20 Most Recent Chamberlain 3/4-HP MyQ Battery Backup Belt Garage Door Opener LW5000EV Questions & Answers
Doorbell switch won't open garage door
If working with remote and/or keypad check wire from opener to doorbell/push button/wall controller. Rami orangedoors.com
5/14/2014 6:38:06 PM • Chamberlain... • Answered on May 14, 2014
2answers
Coromaster B2B Garage Door Opener. It only opens the door halfway?
Question edited for clarity. This is an older model. Either the weight of the door is borderline for the motor and that is why it is beeping. The counterbalance system need adjusting. Or the carbon brushes on the motor need replacing. You can also try lubricating every single item that moves and the tracks to reduce rolling and sliding resistance. Use proper garage door spray or light machine oil not WD40 which goes waxy / gummy after a couple of months. https://www.google.com/search?q=Coromaster+B2B+garage+door+opener and https://www.google.com/search?q=Coromaster+B2B+garage+door+opener+opens+halfway and Beeps https://www.google.com/search?q=Coromaster+B2B+garage+door+opener+motor+beeps ..
4/19/2024 7:51:17 PM • Building... • Answered on Apr 19, 2024
Genie Garage Door RC Receiver. Where is the learn button for Genie receiver model OHDH390 please?
Question edited for clarity. It doesn't look like that model number is correct 390 is the frequency of the signal. It is mentioned here are part of the regulatory approval process as a much longer number https://fccid.io/B8QOHDH390 The Learn Button is next to the bulb https://www.geniedoor.com/support/programming-instructions/garage-door-opener-remote-programming/ More here https://www.geniedoor.com/support/programming-instructions/ https://www.google.com/search?q=genie+receiver+ohdh390+learning+manual ..
4/8/2024 12:29:27 AM • Building... • Answered on Apr 08, 2024
I have a Novoferm 553 garage door system. The remotes have stopped working.
Sounds to me like a cold solder joint on one of the boards
3/31/2024 1:13:56 PM • Building... • Answered on Mar 31, 2024
How many sand and stone and cement do you need or cubic meter of concrete
A concrete mixture ratio of 1 part cement, 3 parts sand, and 3 parts aggregate will produce a concrete mix of approximately 3000 psi. (20685 kpa)
3/25/2024 5:28:07 PM • Building... • Answered on Mar 25, 2024
My DTS 600 garage door open and close very slowly
Unlikely your garage door is battery operated. The remote and wall unit yes. The remote just tells the mains operated motor to get turning. The issue will either be that everything that moves needs lubricating, motor spindle, pulleys, chain, tracks and pivots, or the carbon brushes in the motor need replacing. https://www.google.com/search?q=DTS+600+garage+door and how to fix https://www.google.com/search?q=DTS+600+garage+door+opens+slowly ..
3/13/2024 5:23:31 PM • Building... • Answered on Mar 13, 2024
How do I fix an exterior mobile home door that's not lining up properly?
Question edited for clarity. Question moved from Cars and Trucks category. Look at the corners of the doors that hold the aluminium frame together and if it is a modular door, tighten them up. If it is a solid door, adjustment can be made by shimming behind the bottom hinge with a piece of cardboard. This will move the bottom out and up. ..
2/18/2024 9:28:00 PM • Building... • Answered on Feb 18, 2024
2answers
I have roller door opener merlin430R. I can not
Look at this video, it should answer your question. The learn button in under the green button. Remove the green button. http://www.youtube.com/watch?v=7CqMy2UfG9k
2/15/2024 10:23:37 AM • Building... • Answered on Feb 15, 2024
Garage door opens too far and ends up 2 or 3 inches into the motor housing. How do I fix this issue.
