20 Most Recent Zenith ZHX-313 System Questions & Answers
0answers
Remote code
Be the first to answer 10/22/2013 4:15:35 AM • Zenith ZHX-313... • Posted on Oct 22, 2013Be the first to answer
5answers
Progressive scan mode will not disable
Hi, you must hold 1st remove the disc (if you have one in) then hold down the STOP which is just under the RECORD button. Hold it for about 6 to 8 seconds. That should clear it.
Good luck
trestaris
5/10/2013 1:12:39 AM • Zenith ZHX-313... • Answered on May 10, 2013
3answers
Progressive scan
This happened to me & I finally found a manual online that I could download.
Here's what the manual says:
"If you set Progressive Scan to On in error, you must reset the unit.
1) Remove any disc from the unit and close the disc tray. See that "NO DISC" is displayed on the display window.
2) Press STOP and hold it for five seconds before releasing it. The video output will be restored to the standard setting and a picture will once again be visible on a conventional analog TV or monitor."
Glad I could help because this problem is very annoying!
3/21/2013 10:14:59 PM • Zenith ZHX-313... • Answered on Mar 21, 2013
The surround sound only works
Plug a cable(prob RCA) from audio out on your tv into any desired input on your stereo.
8/30/2011 4:25:04 AM • Zenith ZHX-313... • Answered on Aug 30, 2011
It will only let me year the background wounds but
Hi elygonzalez0,
This indicates that the DVD media which you are using does not support voice in English but other languages.
All you can do now is first check up the setup settings whether there is something which is causing this issue.
If not then check up the DVD and it's cover if it indicates something to that effect.
Hope this helps ..:) In case you have any queries,feel free to get back to me.
8/1/2011 8:38:46 AM • Zenith ZHX-313... • Answered on Aug 01, 2011
I have a Zenith ZHX313
Tracking depends on the tape's lower edge. If the head that reads it is dirty or the edge is wavy you will have bad tracking.
http://en.wikipedia.org/wiki/VHS#Tracking_adjustment_and_index_marking
7/25/2011 9:56:20 PM • Zenith ZHX-313... • Answered on Jul 25, 2011
Can i put 3ohm speakers
If they're not the originally-specified speakers you, like any pioneer, can expect some arrows in your back; or maybe you'll discover sonic paradise. These small systems are manufactured as a set for a reason. If anything has proprietary connectors I'd avoid modifying them for use with unmatched components.
There's a lot more going on in a given speaker than its impedance.
1/25/2011 1:09:38 PM • Zenith ZHX-313... • Answered on Jan 25, 2011
My tape does not completely
Does the tape door open? Mine would not eject because the door did not open. I removed the door & it works OK without it.
12/4/2010 12:07:18 AM • Zenith ZHX-313... • Answered on Dec 04, 2010
2answers
VCR Won't Eject VHS Tape
Do not panic yet! Before doing anything else just unplug the unit for a time. On two different occasions I unplugged my TV/VCR combo, it reset itself and I could eject the tape. I do not know how much time is really necessary as I let mine sit overnite in those two instances.
So after much frustration the first time a tape stuck which included carefully opening the chassis to look for a twisted tape, sticky labels or loose parts in and around the metal cassette holder plates, I put it back together. Now I just unplug to reset.
I am not saying this will work in every instance, but give it a try first.
12/4/2010 12:05:26 AM • Zenith ZHX-313... • Answered on Dec 04, 2010
No video
does it play?
9/14/2010 1:24:39 AM • Zenith ZHX-313... • Answered on Sep 14, 2010
Zenith zhx313 theatre system...vcr accepts tape, but won't play..
retime the gears.
7/18/2010 4:14:06 PM • Zenith ZHX-313... • Answered on Jul 18, 2010
2answers
Want to down load a manual for a zhx313 can you
http://safemanuals.com/user-guide-instructions-owner-manual/LG/ZHX-313-_E It's free too
6/24/2010 3:00:04 PM • Zenith ZHX-313... • Answered on Jun 24, 2010
Speaker set up what speakers are the l.s. and the
LS or SL is rear left and RS or SR is rear right
2/21/2010 12:59:41 AM • Zenith ZHX-313... • Answered on Feb 21, 2010
Disengage Progressive scan
Try this turn on the dvd check there is no disc on the tray then push the stop button for 10 seconds
1/6/2010 2:38:55 PM • Zenith ZHX-313... • Answered on Jan 06, 2010
2answers
I need a manual for a Zenith ZHX-313
There's a full manual at:
It's in .pdf format so you can even download to your computer for future use.
10/17/2009 5:34:03 PM • Zenith ZHX-313... • Answered on Oct 17, 2009
DVD drawer will not open
hi friend,
Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs. If this is the case you should have it serviced or perhaps it is time for a new one.
I hope this helps.
thank u for using fixya
regards,
sivaranjini
8/5/2009 12:05:50 PM • Zenith ZHX-313... • Answered on Aug 05, 2009
Zenith ZHX-313 System Logo
Popular Tags
48 questions posted
Popular Products
Top Zenith Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Audio Players & Recorders
Most Popular Question
disengage progressive scan
  • Audio Players & Recorders
