20 Most Recent Symphonic SC3813 13 in. TV/VCR Combo Questions & Answers
You should be able to access the A/V input by cycling through all available channels (using the Channel Up/Down buttons). You may need the A/V device to be powered on. However, if you programmed the Channel list to skip Aux, you may need to add that back into the list. You need the Menu function on the remote. Use the Up/Down arrows to navigate to Channel Set Up. Then press the F.Fwd (right arrow) to enter the sub-menu. Then select the Add/Delete Channel option. Another way to access the A/V input is accessed by pressing the Game button on the original remote. (This also adjusts the screen lighting.) The game button is the middle button on the last row of buttons on the remote. If you do not have the original remote, you need one that matches that function. Here is one that is guaranteed to work: http://remotes.com/store/symphonic/sc3813.html . This one may also work: http://www.emtcompany.com/symphonic-sc3813-remote/rc64.html . The Symphonic SC3813 was manufactured by Funai. The manual is available from Funai service support: http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/ . The direct link to the manual is http://www.funaiservice.com/manuals/SYMPHONIC/SC3813/SC3813.pdf . I hope this helps. Cindy Wells
Symphonic SC3813... • Answered on Mar 01, 2015
go to a shop and buy a cheep remote uneversal and this shuode solve it
Symphonic SC3813... • Answered on May 22, 2014
Check these codes:0053 0189 0227 0456 0024 Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Symphonic SC3813... • Answered on May 05, 2012
Not really. This is an internal CRT problem, essentially part of the rods are not firing.it would be more expensive to get a replacement piece because you are essentially buying the main component of the Television to reinsert. Sorry.
Symphonic SC3813... • Answered on Mar 03, 2011
Hello
Three digit universal reomote code for Syphonic are:-
520 904 906 033/ 053/ 189
Four digit universal remote code for Symphonic are:-
Direct Code Entry
NB: Switch OFF and ON your TV with its front panel power switch [NOT BY THE REMOTE CONTROL HANDSET]; each time before trying and other code.
OK.
Symphonic SC3813... • Answered on Dec 24, 2010
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
Symphonic SC3813... • Answered on Nov 13, 2010
Externally you cannot disconnect the VCR from TV.If you need to disconnect the VCR yo u have to remove the outside cover and then only can disconnect it.
Thanx
Symphonic SC3813... • Answered on Oct 30, 2010
Left up the VCR tape gate,see,if the tape still in there?Yes,unplug,10 mins.replug the Tv and push the tape forward botton.Let the tape go forward about 5 sec. eject the tape take out.Grandson probally rewind the same seen to many times,causing power power shotdown mode.
Symphonic SC3813... • Answered on Aug 09, 2010
Try 155 or 227 or 233 or 198 or 456. I hope that was helpful to you..........Have a good weekend and Thank you for using Fixya.com :)
Symphonic SC3813... • Answered on Jun 06, 2009
The vcr sistem is out of time and the microprocessor don´t detect the tape is out,you need to change the motor belt charge,good luck
Symphonic SC3813... • Answered on Mar 16, 2009
Symphonic Codes 033-038-189
Symphonic SC3813... • Answered on Feb 28, 2009
Go to www.remotes.com if they dont have it no one will!
Symphonic SC3813... • Answered on Jan 23, 2009
Symphonic SC3813 13 in. TV/VCR Combo Logo
37 questions posted
Top Symphonic Televison & Video Experts
Steven Wander
Steven Wander
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Symphonic Televison & Video
Most Popular Question
tv keeps turning off after 30 seconds
  • Televison & Video
