20 Most Recent Grundig Mini 300 AM/FM/SW Radio Questions & Answers
I have a Grundig Mini 300 handheld radio it rolled off my cloths and into the toilet, water got inside it,the digital display deosn`t work and shows up blank only the AM and FM still work.
It would need to be opened up to remove any salts or other things in the water. If the toilet water contained any flush additives they could have attacked the internal parts. In which case I think it would become very costly to repair. If it is just a case of stuff causing a short circuit, then a clean and dry should solve it.
11/10/2017 1:09:18 PM • Grundig Mini 300... • Answered on Nov 10, 2017
I dropped this radio into a toilet water from it got inside and damaged it can that be repaired
Take the battery out and stick it into a bin (or bag) of uncooked rice for 24 to 48 hours; this should draw out any moisture in the unit. If that doesn't fix it consider looking for a new one.
12/12/2015 5:37:24 PM • Grundig Mini 300... • Answered on Dec 12, 2015
2answers
How do i shut off the alarm mechanism on the mini
Here's a link to the eton site where you can download and print the manual for your radio. Instructions for the alarm function are on page 7:
http://www.etoncorp.com/upload/contents/307/Mini300_Manual_0107.pdf
Bill B.
San Antonio
6/26/2013 10:28:35 PM • Grundig Mini 300... • Answered on Jun 26, 2013
0answers
I have a Grundig Mini 300 World Band Receiver and the power button has stopped working so I cannot turn the radio on.
Spray some WD-40 on the on/off button and press and release the button multiple times. This will clean the gunk built up on the micro-switch and make a better connection.
5/18/2012 6:05:04 PM • Grundig Mini 300... • Answered on May 18, 2012
Need to find a battery cover for my Mini 300.
e-bay.com
7/17/2010 1:19:13 AM • Grundig Mini 300... • Answered on Jul 17, 2010
Broken antenna on grundig mini 300 radio
Replacement is possible, the back of the radio needs to come off and there is a screw at the bottom of the antenna. Remove this and the old one will slide out and simple to install new one. Call Eton for replacement, can be foung with a google search....
2/14/2010 7:02:51 AM • Grundig Mini 300... • Answered on Feb 14, 2010
Replacement battery for grundig satellite 3400 ? Where is it possible to buy?
I think this unit uses 'UM-1' batteries. They are also known as 'D Cell', 'R20' or 'LR20' batteries. Most good electrical, hardware and some of the larger 'supermarket' stores will have these batteries available. A good quality brand like Duracell or Varta should do the job. There is also two separate smaller 'button' batteries in the unit used to power the clock.
1/28/2024 3:47:04 PM • Grundig Audio... • Answered on Jan 28, 2024
Grundig G8 Traveler II Digital AM-LW-FM-SW World Time Radio. Why does my Grundig 8 traveler beep intermittently when it is turned off please?
Question edited for clarity. This is the only mention With the radio turned on or off, press the ALARM button with quick, short presses, over and over, noticing that a speaker or a bell appears under the box labeled 'Timer' in the upper left corner of the display. Leave the speaker there if you want the speaker alarm to turn the radio on; leave the bell if you want to wake up to a beeper. Leave it blank, with no speaker or bell if you do not want the alarm. Sometimes a beep when off is telling you that it is one standby or it is telling you the battery is becoming depleted. https://www.manualslib.com/manual/624477/Grundig-Traveler-Ii-Digital-G8.html#manual There is a beep on button press https://www.google.com/search?q=Grundig+8+traveller+II+digital+intermittent+beep ..
5/3/2023 5:00:53 PM • Grundig Audio... • Answered on May 03, 2023
Grundig Radio - Smart ForTwo
Hi Carlie, I apologize, however I am not familiar with the code requirement for Grundig Radio. I recommend that you contact the dealership directly and they should be able to help you.
2/26/2023 9:22:29 AM • Grundig Audio... • Answered on Feb 26, 2023
Grundig Eton mini radio turns off after a few seconds. It has nothing to do with the sleep timer and batteries are fresh.
Question moved from Mini (the car). Take it apart and look at the main board for dry joints on components. It is a known issue https://www.google.com/search?q=Grundig+Eton+mini+radio+turns+off+after+a+few+seconds ..
10/5/2022 11:40:05 PM • Grundig Audio... • Answered on Oct 05, 2022
Sticky outside material on the Grundig G8, any solution?
Rubbing 70-90% alcohol applied on a piece of cloth then spread on the radio will eliminate the sticky substance. May need several application and vigorous rubbing. After the process, my Grundig G8 Traveller II looks better than the original rubbery texture. Cleaner too.
5/26/2022 5:17:22 AM • Grundig Audio... • Answered on May 26, 2022
Grundig Satellit 800 - On all the AM bands I get a rat tat tat motor boating noise and no signal - no problem on FM or airband.
Try moving it to another location to test the antenna strength. It sounds like it is picking up interference. https://www.google.com/search?q=grundig+satellit+800+am+antenna ..
2/1/2022 4:13:37 PM • Grundig Audio... • Answered on Feb 01, 2022
Grundig Mini 300 AM/FM/SW Radio Logo
Popular Tags
20 questions posted
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Grundig Audio Players & Recorders
Most Popular Question
grundig mini 300 world band receiver
  • Audio Players & Recorders
