20 Most Recent Symphonic ST427FF TV Questions & Answers
Standard CRT TV
Symphonic... | Answered on Oct 23, 2013
To select its inputs, you must have a remote control.
Symphonic... | Answered on Oct 16, 2013
038,031,099,046 are the codes to check. If you wish to get more, check these links. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Symphonic... | Answered on Oct 04, 2013
These are the codes for Symphonic TV: 0053 0189 0227 0456 0024
Symphonic... | Answered on Oct 13, 2012
$13+14.95. Click here for more details.
Symphonic... | Answered on Sep 11, 2012
To connect and select the input to TV to AV, you must have its remote control, as there is no Menu button at the front panel of this TV, to get into its menu option, and to select AV function.
Symphonic... | Answered on Jul 05, 2012
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears or rolls ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Symphonic... | Answered on Dec 03, 2011
press menu button,select for parental setting
Symphonic... | Answered on Jul 18, 2011
If you have RCA connections (AV 1 or AV 2) will work. You may use the RF connection (Cable TV Connection). Be sure in this case you tune to channel 3 or sometimes channel four. Your TV will have an internal switch that provide an acceptance to either channel. If you use the RCA connections, you will have use the input button on your remote. Thanks for asking and show all hands of support!
Symphonic... | Answered on Jun 15, 2011
it could be sensor on tv
try holding remote in front of a video recorder and if you push button on remote and view through video recorder you should be able to see the light blinking coming out of remote - if you see the light coming out of remote and it is still not working then the tvs sensor went bad
besides trying to unplug tv for a few minutes there is no reset for this issue
Symphonic... | Answered on Mar 21, 2011
Bad Crt Tv better buy new one most of the times its bad soldering in the old tvs or blown caps in your case it can be Fbt transistor or alot other things the first step is to open it up and look :D
Symphonic... | Answered on Sep 22, 2010
Symphonic ST427FF TV Logo
Popular Tags
37 questions posted
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Symphonic Televison & Video
Most Popular Question
symphonic wf27f4 old tv restore
  • Televison & Video
