20 Most Recent
Zenith A50M91W 50" Rear Projection Television Questions & Answers
Picture gose blurry after 45 min or so
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
I have what I believe is a convergence problem.
Hi, this is a convergence chip failure and it can only be corrected by replacing the entire convergence board in this unit. This Board regulates and collaborates the RGB streams. if there is an apparent malfunction, it will become impossible to correct the issues you are experiencing at this time.
Simply replacing the convergence board or chip set will fix this issue.
No picture
the porblem of your tv might be somwhere in the video chroma.... the first thing to do is to check for an open capacitor 16V 1000mf path ways to CRT board connection to the main board... if your not inclined with this job contact for a service technician.....gud luck!!
Green spot on the middle of screen.
If the spot is perfectly round then most likely you have phosphur burn on 2 of the CRT's. If it uneven then maybe it is a spider who has made his home in there (not uncommon as it is warm and dry which is what they like).As far as cleaning goes, don't use standard glass cleaner as it will damage the screen. Use warm water and a soft towel, or purchase glass and plastic cleaner which is ususally a foam type spray.
My zenith CD/DVD duplicator LCD light on but no ready
If the LCD light on your Zenith CD/DVD duplicator is on but it is not showing as "ready," it is possible that there is an issue with the duplicator's internal components or settings. Here are a few troubleshooting steps you can take to try and resolve the issue:
Check the disc trays: Make sure that all of the disc trays are closed properly and that there are no discs stuck inside the duplicator. If a tray is open or a disc is stuck, the duplicator will not be able to operate properly.
Check the power source: Make sure that the duplicator is plugged into a working power source and that the power cable is securely connected to the duplicator. If the power source is not providing enough power, the duplicator may not be able to operate.
Check the settings: Check the duplicator's settings to ensure that it is set up correctly for the type of disc you are trying to duplicate. For example, if you are trying to duplicate a DVD, make sure that the duplicator is set to duplicate DVDs and not CDs.
Reset the duplicator: Try resetting the duplicator by unplugging it from the power source for a few minutes, then plugging it back in and turning it on. This can sometimes resolve minor issues with the duplicator's internal components.
If none of these steps resolve the issue, it is possible that there is a more serious issue with the duplicator's hardware or software. In this case, it may be best to contact Zenith customer support or a professional technician for further assistance.
