20 Most Recent Pier 1 Imports Brown Pierced Metal Floor Hurricane - Small Questions & Answers
These are specially made with to suit the particular requirement and there is no way but to get this replacement from the manufacturer. the other way out is to use the two remaining ones on either sides for a brighter light and use 10" pipes of PVC or transparent tubings to give a special shade. Check this out with the availability at a plumbing store. You can cut portions on the opaque shade and use acrylic pieces to be stuck within to give an art look.
Pier 1 Imports... | Answered on Jul 12, 2015
Any janitorial supply in your town, or ebay. Your Home Depot or Lowe's may have them as well as Amazon.
Floor Polishers... | Answered on Jun 28, 2019
The rectifier is in the top end of the motor. Take the cover off and then the top end plate of the motor. With the bolts removed, you will have to tap and rock the plate to evenly remove it. Carefully look at the marks on the old and new part to be shur you do not make a mistake in the wiring. A drawing and photo might be nice too.
What exactly is the question here?
Is this a corded electric Scrubber or a battery one?
Floor Polishers... | Answered on Dec 27, 2016
Timber Floor Sanding and Polishing Melbourne
Use this guy, i have used them before & they are very affordable & professionals for sure
Floor Polishers... | Answered on Mar 29, 2016
motor bearing worn or shaft bent.
Floor Polishers... | Answered on Aug 10, 2014
Wax remover. Rewax spot after removing wax.
www.electroluxappliances.com/Owner-Support
www.cleanfreak.com/Qstore/p001525.htm
the brush is either dirty or you burned the wax.
Plug it in,pull trigger
Floor Polishers... | Answered on Jul 31, 2014
Pier 1 Imports Brown Pierced Metal Floor Hurricane - Small Logo
1 questions posted
Top Pier 1 Imports Floor Polishers & Buffers Experts
Robert Wooley
Robert Wooley
Brandon Cherry
Brandon Cherry
Level 1 Expert
Ned Halaweh
Ned Halaweh
Are you a Pier 1 Imports Floor Polisher and Buffer Expert? Answer questions, earn points and help others
View Most Popular
  • Pier 1 Imports Floor Polishers & Buffers
Most Popular Question
bought 3 metal floor hurricane candle
  • Floor Polishers & Buffers
