20 Most Recent XIME Bidet Spa Auto Electronic Toilet Seat Questions & Answers
the maker of the unit
XIME Bidet Spa... | Answered on Nov 29, 2013
https://writeupcafe.com/blog/cryptocurrency/1255530-atomic-wallet-support-number??1856-254-3098??/
Home | Answered on May 19, 2020
However, Atomic wallet is available in desktop and mobile versions which provides convenience. And it is a decentralized wallet where you will get private key for every coin you store in it. It is an open source wallet which means no one can infuse any malicious code into it.
https://steemit.com/atomic/@abhijeetcg/atomic-wallet-comparison-with-other-existing-crypto-wallets
Home | Answered on May 14, 2020
Tighten the screw in the centre of the hands of your mystery clock.
Home | Answered on May 13, 2020
I believe the whole back needs to be removed I cant remember if it is pop off or held on with a screw. Battery is AA minion
sounds like the main drain pipe is clogged up..contact a plumber asap
Home | Answered on May 12, 2020
The company says it's out of production until the Fall of 2011. It's being moved to a different manufacturing plant. The **** who made the decision didn't have enough brains to stock pile before the move. ****.
Home | Answered on May 08, 2020
Replacement style led's lamps are available for nearly any fixture. Take one of the halogens to your local box store and ask for a replacement led.
Home | Answered on May 02, 2020
Toilet tank won't fill up or is slow to fill. The most common reasons for a valve to slow down or no longer fill the tank after the flush are debris issues and the length of time a valve has been in use. ... Valves in use for a period of 7 years or more can have their working parts start to wear out. 1.
https://www.fluidmaster.com/toilet-problems/remove-fill-valve-cap-replace-seal-toilet-wont-fill-slowly-filling-tank/
I use Crazy Glue because it is very thin, so it allows the parts to come together completely. Practice getting the parts to fit together perfectly before glueing. Don't use too much because it may spread out wildly as the parts are put together.
Home | Answered on Apr 25, 2020
HAVE NO CLUE AS DO NOT OWN ONE OR EVER SEEN ONE WHAT WAS IN IT
Home | Answered on Apr 22, 2020
https://www.amazon.com/Swarovski-Melody-Motion-clock-2019-QXM382BRH/dp/B07XN4LXR4
Home | Answered on Apr 21, 2020
https://lifehacker.com/why-the-shower-gets-hot-or-cold-when-you-flush-and-how-508252782
It could be caused by an over-enthusiastic thermostatic mixing valve, which reduced the hot water flow too much. Using up all the water in the hot water tank would also lead to a cold shower.
Home | Answered on Apr 05, 2020
Well that's not very Eco is it :>D
Video and text based help
https://www.google.com/search?q=eco+flush+keep+running
Home | Answered on Apr 04, 2020
Composting toilets use the natural processes of decomposition and evaporation to recycle human waste. Waste entering the toilets is over 90% water, which is evaporated and carried back to the atmosphere through the vent system. The small amount of remaining solid material is converted to useful fertilizing soil by natural decomposition.
Compost toilets work in three steps:
  1. Compost the waste and toilet paper quickly and without odor
  2. Ensure that the finished compost is safe and easy to handle
  3. Evaporate the liquid
This natural process, essentially the same as in your garden composter, is enhanced in "commercial composting toilets" by manipulating the environment in the composting chamber.
Home | Answered on Apr 01, 2020
I'm having the same problem. Did you ever find a solution?
start with manufacturer for request --or online search
Home | Answered on Mar 31, 2020
XIME Bidet Spa Auto Electronic Toilet Seat Logo
1 questions posted
Top XIME Home Experts
john h
Tom Chichester
Are you a XIME Home Expert? Answer questions, earn points and help others
View Most Popular
XIME Home
  • XIME Home
Most Popular Question
buy water filter
  • Home
