20 Most Recent
Zenith A56M91W 56" Rear Projection Television Questions & Answers
No Picture good sound
I had the same problem and re-soldered the DAG and the AA wire on the circuit board and now it works fine.
I am told I might have a fuse out on this tv.
Very rarely is there any fuses that open up on TV's. There are usually fusible resistors or fusible links that don't look like fuses at all open up. Mind you more than not a fuse or link will open because of an underlying issue with the TV. I suggest you have a technician look at the TV for you.
PIN CUSHION PROBLEM
If you have the proper tools and understand how the picussion circuits work then you can get a maunal and troubleshoot the TV set, but this pincussion circuit is a dangerous place to be as there is alot of high voltage in this circuit. if you do not know about these solid state circuits, play it safe and get a pro to assist you in this repair. Good Luck
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
