20 Most Recent Symphonic SC319C 19 in. TV/VCR Combo Questions & Answers
The vcr tape is stuck
press rcord and then it shuode come out. it will switch it selfoff then prees ejeckt.
5/22/2014 4:38:35 PM • Symphonic SC319C... • Answered on May 22, 2014
0answers
0answers
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
12/26/2010 7:22:50 PM • Symphonic SC319C... • Answered on Dec 26, 2010
0answers
How to change from tv
Here's the link to the manual for the SC319C. Look on page 12.
http://www.symphonic.us/pdf/om/SC319C.pdf
I hope this is helpful to you. Bobya.
9/24/2010 12:40:26 AM • Symphonic SC319C... • Answered on Sep 24, 2010
Theres no vcr tape in the vcr, therefore the tv turns off by itself.
maybe its confused
7/15/2010 5:08:39 PM • Symphonic SC319C... • Answered on Jul 15, 2010
On a symphonic SC3819, can a stuck VCR tape be
Yes, but for that you will gonna have to practically dismantle the tv to access the VHS mechanics and move them yourself  manually.
6/7/2010 8:05:23 PM • Symphonic SC319C... • Answered on Jun 07, 2010
Can I buy a remote for Symphonic TV, model SC3819?
sure you can check out partstore.com they have original remote for your tv.good luck.
2/27/2010 11:38:49 PM • Symphonic SC319C... • Answered on Feb 27, 2010
A friend gave ne an old Symphonic TV with its
u can go 2 buy a universal remote with a handbook 2 tell u how 2 program it lol.b alot easier.that way if u have dvd & vcr...it can b programmed 2 operate it as well as the tv!universal remotes r the best sollution lol.lazier the better lol.
9/23/2009 3:25:08 AM • Symphonic SC319C... • Answered on Sep 23, 2009
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
7/1/2009 7:42:49 AM • Symphonic SC319C... • Answered on Jul 01, 2009
No sound on TV but VCR is OK
Hi there, This sounds like an input control error.
If you find the menu section, then choose Av inputs, you can adjust the settings, I.e. stereo Video or Av (if you are using scart leads then choose Av.
Hope this helps, Chris
12/3/2008 10:13:53 PM • Symphonic SC319C... • Answered on Dec 03, 2008
Remote signal not received?
If u can get to the INSIDE front, clean the window of the receiver eye.(of cause the outside also!) If the wires going to the board can be unpluged, unplug, the push it back in. Possable that the receiver eye circuit is too heated up.Put a small (square boxed computer type fan) in the back of the tv to cool it down some.If u know how to "glue" a HEATSINK to the chip to get rid of the heat, may help.
note: it is possable that BOTH regulor and universal r/c are intermittance (sometimes works, sometimes don't work)
8/4/2008 3:12:02 AM • Symphonic SC319C... • Answered on Aug 04, 2008
Tv vcr combo
The best way I can think of is to REMOVE the rubber band that loads the tape into the transport unit.Be KILLFULL (careful) the band is right next to the B+ (power supply) or the A\C 120volt
( and if u can find the replacement rubber bands, buy 2 kits)
8/4/2008 3:02:50 AM • Symphonic SC319C... • Answered on Aug 04, 2008
2answers
Power problem
Problem in tape transport mechanism, most likely...accordianman
8/4/2008 1:58:51 AM • Symphonic SC319C... • Answered on Aug 04, 2008
Tape stuck in vcr
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
8/1/2008 4:25:45 PM • Symphonic SC319C... • Answered on Aug 01, 2008
TV Problem
i have this problem too i dont know how to fix it either
7/25/2008 12:51:58 AM • Symphonic SC319C... • Answered on Jul 25, 2008
DVD operation
scroll down on the channel button from channel 2. the different aux inputs should be there.there may also be a video/line in/source button on the front of the tv.if there isn't, you can buy a cheap universal remote for under $10 [even in some dollar stores for $1]
wg
2/16/2008 5:16:47 AM • Symphonic SC319C... • Answered on Feb 16, 2008
Symphonic SC319C 19 in. TV/VCR Combo Logo
24 questions posted
Top Symphonic Televison & Video Experts
Jaime Hernandez
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Symphonic Televison & Video
Most Popular Question
symphonic sc3819 stuck vcr tape
  • Televison & Video
