20 Most Recent
Bose 151SE Main / Stereo Speaker Questions & Answers
Dayton sub-100 connection
You have it upon one of several truly odd "standards" in the AV industry but the answer is simple if not quite logical. You will use an RCA type cable from the Sub out or LFE on the receiver to just one of the two inputs on the subwoofer. I usually use the one on the right but it really doesn't matter. The other connectors would be for a system with out a sub out where the speaker wire would be run first to the subwoofer and then out to the speakers. This will not be used at all in your case.
Enjy!
Bose 151SE Main...
Answered
on Feb 27, 2009
Subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Bose 151SE Main...
Answered
on Feb 17, 2009
Bose sa4 converting to analog input
I'm looking for advice as to the best Bose input for SACD (contains 5.1 information) captured to FLAC and played back by computer (Analog Line out currently but considering adding digital out): 1. Bose Aux in 2. Bose Digital in Regarding option 1. The Bose manual states the following which makes me think that Aux is the right decision: Setting up a digital sound source Connect a DTV or DVD player's digital signal directly to the female RCA jack on the audio input cable. Connect the DVD player's analog signal output to the AUX inputs. If your Lifestyle® system receives a valid digital signal (including PCM or Dolby Digital bitstreams), this digital sound is used. If no valid digital signal is received, then your system selects the analog signal being sent to AUX, which is then processed by the Videostage® decoder for excellent home theater sound. If your digital audio source has an optical connector, you will need an adapter with an RCA (coaxial) connector. Consult your dealer or contact Bose® Regarding option 2. I've read the following (not in Bose manual): A coaxial digital audio connection is used to send S/PDIF digital audio signals between devices. It supports uncompressed PCM stereo audio as well as DTS and Dolby Digital 5.1/7.1 surround sound signals. It does not support DVD-A, SACD or high-definition audio such as DTS-HD Master Audio and Dolby TrueHD. So in summary: The Aux in is analog but processed by the Videostage® decoder. The Digital in supports 5.1 and should be cleaner/quieter being digital I expect. I'd be interested in onions from other that know for sure what's better or have done this. thanks
Bose Audio...
Answered
on Nov 29, 2020
How to convert Bose sa4 into analog input like sa3
Hi guys
I'm having quite a bit of trouble setting up my Soundtouch SA 4 AMP. I'm yet to do the IT course required to fix the issues with my music libraries not being found, but I'll get onto that when I have spare weekend to devote to tackling it.
In the meantime i am wondering if someone can tell me how to connect a device directly to it via the auxiliary input.
I was told by the reseller I purchased it off that I needed to use the aux port to connect my smart TV to the Soundtouch. However I can't find any mention of it in the manual or on the forums and have tried the headphone jack input but with no joy.
I also use this feature often as I have the Soundtouch set up in my entertaining area....inevitably people come over and politely inform me that my taste in music is a little on the nose - so they plug their iPhone into the system to show me how to do it right! Sadly that happens way too often (Abba- Bee Gee's - where am I going wrong?).
So please help - how do I connect audio devices directly into the Sountouch SA4 Amp without using Wi-Fi?
Thanks
Bose Audio...
Answered
on Nov 29, 2020
Bose remote rcv1t-27 not working
If it's still not working, contact Bose, sometimes they will ship a replacement at no charge, if not, ship it and $20.00 to me and I will repair it or get you a replacement, if for some unseen reason it is un repairable or I am unable to get a replacement, you will get a full refund, see my feedbacks on Letgo in Fairfield California under Supertech99, 100% 5 Star feedback and reviews, I am the real deal.
Bose Audio...
Answered
on Sep 20, 2020
Button on bose speaker stuck
The buttons on my Series-II cubes get stuck all the time. It seems the button itself sticks against the housing. I first spray on a little bit of silicone to coat the sides of the housing that rub up against the button. Then I use a straight razor blade to pry in the gap between the button and the wiring-holes, alternating below each hole. As you do that, the button rocks out a little bit at a time.
Bose Audio...
Answered
on Aug 07, 2020
