20 Most Recent Zenith C27V22 27" TV Questions & Answers
manual
Can't get visual and audio on screen from dvd
Check your cables:
8/18/2013 3:26:44 PM • Zenith C27V22... • Answered on Aug 18, 2013
No picture, just sound. picture
in some computer CRT monitors & CRT TVs after 4 or 5 years cracks develops at some soldering points - then due to loose contact picture disappears...when we hit ....those loose contacts joins temporarly & so again picture appears...so solution is TV circuit board should be observed carefully & at most of the soldering points - dry soldering should be done....100% your TV will work.......so if you are a technical person & if you have soldering iron & tools to open backside cover then you can do it or else approach a good service engineer..............iam babu - service engineer ( computers, laptops, printers, etc..) - bangalore - domlur - 09986222774 - [email protected]
4/14/2011 4:58:26 PM • Zenith C27V22... • Answered on Apr 14, 2011
I need the codes to program the remote to the tv
Hi Sarah,
You didn't mention the brand of you remote, anyway try this code.
PHILIPS/MAGNAVOX Codes: 183/ 184/ 208/ 213
Let me know if it didn't work.
Hope I helped you.
Have a nice day!
2/17/2011 5:09:03 AM • Zenith C27V22... • Answered on Feb 17, 2011
Screen intermittently goes black for about 15
Your TV has some loose contact in the circuit board. Usually it occurs on the soldering of picture tube base board. After long use the soldered contact will get loose sometimes. This fault cannot be detected by normal multimeter test. The only remedy is to resolder all the suspected soldering points. You just call a tecnician for support. You can assure it whether this is the problem or not; by make a small hit my hand on the side or top of the TV set while the screen goes off. Never hit it with any hard material. Only use your palm.
10/15/2010 7:58:26 AM • Zenith C27V22... • Answered on Oct 15, 2010
Cannot turn television off without unplugging
it might be due to on/off switch failure.
2/3/2009 9:39:27 AM • Zenith C27V22... • Answered on Feb 03, 2009
32" No Power, But Beeping Sound
you have a problem with the power supply module . it is located on the main board and needs to be replaced by a local repair tech.
8/31/2008 8:37:02 PM • Zenith C27V22... • Answered on Aug 31, 2008
2answers
Zenith 27" TV ( Regular, no Hdtv)
Likely to have a bad solder connection on the board on the CRT inside the tv
3/22/2008 1:06:09 AM • Zenith C27V22... • Answered on Mar 22, 2008
3answers
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
2/12/2008 6:02:19 AM • Zenith C27V22... • Answered on Feb 12, 2008
Zenith C27V22 27" TV loud humming noise
There is a coil in the set with a magnet glued to it, called the horizontal linearity coil. Sometimes the coil "sings", making a squeeling sound. I have seen this many times, and there really isnt anything actually electrically wrong with the set. To stop the squeeling the coil should be replaced.
6/27/2007 4:21:25 PM • Zenith C27V22... • Answered on Jun 27, 2007
PLEASE, PLEASE HELP IF YOU
Whats the model number of your Zenith and I will try to locate a owners manual for you.
1/4/2024 2:58:37 AM • Zenith Televison... • Answered on Jan 04, 2024
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue: Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly. Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate. Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs. Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components. If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
3/19/2023 2:53:59 PM • Zenith Televison... • Answered on Mar 19, 2023
Zenith VR4206HF VCR Very Slowly Loads/Unloads Tape
eject motor weak or dirty
11/5/2022 4:21:46 AM • Zenith Televison... • Answered on Nov 05, 2022
I have a Zenith zp505 universal remote(silver w/out a code search botton) . I need the manual and codes for 4 digit codes
I have a sony bravia TV(MODEL:KDL50R550A) I dont know How to reprogram my ZP505 ZENITH Universal 5in1 remote control to it.
9/26/2022 5:02:53 PM • Zenith Televison... • Answered on Sep 26, 2022
My Zenith dvd vhs combo model number xbv 443 dvd tray won't open
you might have to initiate the tray opening mechanism and as it's trying pry the tray forward and force it open it might fix it.
9/18/2022 4:34:41 PM • Zenith Televison... • Answered on Sep 18, 2022
Unlock zenith tv from hotel code without remote
The hotel mode is set by the remote control , not the control panel.
8/8/2022 2:43:24 PM • Zenith Televison... • Answered on Aug 08, 2022
Where can I find a manual for my Zenith ZG120M alarm clock
Not available online, but there is a video. https://www.google.com/search?q=Zenith+ZG120M+manual ..
7/22/2022 3:24:38 AM • Zenith Televison... • Answered on Jul 22, 2022
My 50' zenith tv clicks on and then goes right back off after about 2 seconds what's the cause of this?
Without a model there isn't a way to give any helpful information
7/11/2022 11:09:37 PM • Zenith Televison... • Answered on Jul 11, 2022
My 60 inch zenith plasma tv goes off in the middle of watching TV but always came back on but now the screen is black but sound still works
Is the tv blinking a code on the light in the front of the tv. If so go to manualslib.com input the model number and look up the trouble code in the manual for the tv.
5/27/2022 6:29:44 AM • Zenith Televison... • Answered on May 27, 2022
Zenith C27V22 27" TV Logo
13 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
32 no power but beeping sound
  • Televison & Video
