20 Most Recent
Acesonic KOD-1900HD Touch Screen Karaoke Music Jukebox Questions & Answers
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
I have a Fisher 5
The E display indicates disc loading error.Due to inactivity the carousel loading trays rubber belt would have either become stiff or loose ( depending on which part of the world you live in ).So your loading action is not being completed due to your loose loading belt condition.
There are sensors ( small leaf switches ) which tell the micro controller if the tray has gone in completely and lifted the CD off the carousel tray, only after that the CD starts spinning for play operation. If this sequence does not complete the tray opens and closes by itself in some makes and model during power On
If you are up to it you can open the top cover and see the loading tray and beneath it is the loading belt.Your challenge is getting a replacement today of an old model.
No sound sanyo preamp a8
Is this a new rig or did it just stop working?
If you would elaborate a bit on what you're doing and how it's connected we might be able to solve your problem with high level information.
A list of equipment, including the amplifier you're using, would help.
In general...
If there is a Pre Amp Out stero pair that would go the Amplifier's Pre or Main IN pair.
If there's is a Tape Monitor control, turn it off.
Phono can go ONLY to phono.
Other stereo devices can go to just about anything avalable such as Tuner, Aux, CD, DVD.
Philips HTS8100/59 very low audio
Hi, It could be that you have the wrong omes 4 omes instead of 8. That means the amp has to put out more power to run those speakers. Check that you have the right omes. Good luck
