20 Most Recent Fisher 9925 Shelf System Questions & Answers
there aught to be if its a cd player a bsm button if there is then hit and hold it. if ur looking at an older radio then get the channel that u want and hold the number that u want that station to b at. but i need more specs on the radio befor i can make any further assumptions on it
Fisher 9925... • Answered on Feb 04, 2016
SOUNDS AS IF THERE IS A CD STUCK INSIDE ,CHECK IT
Fisher 9925... • Answered on May 30, 2014
TAKE COVER OFF THERE IS A MEMORY RESET BUTTON ON THE LEFT SIDE ON LOWER BOARD
Fisher 9925... • Answered on Apr 19, 2014
Check firstly, if your radio is Fisher Tad-9415 you are in ****! The only chance which you have it is to make it repaired by the company. The price of repairing: $750 us address I do not know it. Sorry. But, keep really because the casset reader and the radio FM always works. I would pay $1000 us to renovate this radio if I was you! I hope that you is not too much over! Three million times sorry.
Fisher 9925... • Answered on Jan 27, 2014
If for some reason you would opt for user performed action, then pls try:
1. reset, unplug from the mains for at least an hour and try again;
2. check if there is a slide switch of some sort at the rear of the unit;
3. check if there may be a pinhole somewhere along the bottom of the loading tray where a blunted point safety pin maybe inserted;
4. open the top cover and manually eject the tray;
5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly;
6. if the unit has been in use for some time, it may simply need cleaning and re-application of lubricant in the mechanical assembly.
The slider mechanism, depending on the age of the unit and , consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Fisher 9925... • Answered on Aug 28, 2011
That may be a clue.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Fisher 9925... • Answered on Jul 06, 2011
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
Fisher 9925... • Answered on Jun 30, 2011
I have a fisher tad 9925 and no sound. I hooked up multiple speakers from another system with this unit and blew my output board. Need help on where I can purchase a replacement board?
Fisher 9925... • Answered on Jan 11, 2011
hope it is not too late but have had the same problem, just got around to open up the case and found the problem and was able to fix mine and now it plays fine. My problem was with the cd turn table it was not be feeding the cd into the player causing the m-error..
Fisher 9925... • Answered on Dec 11, 2010
Its a little hard to diagnose over the computer.
I assume there is no sound from the amp EVER.
I assume you have tried other sources.
I assume the unit worked OK until the IC blew.
I assume you replaced the IC yourself?
Often, parts with the IC also fail. There maybe fuses that look just like little resistors along with the IC. They might be blown.
There are parts in the circuit to test if there are speaker problems called power resistors. These will frequently open circuit when the IC Blows - you won't be able to see anything visually.
If your stereo normally makes a 'Click' sound just before the sound comes on, and now there is no click, this indicates the repair of the IC is not complete yet - find the blown part.
Fisher 9925... • Answered on Mar 22, 2010
hi, one of the main problems of the cd players not playing is due to the fact the cd lense is dirty and needs cleaning, you can go out and buy a cd lense cleaning cd witch will clean the lense for you and hopefully solve your problem.
Dont buy the cheapest lense cleaner you see as they tend not to work so go for a mid range one.
If after doing this you still get the problem then you will find the cd laser unit needs replacing so depending on how much this would cost would depend on wether its worth getting repaired or not.
The problem with replacing the laser unit is that they have to be set up and this takes a while to do so paying someone to do this would be quite expensive so you would have to decide wether it was worth paying to get repaired or not.
Hopefully the cd lense cleaner will solve your problem and get it working again for you.
Let me know how you get on or if you need further assistance ok
Fisher 9925... • Answered on Dec 27, 2009
What is the error message? Thanks
Fisher 9925... • Answered on Dec 19, 2009
**** your radio
Fisher 9925... • Answered on Jun 07, 2009
did you check the fuses
Fisher 9925... • Answered on Dec 27, 2008
check tape 2 monitor button (must be off)
Fisher 9925... • Answered on May 19, 2008
Fisher 9925 Shelf System Logo
Popular Tags
38 questions posted
Top Fisher Audio Players & Recorders Experts
ray gallant
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher Audio Players & Recorders
Most Popular Question
m error message fisher studio 24 tad
  • Audio Players & Recorders
