20 Most Recent Blomberg BRFB1450 Bottom Freezer Refrigerator Questions & Answers
Blomberg kmn4551i fridge not cold enough
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage. Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly. Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air. But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer. Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator. May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. THE COMPRESSOR: If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed. To check ur compressor with multi meter: Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing. You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground. Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms. Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810. The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required. 1-3 TEMPERATURE CONTROL As the food in the fridge gets colder, it gives off less heat, and the air inside the fridge will remain colder. A thermostat called aCOLD CONTROLwill cycle the cooling system on and off to keep the temperature inside your fridge within a certain range. You can adjust that range using one of the dials within your fridge. On most fridges, all the cold air for both the food compartment and the freezer compartment is produced in one evaporator. Since the freezer is so much colder than the food compartment, most of the cold air that is produced circulates to the freezer compartment. Only a small amount is needed in the food compartment to keep it down to the proper temperature. This amount is adjusted by a smallAIR DOORin the duct between the evaporator and the food compartment. The control for this air door is the other of the two dials within your fridge. If you hear your compressor "short-cycling" (starting and stopping at short intervals) try jumping across the two leads of the cold control thermostat ( in the fridge compartment) with an alligator jumper. You can also check both for live voltage current and ohms- If there is a greenthirdlead, ignore it for this test; it is the ground wire. If the fridge starts running constantly, the cold control is bad. Replace it. To test or change the cold control, first Pull the knob off it and remove any plastic cover plate or housing from it. You will see two wires leading to it. There will also be a thick, stiffCAPILLARY TUBEattached. The capillary tube is the liquid-filled temperature-sensing element of the cold control, and operates in the same manner as a thermometer The air damper, baffle or diffuser is the device that balances the air flow from the evaporator fan housing. This normally is a mechanically controlled baffle or flapper that controls the amount of cold air entering the fresh food compartment. If the baffle is damaged or the linkage to the control knob is damaged, then you may not have enough cold air entering the fresh food compartment resulting in higher than normal temperatures. This baffle or damper will be located where the cold air enters the fresh food compartment. cold temp control location-undefined-undefined-0.jpg control box fridge1-undefined-undefined-1.jpg damper assembly whirlpool-control-damper-12571701-ap4013860_01_l-undefined-undefined-2_1.jpg damper-undefined-undefined-3.jpg evaporator-fan-blade.1280x600-undefined-undefined-4.jpg door seals damaged door seals-undefined-undefined-5_0.jpg
7/24/2023 6:16:16 PM • Blomberg... • Answered on Jul 24, 2023
Blomberg FNT 9671 freezer warning symbol
Minus 20' Celsius is too cold. Change it to -18'C. Also check that the door gasket is in good condition and sealing well. Here is the manual if you need it. Troubleshooting is at the end is not particularly good. Page 9 suggests that the Warning icon is the triangle with exclamation mark (!), is that the one that is flashing? Other icons flashing is indicating Fast Freeze Mode. Make sure the condenser coils at the back are clear.
FNT 9671P - Blomberg
https://www.blomberguk.com > Download > filen... PDF Symbols and their descriptions. This instruction manual contains the following symbols: C Important information or useful usage tips. A Warning against ... 20 pages ..
11/22/2022 5:01:10 PM • Blomberg... • Answered on Nov 22, 2022
Blomberg refrigerator r600a suction pressure at -15 inhg - Normal?
I doubt you have the specialized equipment needs to do this successfully. I wrote this for vehicle AC, but just change the word 'AC' to 'Fridge'. The procedure is the same. You can't eyeball this stuff. Also, with the new compressor, did you add oil and a new dryer? https://www.fixya.com/cars/r29878326-recharging_vehicle_air_conditioner OR Fridge. ..
9/4/2022 11:19:29 PM • Blomberg... • Answered on Sep 04, 2022
How to fix Blomberg fridge not cooling properly
what did tech say was problem --closed loop doesnt mean anything ---get a second appenion
8/3/2022 5:40:51 PM • Blomberg... • Answered on Aug 03, 2022
2answers
Blomberg BEO9414X oven how to fix
1/15/2022 12:59:39 AM • Blomberg... • Answered on Jan 15, 2022
Model BRFB1822ss. Why do approximately two cups of water per month accumulate in freezer (bottom)?
If unit is frost-free, it is residual defrost water.
1/8/2021 10:28:47 PM • Blomberg... • Answered on Jan 08, 2021
My Blomberg freezer seems to be running almost continuously
Can be 2 things. If its over freezing, its likely the thermostat has jammed closed and continually causing the compressor to keep running. This will make the freezer get too cold and over freeze. If its not icing up and not getting cold, I would say its lost its gas charge. The compressor is continually running, trying to get down to temperature.
9/23/2019 2:03:57 AM • Blomberg... • Answered on Sep 23, 2019
How do i fix the error E9 for Blomberg refrigerator
2/25/2019 3:31:27 AM • Blomberg... • Answered on Feb 25, 2019
How do I fix error code 9
Codes should be in the manual. If you lost yours https://www.blombergappliances.com/user-manuals
2/25/2019 3:28:00 AM • Blomberg... • Answered on Feb 25, 2019
Blomberg BRFB1450 Bottom Freezer Refrigerator Logo
4 questions posted
Top Blomberg Refrigerators Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Blomberg Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Blomberg Refrigerators
Most Popular Question
bought fridge model kqd1440x suddenly
  • Refrigerators
