20 Most Recent Fisher FVH-T538 VHS VCR Questions & Answers
Trying to find universal remote
The following link has a large list of remote and codes to go with it.
http://www.xdiv.com/remotes/
Regards,
G33k
5/4/2011 7:41:57 AM • Fisher FVH-T538... • Answered on May 04, 2011
Fisher v plow controller, on/off blinking
It sounds like you may be experiencing an issue with your Fisher plow controller. The on/off blinking could indicate a problem with the controller or the plow itself. Here are a few things you can try to troubleshoot the issue:
  1. Check the wiring of the controller and plow to ensure that all connections are secure.
  2. Inspect the controller and plow for any visible damage, such as frayed wires or damaged connectors.
  3. Check the battery in the controller to make sure it is charged and functioning properly.
  4. If the problem persists, try resetting the controller by removing the battery and unplugging the controller from the vehicle for at least 30 seconds. Then, reattach the battery and plug the controller back in.
If these troubleshooting steps do not resolve the issue, it may be necessary to seek assistance from a professional or contact Fisher for further assistance.
1/6/2023 8:10:54 PM • Fisher Televison... • Answered on Jan 06, 2023
My Fisher AM/FM receiver RS9015 does not seem to receive commands from remote
You should have sent a picture of the back. Im taking a guess. Is the open slot big enough to put remote control inside to charge the batteries. If the remote is universal it may need reset. The transmitter in receiver is not working with remote.
8/20/2022 1:12:31 PM • Fisher Televison... • Answered on Aug 20, 2022
A remote for my Fisher CA9050 amplifier.Help!
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name of your device in its search box at the right column of the display window. It will help you to find the details easily. https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/ https://remotesearch.blogspot.com/ https://electrohelponline.blogspot.com/
7/15/2021 1:24:54 PM • Fisher Televison... • Answered on Jul 15, 2021
Fisher paykel DEGX2 dryer squeaking
There is a video that may address your issue. Check it first. This video will look at a DE62T27GW Fisher & Paykel Electric Dryer that has the following problems: Squealing noise, Making loud noise, Squeaking.
11/19/2018 4:56:23 PM • Fisher Televison... • Answered on Nov 19, 2018
Finding remote control for FISHER TAD-5060 Digital High-Fidelity System with REM-5060 Wireless Remote Control. I've lost mine
You can buy one here:https://www.ebay.com/sch/i.html?_odkw=rem+5060&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XREM-5060.TRS0&_nkw=REM-5060&_sacat=0Hope this helps :)
1/1/2018 8:53:49 PM • Fisher Televison... • Answered on Jan 01, 2018
I have a FVH-7600. The tape is stuck inside. When
Open up unit and manually turn gear for the tape platform to move it up for ejection. Then replace the spool belt and you may restore operation. the attached site has belts and will also show you how to measure for replacements. MCM Electronics Home and Pro Audio Video Security and Test Equipment
9/23/2017 8:31:25 PM • Fisher Televison... • Answered on Sep 23, 2017
Fisher vcr model FVH -920 POWER COMES ON BUT SHUTS ITSELF OFF IN A FEW SECONDS
Fisher Studio Standard VCR FVH-730 - YouTube
? 6:32 www.youtube.com/watch?v=j4XygXpGkD0 Jul 26, 2009 - Uploaded by GHWTVideos But got replaced by a Sears by JVC VCR from 1992. ... FisherStudio Standard Amp Problem and Power Surge (Part 2) - Duration: 8:12. by ...
10/17/2015 12:13:28 AM • Fisher Televison... • Answered on Oct 17, 2015
Looking for owner manual for Fisher VCR Model FVH2502
google it
11/6/2014 5:17:27 PM • Fisher Televison... • Answered on Nov 06, 2014
No Sound from Fisher Box TV
I think your problem is with the scart socket . It most likely to be a dry joint on the pin where the sound goes in to the tv. you have to take back cover off the tv and turn the chassis over to do the dry joints if you can do it yourself otherwise get an engineer to do it. Good luck.
8/25/2014 4:42:40 PM • Fisher Televison... • Answered on Aug 25, 2014
Recently acquired a Fisher PC203
If I remember correctly, this is an older model set (late 1980, early 1990 I think). Many cable systems of that era didn't offer the large number of channels they do now, and the cable tuning of many sets was very limited. Most cable companies required you to use a converter box to get all the channels. So you probably aren't missing anything, the set just can't do more.
2/10/2014 9:34:31 PM • Fisher Televison... • Answered on Feb 10, 2014
I need a code for a fisher t.v.
0493,0499,0418,0431. Try these codes. If you wish to get more codes and other details check: http://electrohelponline.blogspot.com/ & http://electro-medical.blogspot.com/ Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
1/6/2014 11:39:46 AM • Fisher Televison... • Answered on Jan 06, 2014
I can't get it off of a setting testing.
I WANT POWER LOT NUMBER PLS
7/28/2013 12:17:59 PM • Fisher Televison... • Answered on Jul 28, 2013
Programar un control
URC 4080 has setup codes for Fisher. Check this link to download its code list.
12/18/2012 4:16:20 PM • Fisher Televison... • Answered on Dec 18, 2012
0answers
2answers
My tv screen is blaock
What ever you do, do NOT hit electronics, even if it seems to make them work, it will only have it working for a bit till it stops working again. When you hit it, you are most likely getting a connector back into its socket. If you have warranty then I suggest sending it back. IF you do not have warranty and feeling adventurous, you can attempt to take the TV apart and fix it yourself.Look for a loose connector, because most likely when you hit the side of the TV, you make a connector lodge itself back into place correctly, bringing back the picture, but I do advise against this and get it sent back via warranty.
6/19/2011 5:47:59 PM • Fisher Televison... • Answered on Jun 19, 2011
Televison & Video Logo
1 questions posted
Top Fisher Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you a Fisher Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher Televison & Video
Most Popular Question
trying find universal remote
  • Televison & Video
