20 Most Recent Wolf Range 18 in. SPR-100 Gas Cooktop Questions & Answers
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Wolf Range 18... | Answered on Sep 11, 2018
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Wolf Range 18... | Answered on Sep 22, 2011
Did the plumber make sure there was not something plugging the gas service connection on the range before he hooked up the gas pipe from the house to it?
Wolf Range 18... | Answered on Mar 16, 2011
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Wolf Range 18... | Answered on Feb 06, 2011
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
heatman101
Wolf Range 18... | Answered on Sep 26, 2010
Use Ceramic Bright from Home Depot.
Wolf Range 18... | Answered on Apr 10, 2010
The good news is you have a great product! You just need technique and the "Green" cleaner DeBruce Polish. Use DeBruce Polish and a cloth for clean ups. DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. We buy Debruce Polish at debrucepolish.com
  • Firstly clean with DeBruce Polish to clarify area.
  • you may have to "re-grain" those finely scratched areas.
  • Blend or "scratch out" the misdirection scratch's with new "controlled" scratching, useing a 3M scotch brite #7447 you get at auto parts store (Nappa). Use medium very firm pressure.
  • -Re-clean with DeBruce Polish. Touch ups are now a breeze.
Wolf Range 18... | Answered on Mar 05, 2010
Remove the oven door skin.
Wolf Range 18... | Answered on Mar 02, 2010
hi friend,
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
it sounds like it is the spark module that's making the clicking noise. normally there are 4-6 wires that connect to it , and if you are not comfortable making the repair yourself then I would call an appliance repair company.The part should cost 30-50 $ Good luck
hope this helps u
please rate me.......................
thank u for using fixya
regards
sivaranjini
Wolf Range 18... | Answered on Nov 25, 2009
try using non scratching comet or ajax and a small amount of water with a scrub brush.
Wolf Range 18... | Answered on Oct 10, 2009
Use DeBruce Polish for the stainless steel and smooth cook tops. We get DeBruce at debrucepolish.com
Wolf Range 18... | Answered on Sep 10, 2009
Youcan try tightening them up yourself. Need two adjustable wrenches, one to hold the connector to the burner and the other to tighten the compression fitting. After that have a solution of water and soap and spray all around your fittings to see if its still leaking, you will see bubbles, If its still leaking you will have to turn yourgas supply valve off and disconnect flex gas lines replace with new ones. After replacing do the same thing spray with the solution to see if they leak.If you dontfeel comfortable doing this dont.
Wolf Range 18... | Answered on Aug 25, 2009
yes it is more effective
Wolf Range 18... | Answered on Jul 21, 2009
GE has come up with new products which have high quality insulation. I am leaving it on you to decide which one would fit your pocket by selecting the model from GE's authorised web site.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=COMMERCIALCATEGORIES&CATEGORY=CA0018&SITEID=GEA
Thanks for contacting Fixya.
Wolf Range 18... | Answered on Jul 05, 2009
clean the bottom of the knob by using vaccium,remove the knob then clean it.return the knob in possition how u remove.
tnx gerbee
Wolf Range 18... | Answered on Jul 04, 2009
Use DeBruce Polish I guarantee great results, also perfect on stainless steel go to debrucepolish.com
Wolf Range 18... | Answered on May 22, 2009
We have a new product that is odor less and non-toxic. $8.95 a bottle + shipping. Our web site will be up shortly: debrucepolish.com I'm Bruce, can be reached at 612-220-2236
Wolf Range 18... | Answered on Mar 27, 2009
Wolf Range 18 in. SPR-100 Gas Cooktop Logo
32 questions posted
Top Wolf Range Cooktops Experts
Alan Chouinard
Paul Carew
ray gallant
Are you a Wolf Range Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Wolf Range Cooktops
  • Wolf Range Cooktops
Most Popular Question
even after burners
  • Cooktops
