use the set buttons on top change the Alarm time. Use the to change the Alarm time, when the Alarm time is set press and hold enter until you hear a beep. Press the Alarm On/Off button to select radio or buzzer for the alarm or alarm off. http://portablemedia.manualsonline.com/support/zenith/clock-radio/zenith-1233a-how-do-you-set-the-time-on-the-clock-4514622
Zenith Televison... • Answered on Apr 23, 2020
Digit Zenith TV Converter Box Remote Codes
212
254
267
357
454
457
557
657
757
857
955
957
991
4 Digit Zenith Converter TV Box Remote Codes
1415
9910
5 Digit Zenith Converter Box TV Remote Codes
01414
51415
Zenith Televison... • Answered on Apr 22, 2020
No, the Zenith XBV443 can not record a VHS tape to DVD. This unit is a DVD Player/VCR recorder. It doesn't have the ability to burn data/files to disc. The manual is available at ManualsLib: https://www.manualslib.com/manual/267291/Zenith-Xbv-443.html . The DVDs that it can play are limited: https://www.manualslib.com/manual/267291/Zenith-Xbv-443.html?page=5#manual . I wish that I had better news for you. Cindy Wells
Zenith Televison... • Answered on Jul 23, 2019
Zenith IQB36B42W TV Logo
5 questions posted
Top Zenith Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
tv turn
  • Televison & Video
