20 Most Recent Symphonic SC519DD 19 in. TV/DVD Combo Questions & Answers
U pound salt. Get a new remote.
Symphonic... | Answered on Jun 13, 2016
you might have set the sleep setting on remote
Symphonic... | Answered on Oct 02, 2012
put it the mail address on not admitted
Symphonic... | Answered on Aug 10, 2011
It is difficult without remote. Try through the buttons provided in the TV front. Try the MENU button. Scroll through you will be able to get a solution.
Symphonic... | Answered on Aug 19, 2010
hello it sounds like theres a dead short unless you have a multimeter and oscilloscope a diagram and a bit of know how then yes you could do it youself i'd would get a quote for a repair good luck
shaun
Symphonic... | Answered on Jan 19, 2009
i can't find a setup code to remote setuo
Symphonic... | Answered on Dec 01, 2008
I know that shortly after I purchased this tv mine also shut itself off occasionally. The owners manual says that if it is on dvd mode and it's paused or on an inactive menu or something for 15 minutes or so that it would shut itself off. If a dvd is stuck inside it may be causing this? I have no idea about the open/close malfunction.
Symphonic... | Answered on Mar 31, 2008
The text mode has been activated either thru your cable/satelite box or your tv's. It is activated because the closed caption portion. If you think its because of your channel providers call them for the process to deactivate it . If it's your tvs check your menu's to make sure the closed caption portions are turned off. Good luck
Symphonic... | Answered on Feb 29, 2008
Color splases can show up when the sets are move from one location to another or when they have been dropped while moving it,another reason is when a speaker is placed to close to the tv.The tv has an internal demagnetizer witch gets activated when you turn the tv on,I suggest to unplug the unit for about 15 minutes and then plug the unit and turn it on,If the unit was dropped this problem might not be repairable.I hope the information helps .
Symphonic... | Answered on Jan 11, 2008
First of all try getting a Symphonic remote - http://www.miracleremote.com/ not that expensive. Then you can access all areas of the TV, including all sub menus and see how the audio is set-up.. Could be you have it in SAP mode, (Second Audio Programming), in which case you will hear nothing...
Bill
Symphonic... | Answered on Nov 19, 2007
https://codesforuniversalremotes.com/remote-control-codes-for-symphonic-tvs/
Symphonic... | Answered on Apr 25, 2020
Connect the converter box to TV, (usually rca connectors) connect an antenna to the box, turn it on and search for available channels. In most areas you should receive 10-20 channels.
Symphonic... | Answered on Sep 24, 2019
Symphonic SC519DD 19 in. TV/DVD Combo Logo
13 questions posted
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Symphonic Televison & Video
Most Popular Question
help
  • Televison & Video
