20 Most Recent
Propellerhead Reason 5 Educational Version Software Synth for Mac Questions & Answers
My reason 5 was working
Hello.
First of all try restarting your computer if you haven't yet and see if everything will be back to normal.
If you are still having the problem, tell me what OS you are using and if you have other sound devices installed in your system aside from UA-25EX. Also check if there is any problem in the device manager.
No sound is being made
Go to your sound options. go to advanced speaker properties and find what your default sample rate is. you can adjust yours or leave it how it is. then go to preferences in reason and select audio. make sure the sample rate selected in the program is the same and you should be all set
When using reason adapted after
Please do a hard shut down by holding down the power button and
restarting the system.
If you have the software for the program you can uninstall, restart
system the reinstall the program again.
That should fix the bug.
Cheers.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
