20 Most Recent
Zenith C27V36 27" TV Questions & Answers
Bad fly-back transformer or perhaps a shorted deflection yoke. That's the best guess I have for you without having the TV in front of me.
Zenith C27V36...
Answered
on Apr 25, 2010
Hello to all, I have a tv zenith model C27V36, and it has a problem I connect it in the series and it does not turn on and I connect it to the network(net) and immediately burns (damages) the horizontal exit that is a trasistor C5905 and it burns (damages) both resistances of the protection,I changed the trasistor C5905 for a trasistor C3997 that is 20 amps and nonetheless it burns it,there are no signs of short circuits. Could the problem be the high horizontal ocsilacion?? But since turning it on it burns(damages) the horizontal exit I do not have way of checking it, because it is automatically damaged . can someone please tell me what to do in this case??? Or where I can find an electronic diagram or a sketch??? Or can someone who has worked on this TV before h
help me out?? It is a zenith model C27V36 of 27 "..
thank you for you help.
Zenith C27V36...
Answered
on Apr 25, 2010
G'Day!
Unfortunately, what you're describing is a repair
issue. You won't be able to address the problem with troubleshooting.
There is a part inside the TV that needs to be replaced. If you're
under warranty, this will cost you nothing. If you're not under
warranty the cost will likely be a minimum of $200 parts and labor.
However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further.
Zenith C27V36...
Answered
on Jul 29, 2009
The short answer is no. You will not need a converter box. This set contains the ATSC tuner required for the new over-air signals.
Dan
Zenith C27V36...
Answered
on Mar 04, 2009
This set has the ATSC tuner required for the new over-air standard. No converter is needed.
Dan
Zenith C27V36...
Answered
on Mar 04, 2009
The remote should have a scan button on it.
then the screen go thru it process and it should say done
Zenith C27V36...
Answered
on Feb 18, 2009
Hi and welcome to FixYa,
Pls verify if your particular model/versions has a PIP feature. To my understanding, the 2nd Antenna/Cable IN goes to a 2nd tuner that is primarily used for the PIP (picture in picture) mode. This mode would allow you to watch simultaneously 2 different TV channels.
Pls post back. Good luck and thank you for using FixYa.
Zenith C27V36...
Answered
on Feb 11, 2009
It sounds like the De-gauss circuit isnt working. It demagnetizes the TV tube.
It's something only a tech can fix though.
Zenith C27V36...
Answered
on Jan 05, 2009
try to check the capacitor valuing 400v/150mf or the biggest capacitor,and all 160volts capacitor
Zenith C27V36...
Answered
on Apr 11, 2008
If it is an older "hd" tv it is probably 'hd ready.' Check for adjustments on your source. The tv will most likely only display the highest resolution it is given.
Zenith C27V36...
Answered
on Dec 30, 2007
If this set uses a picture tube then your problem may be in the vertical deflection circuit. Also an unstable power supply will cause this problem.
Stargazer
Zenith C27V36...
Answered
on Mar 17, 2007
Possibly you're not putting the numbers in fast enough.
If you are then there maybe a problem with the microprocessor responding too quickly to commands.
I've never seen this problem before, but my TV will do the same thing if I don't get the numbers in fast enough.
Stargazer
Zenith C27V36...
Answered
on Mar 10, 2007
A common practice in the TV industry is to include the size in inches in the model number. Often, a model will be made in different sizes, for example, z42pj240 may have a z50pj240 family member. They will use the same main circuit boards and remote controls. Check the list in your universal remote control manual for a variant like that.
Zenith Televison...
Answered
on Mar 29, 2021
