20 Most Recent Zenith VR4207HF VHS VCR Questions & Answers
You need to really give all the heads and surfaces where the tape touches a good clean. I recomend Servisol video 40 for this type of work. Cotton buds soaked in it will help shift bad areas. Apart from that, if it then doesn't go away you might have a faulty head, in my experiance.
By the way the job of cleaning will be hard work if the video lives in the house of a smoker!
Zenith VR4207HF... • Answered on Jun 23, 2010
Not at all, as long as the channel selector on the back of the VCR is set to channel 3 to receive the signal and record. Connect the digital convertor box to the VCR. Connect a second co-ax cable to the TV to complete the signal loop. Tune your TV on the channel you want to watch/record. Put the VCR on channel three on the display screen. Try recording and play it back. This will ensure all your connections are correct. Hope this helps, if not let me know.
Zenith VR4207HF... • Answered on Oct 27, 2009
A common practice in the TV industry is to include the size in inches in the model number. Often, a model will be made in different sizes, for example, z42pj240 may have a z50pj240 family member. They will use the same main circuit boards and remote controls. Check the list in your universal remote control manual for a variant like that.
Zenith Televison... • Answered on Mar 29, 2021
If you are trying to use the player and switch between DVD and VCR there is usually a button on the front of the player and a matching one on the remote. VCRs are becoming very rare now so most TVs don't have the connectors for them. How old your TV is will control how you do this. Older HD TVs are fitted with a SCART connector, ( a large, chunky, rectangular connector with lots of pin holes), or RCA connectors, (3 round pin connectors coloured red, white and yellow). *Note* Make sure you use the 'OUT' connectors on the VCR and the 'IN' connectors on the TV. Some newer TVs will let you connect through a 'screw in' Satellite/'CABLE TV wire connector.
Zenith Televison... • Answered on Nov 20, 2020
1) tune the desired station frequency
2) while the frequency is being displayed, quickly press the memo set/clock adjust button.
3) press the desired preset button
4) press the memo set/clock adj button again
5) the station will be stored
Zenith Televison... • Answered on Apr 24, 2020
To set the Alarm press the Alarm Set button then use the set buttons on top change the Alarm time. Use the to change the Alarm time, when the Alarm time is set press and hold enter until you hear a beep. Press the Alarm On/Off button to select radio or buzzer for the alarm or alarm off. http://portablemedia.manualsonline.com/support/zenith/clock-radio/zenith-1233a-how-do-you-set-the-time-on-the-clock-4514622
Zenith Televison... • Answered on Apr 23, 2020
Digit Zenith TV Converter Box Remote Codes
212
254
267
357
454
457
557
657
757
857
955
957
991
4 Digit Zenith Converter TV Box Remote Codes
1415
9910
5 Digit Zenith Converter Box TV Remote Codes
01414
51415
Zenith Televison... • Answered on Apr 22, 2020
No, the Zenith XBV443 can not record a VHS tape to DVD. This unit is a DVD Player/VCR recorder. It doesn't have the ability to burn data/files to disc. The manual is available at ManualsLib: https://www.manualslib.com/manual/267291/Zenith-Xbv-443.html . The DVDs that it can play are limited: https://www.manualslib.com/manual/267291/Zenith-Xbv-443.html?page=5#manual . I wish that I had better news for you. Cindy Wells
Zenith Televison... • Answered on Jul 23, 2019
Televison & Video Logo
6 questions posted
Top Zenith Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
zenith vcr vrm4270 auto tracking seems
  • Televison & Video
