20 Most Recent Koss CDR200 2-Disc CD Recorder Questions & Answers
0answers
Manual
Be the first to answer 5/31/2013 3:16:26 AM • Koss CDR200... • Posted on May 31, 2013Be the first to answer
When i put a blank disc in side b it says
i found the only cd-r that works is 40x which seems hard to find at local stores..there are 16x. 20x, 48x, 52x etc.....
12/19/2012 8:04:48 PM • Koss CDR200... • Answered on Dec 19, 2012
I am unable to engage
There are several types of blank discs (CD-R, CD-RW). This unit only handles the CD-R discs. Unfortunately, this particular unit is even fussy about the CD-R discs it does accept. Even more unfortunately, there is no way to determine which will be accepted and which will not work. At this point, I can only advise you to try CD-R discs from a different manufacturer. Read the first review on amazon.com. Same issue I have had. Sorry and good luck.
7/24/2011 9:55:11 PM • Koss CDR200... • Answered on Jul 24, 2011
I have this 2-Disc CD Recorder but I don't
No problem,You need to connect "CD" to" Receiver" in a regular way just to play ..
(output of CD-TO- input of Receiver) ..use either "RCA analog (red/white ) " or "optic " cable.(any standard optical cable )...optic is the best way to connect it..Remember your CD's "OUT" goes into" IN "
pls also remember,wherever you connect your CD on your Receiver,you should switch the source selector accordingly to correspond to the connection on the back...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
6/30/2011 8:40:03 PM • Koss CDR200... • Answered on Jun 30, 2011
What type of CD must
A recordable one that says audio or music right on it.
5/27/2011 11:00:51 AM • Koss CDR200... • Answered on May 27, 2011
KOSS CDR 200 RECORDING
Yes, but you, like I could use an owners manual for this thing, as it isn't as easy to operate as the Philips Audio CD recorders. Owner's manual anyone?
You can just press input select for analog, press record, wait then press 'play' to start recording.
7/26/2010 5:31:19 PM • Koss CDR200... • Answered on Jul 26, 2010
0answers
Can I record from a cassette player to the koss
should be able to go directly from tape out of cass deck to input of your koss, as long it has line level inputs (which it should). from there its play on the tape and record on the cd rcrdr. seems the simplest solution
2/3/2010 4:49:33 AM • Koss CDR200... • Answered on Feb 03, 2010
Side b will not read any disk
Laser could be dirty or could have burned out
11/13/2009 1:46:07 AM • Koss CDR200... • Answered on Nov 13, 2009
Cantrecordfromonecdtoanother
ask manualfox.com
10/28/2009 8:41:23 PM • Koss CDR200... • Answered on Oct 28, 2009
2answers
Koss cdr200 dual burner
I had an issue similar to this - I found if I didn't try to record from the internal player it worked ok. Does it say 'recover' when you try to record anytime? If you open the unit,you might see some capacitors on the power supply on the left hand side have leakedand the power is cutting in and out. 'Recover' usually comes up when a recording is interupted if you switch the unit off during recording.
7/7/2009 1:15:56 AM • Koss CDR200... • Answered on Jul 07, 2009
Every blank cd I put
You must use a digital audio cd only!
7/7/2009 12:49:36 AM • Koss CDR200... • Answered on Jul 07, 2009
4answers
KOSS CDR200
can I record from an outside source, like a casset player to cd, on the cdr200, if so, how, thankyou
5/17/2009 6:21:06 PM • Koss CDR200... • Answered on May 17, 2009
0answers
Koss CDR200 2-Disc CD Recorder Logo
31 questions posted
Popular Products
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Marvin
Marvin
 Grubhead
Grubhead
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Koss Audio Players & Recorders
Most Popular Question
2 disc cd recorder but don 39 t
  • Audio Players & Recorders
