20 Most Recent Symphonic SC309C 9 in. TV/VCR Combo Questions & Answers
you need a freeview box to make it go
Symphonic SC309C... | Answered on May 22, 2014
hi you need a freeview box to make it go
you need a freeview boxs
I was told by the folks at HCT that the TV uses remote control code 1226 but you can also use NEC or LG brand codes as well. Hope this helps. BTW, their number is 1-866-500-3020.
Symphonic SC309C... | Answered on Aug 13, 2011
Hello
Three digit universal remote code for Symphonic Tv are:
033/ 053/ 189
Four digit universal remote codes for Syphonic TV are:-
0053 0189 0227 0456 0024
Four digit universal remote code for Symponic tv/vcr combo is
0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
Ok
Symphonic SC309C... | Answered on Jan 15, 2011
Hello
Three digit universal remote code for Syphonic Tv are:-
: 033/ 053/ 189
Four digit universal remote code for Symphonic TV/VCR combo is:-
0227
Direct Code Entry
OK.
Wish You Happy peacefull 2011.
Symphonic SC309C... | Answered on Dec 30, 2010
1)in side ur tv kit    there  sould be  loose connection  at circuit tracks     otherwise    check  EHT SECTION    means   check  ABL signal  from  EHT TO CROMA IC .
2)if ur tv is  stays on  for 5 minutes  only with sound and not with video    then    replace   vertical IC  with the same number
this will solve ur problem
thanks
Symphonic SC309C... | Answered on Jan 01, 2009
When the same thing happened to me, I got mine to work using the codes from a Sylvania. The to TVs look the same, and seem to use the same firmware so I tried, and got lucky. Hope this helps.
Will9571
Symphonic SC309C... | Answered on Dec 06, 2008
its simple     ,, first   go to  tunning menu   and select AUTO SEARCH  ..  it will take care
thanks
Symphonic SC309C... | Answered on Oct 26, 2008
is there sound at  AV OUT  pins  check  with any  amplifier ,  if sound is coming  then  there should be  AUDIO AMPLIFIER IC gone . and  replace it  with same number....
if sound is not coming   then  inside TV kit there should be CHROMA IC gone   and replace it with same number,
thanks
Connect the converter box to TV, (usually rca connectors) connect an antenna to the box, turn it on and search for available channels. In most areas you should receive 10-20 channels.
Symphonic... | Answered on Sep 24, 2019
Symphonic SC309C 9 in. TV/VCR Combo Logo
Popular Tags
15 questions posted
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Symphonic Televison & Video
Most Popular Question
no sound
  • Televison & Video
