20 Most Recent
Kodak Ektaprint 95 Copier Questions & Answers
Orange roller
hi im jules_09,is it all the fuser area?to be safe try cleaning it
first with alcohol,if the that doesnot work try metal polish,just be
sure its not the opc drum that make the copies ok,get a fine and soft
cloth so you would not damage the roller,urb a right amount of metal
polish to it then then rub it with cloth gently in one direction the
best directio is circular.be carefull not to scracth it or the drum
My kodak verite 55 printer says it is out of paper, but it is not. It also says the printer is not recognized. Any ideas?
- Check to make sure that the paper tray is loaded correctly and that the paper is not jammed in the printer.
- Make sure that the paper guides in the tray are adjusted correctly for the size of paper you are using.
- Check to see if the printer driver is up to date. Outdated printer drivers may cause the printer to not be recognized by the computer. You can download the latest driver from the Kodak website.
- Check the USB cable that connects the printer to the computer to ensure that it is properly connected and that there is no damage to the cable.
- Restart the printer and the computer and try to print again.
- If the issue persist, run the printer troubleshooter, it might help you to identify and fix the problem.
- If none of the above solutions work, it is possible that the printer's paper sensor is malfunctioning. In this case, contact Kodak customer service for further assistance.
It's important to follow the instructions carefully and if you have any doubts or difficulties, consult the printer's user manual or contact the manufacturer for assistance.
My Kodak Ektapro 5020 double plays every slide
if you need to purchase a special slide, you can call Kodak directly and make the request. They can either direct you to the product on their website or one of their vendors. And for the double slide issue, I would suggest leaving a blank space between each slide as a round about solution. Otherwise, you can reference the product manual to help overcome this.
Thank you.
I cannot print a word document
You can try use a PDF print driver and see what is the output and Error.
Please post more information such as error and what happens when you try printing, if the PDF solution does not work
