20 Most Recent Bose Acoustimass 15 System Questions & Answers
Check to see if any wires are touching or if any pins are bent in connector.
Bose Acoustimass... | Answered on Dec 28, 2018
If there are no obvious screws holding the back in place, then the only way to have access is to remove the grill, remove the speaker and go in from that end to perform the needed repair of the connector. You can remove the wires from the speaker so it does not get in the way as you use the speaker opening for access. good luck.
Bose Acoustimass... | Answered on Sep 06, 2017
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Bose Acoustimass... | Answered on Oct 29, 2016
The serial numbers for the L1® 1S Cylindrical Radiator®s are on the back. The serial number for the Power Stand is on the bottom of one of the legs.
Sorry, I can't help with the Acoustimass system.
Bose Acoustimass... | Answered on Aug 12, 2016
The pin is usually the positive on the RCA connectors
Bose Acoustimass... | Answered on Nov 14, 2014
HDMI is great way to connect the two.
Bose Acoustimass... | Answered on Aug 03, 2014
Hey Any chance you have the Acoustimass 15 II or III? The first Acoustimass 15 has a switch. The II and II models turn off and on when it receives a signal from the source you are using. Amplifier, ect. All you need to do is make sure everything hooked up correctly and plug it in.
there is a switch located next to where the speaker wire is connected to the module. flip it.
Bose Acoustimass 15 System Logo
143 questions posted
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
speaker outputs pin or sleeve positive
  • Audio Players & Recorders