Check the opening limit dial on the garage door opener unit. You can locate the dial that controls the opening limit on the opener unit and use a flat head screwdriver to turn the dial counter clockwise until the door stops about an inch and a half away from the stop bolt. Then, test the door and make sure it does not slam into the bolt. A video tutorial on how to adjust the opening limit of a Craftsman garage door opener is available on YouTube. If the above step does not work, check the limit switches on the garage door opener. Most garage door openers have limit switches that control how far the door opens and closes. Improperly adjusting these switches can cause the door to stop halfway. Consult your garage door opener's manual to learn how to adjust the limit switches. Make small adjustments until the door closes fully. Craftsman garage door opening too far and hitting stop bolt easy adjustment (youtube.com)
1/15/2024 10:16:07 PM • Building... • Answered on Jan 15, 2024
tip
NHK Tiling
At NHK Tiling, our tiling process has been perfected over the years to give you the best results possible. Our Expert Tiling Service is perfected for a range of applications, styles and functions. Whether you require contrasting grout to make a statement with your kitchen splashback, or you need a Professional Tiler for tiling your swimming pool, NHK Tiling is the ideal choice for you. https://www.nhktiling.com.au/
on Dec 06, 2023 • Building Materials
tip
Granite Warehouse
GRANITE WAREHOUSE is a privately owned Western Australia business specializing in the wholesale of Granite, Marble, Limestone, Sandstone and our line of engineered stone, Stellastone, in slab form suited for the fabrication of kitchen and vanity benchtops as well as other building uses. Granite Warehouse was founded in 1995 by Tindaro (Tony) Tomeo to fill a need in the local Western Australian market for quality natural stone. With more than 40 years experience in the building industry, specializing in cabinet making and kitchen fit-out, Tony, with wife Susan and son Mark, built Granite Warehouse into the well-respected business it is today. With Tony and Susan's retirement, and in the best family tradition, Granite Warehouse has been taken over by Mark Tomeo who continues to develop the business to fill best the needs of those wanting to enjoy the beauty of stone installed to their home or business. https://granitewarehouse.com.au/
tip
Kwikcut & Coring
Having operated for the past 11 years in Western Australia, we offer a wide range of quality construction and demolition related services at competitive rates. Operating with the latest equipment endorsed by Traxx Construction Products, our fully qualified and professional operators work to the highest safety standards with excellent service guaranteed to meet your every need. Our team of qualified professionals, well trained and certified personnel who can operate the latest high-tech machines implement every project with care and 100% attention to details. To make sure that we are always ready for action and up-to-date with technologies, fast-paced world, procedures & regulations, we keep proving educational and on the job training to every professional we have in our team. Kwikcut believes in the importance of collaborating ideas and exploring innovative concepts not just for the benefit of our company but above all for the benefit of all our clients. We are customer focused, and we all share the same vision which is to put attention to details and produce nothing but excellent results for every project laid before us. We are highly professionals, trained, skilled, and licensed. For us, no job is too small or too big that we cannot undertake. https://www.kwikcut.net.au/
on Dec 05, 2023 • Building Materials
tip
Evolution Epoxy Flooring
Evolution Epoxy Flooring is Sydney's epoxy flooring expert, specialising in decorative garage coatings & concrete grinding. We only use advanced techniques, custom design, and Australian-made products to ensure the best concrete finish that suits the individual client's needs. https://evolutionepoxy.com.au/
/uploads/images/dp-undefined-undefined-0.png
on Dec 03, 2023 • Building Materials
My Liftmaster Wall Control (Large White Button) green light is not illuminated and I cannot open/close my garage. Remotes work fine. Which part needs replacement?
They have self diagnostic features and are 'smart'. Make sure there is nothing near the two door sensors and make sure they are clean. No model number given, but generic help in the link. https://www.google.com/search?q=Liftmaster+Wall+Control+Large+White+Button+green+light+is+not+illuminated ..
10/31/2023 11:39:56 PM • Building... • Answered on Oct 31, 2023
2answers
Why Kitchen Countertops are on Top and in Trend?
earth-friendly products is good for us this means it's products that was made from things that could be reuse and made better for our health and environment will be better
10/30/2023 11:40:38 AM • Building... • Answered on Oct 30, 2023
How do i make my wooden windows open and close easily without straining my back These are windows in the home
Question moved from Cars and Trucks Are they vertical lifting sash windows? They have hidden counter-weights in the frame. Very often the string will break so you are lifting the full weight of the frame and the glass. ..
10/17/2023 12:09:37 AM • Building... • Answered on Oct 17, 2023
tip
Reef View Construction ltd
Are you worried about the deteriorating exterior of your home in Auckland? Look no further than Reef View Construction LTD for top-quality house recladding in Auckland. Our skilled team will help transform your home's appearance while also improving insulation and weather resistance. Trust us to provide you with a long-lasting solution to your recladding needs. Contact us today. Visit : https://www.reefviewconstruction.co.nz/ Phone: 0800121874 Address: 8 Reef Place, Mangere, Auckland, 2022
/uploads/images/b1-undefined-undefined-0.jpg
on Oct 03, 2023 • Building Materials
Chamberlain 3/4-HP MyQ Battery Backup Belt Garage Door Opener LW5000EV Logo
3 questions posted
Top Chamberlain Building Materials Experts
Jose Ramirez
ADMIN Andrew
ADMIN Andrew
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • Chamberlain Building Materials
Most Popular Question
garage door automatically reverses cross
