20 Most Recent Bose LifeStyle 50 System Questions & Answers
Bose lifestyle 50 "no response"
You can find a bose M1 on amazon already refurbished
11/4/2016 4:21:26 PM • Bose LifeStyle... • Answered on Nov 04, 2016
2answers
I have a Bose Lifestyle
Here is the Manual for you're Bose LifeStyle 50 System, here you can figure it out: http://www.bose.co.uk/GB/en/images/Lifestyle%2050%20Home%20Theater%20System_tcm6-4085.pdf
11/3/2016 5:45:36 PM • Bose LifeStyle... • Answered on Nov 03, 2016
3answers
The music center does not communicate with the
i have the same problem did you find out why
7/31/2016 4:20:30 PM • Bose LifeStyle... • Answered on Jul 31, 2016
Getting "no response" on music center after power outage. After disconnecting transformer for several hours and reconnecting it usually works until now.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/31/2016 4:18:09 PM • Bose LifeStyle... • Answered on Jul 31, 2016
Remote shows no response
I have just had a major problem trying to get the handheld (touch screen) music centre to communicate with the multi room interface. It took over a week to sort out by trial and error, but here is the solution : 1. Disconnect everything from the multi room interface apart from Room A and the CD player (blue connector). 2. Turn off the electricity supply at the wall (turning off any in line extension lead is not good enough - it needs to be at the wall socket). Leave turned off for at least 2/3 hours. 3. Turn back on and then leave it again for 2/3 hours. 4. Touch the music centre and you should find that it has now registered with the interface unit. 5. Connect the other rooms and input sources with the power switched on (contrary to instruction manual which advises you connect everything before powering up). 6. Test each input systematically as you connect them. Hope this helps. I was on the verge of buying another multi room interface (I have 2 music centres and neither worked so assumed in was the interface at fault), at a cost of £200, so now glad I persevered with resetting the system !
7/31/2016 4:14:38 PM • Bose LifeStyle... • Answered on Jul 31, 2016
My lifestyle 50 M1 interface is displaying "No response". I have tried all the standard reboot options but apparently I need to replace the capacitors. Can anyone tell me the values of these?
Terry, I have had the same issue with LS50 for some time and stumble last night on the blog: https://blogteramod.wordpress.com/2015/05/18/lifestyle-50-no-response-quick-repair/ It is written in German though the detail worked perfectly for me this morning. Bottom line is that they suggest you replace on the P1 unit 4 x caps (C9- 47uF 16V, C10-47uF 16V, C17-10uF 25V, C18-10uF 35V). I did the work on my unit this morning and all is good - remote now connects immediately to P1 (as it did when new). Hope that's useful. Glen
3/3/2016 10:30:11 AM • Bose LifeStyle... • Answered on Mar 03, 2016
2answers
BOSE LIFESTYLE 50 REMOTE CONTROL NOT WORKING
FOR THE BOSE LIFESTYLE 50 SYSTEM (Model P1 - Personal Music Center remote)You can re-calibrate the remote first by following the steps below:1. press and hold down on the display screen in the top middle area of the remote2. After a few seconds the word CAL will appear in the middle and the word SOURCE will appear in the top left area of the remote.3. Press the SOURCE button.4. The word KEYPAD will appear in the top right area of the remote5. Press the KEYPAD button and a small circle will appear in the bottom right of the remote.6. Press the Circle This should've recalibrated the remote.If you need to relink the remote to the system, HOLD down the mute button while having the remote as close as possible to the unit. You will hear a beep . Release the button, after a pause , you will hear the remote beep twice.This re-links the remote to your systemIf the backlight is not working, your options are1. Spend $349 and get a new one from Bose Or2.Spend $220 and get a used one on E-bayOR3. Use your remote with the lights on so that you can see the display :-)...the cheapest way OR Invest in an LED Book light that you can clamp on the remote and use that for your light ($9.99)
11/19/2015 3:45:35 PM • Bose LifeStyle... • Answered on Nov 19, 2015
2answers
Turned my tv on today and only 1 speaker working (left front). Yesterday all speakers were working fine. Have unplugged everything and set up again but still just the one speaker working. Any ideas?
Swop left & right speakers, if only the right speaker works, the ex left speaker is faulty, if the left side still doesn't work, the problem is the tv
9/28/2015 8:24:43 PM • Bose LifeStyle... • Answered on Sep 28, 2015
When I had my Bose 50 lifestyle playing the sound just went out no radio no nothing whats the problem?
My best guess. Is bad connections, loose wires, or disconnected wires
2/2/2015 6:45:57 PM • Bose LifeStyle... • Answered on Feb 02, 2015
Bose p1 remote does not work batterys git very hot need a replacement do they have a universal unit for the music center
no my parents have the same problem, since it's not a infrared system a universal one won't work , they ain't cheap
10/13/2014 9:00:48 PM • Bose LifeStyle... • Answered on Oct 13, 2014
Bose system (Lifestyle 50)
Did you try leaving it unplugged for a few hours?
7/10/2014 1:00:52 AM • Bose LifeStyle... • Answered on Jul 10, 2014
0answers
0answers
Bose LifeStyle 50 System Logo
55 questions posted
Top Bose Audio Players & Recorders Experts
Marvin
Marvin
Steve
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
lifestyle 50 m1 interface displaying no
  • Audio Players & Recorders
