20 Most Recent
Zenith Z46Z83D 46" Rear Projection Television Questions & Answers
Convergence Problem
Hi
Thanks for using FixYa. You can see the pictures and
instructions to resolve the convergence issue---
Convergence
Issue
Please do accept the solution if the issue is resolved or
else revert for further assistance.
Thanks
Rylee
No pictuer just sound
I need get a Focus Block A-1719605 for a Zenith RZ46Z83D7 my mail is carvinsa @hotmail.com
Zenith tv
There is alot of reasons as to why set will not come on you need a repairman.Check ac fuse see if it is ok., which i dout but you might get lucky .
Filment
replace high voltage trippler.
Zenith 46" with a "hour-glass" picture.
If the hour glass figure is a seperation of colors that appear to be convegence mis aligned, then, the convergence ICs would be the problem.
If the picture is clear and you have a bending on the sides then the pincusion circuit in the horizontal circuit is where to look. Be careful of this circuit, it does control the high voltage.
The only way to have a board checked is to have an Authorized Service Center look at it.
It does, however, sound like there is a cold solder joint in the power supply that has gradually opened up and now is permanantly open.
Call Zenith (LG) to see who they recommend.
Picture quality and sound
than the tuning coil of circuit,like 39mhz coil or other circuite related with I.F. and detection section coil or any p.f.will be damaged if it should b currect than replace the tuner
Picture is blurry
it sounds like the focus block or flyback is bad.sometimes you can put nail polish on the adjustments controls to make it stay.usually
they are marked from the factory with white marks check and see if they are aligned.but be sure somebody with tech-skills help you.the flyback usually has a screen & focus control.(the big red wire to the tubes or block)
Menu
Why do you need them? use the remote....
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
