20 Most Recent
TallyGenicom 9022 Laser Printer Questions & Answers
I need the procedure to
If the printer already has an IP address and you know what it is by printing a config page, the simplest thing to do is connect a pc directly to the printer using a cross over network cable.
Ensure the IP address in the PC is in the same range as the printer ie only the fourth octet is different.
Ensure you can PING the printer
Enter the current IP address of the 9022 in a web browser and it should take you to the printers internal web page whic will allow you to change network settings.
An alternative option is to use the ARP command at the DOS prompt, for this you will need the MAC for the network card on the printer, this will be on the printed network config page and on a lable on the network card.
For help on the ARP command type;
ARP /?
At the DOS command propt on a PC.
A third option is to use a software utility called SYNCTHRU supplied on the installation CD that was with the network card when new.
How do i find the
First, are you sure you have network capability. This is an option. Since there is no control panel display on this printer, you'll have to use the configuration software provided by Tally Genicom.
