20 Most Recent
Acer Aspire Z5600 PC Desktop Questions & Answers
When starting up wow on
Hi there mate,Try right clicking the WoW shortcut and going to properties-> then compatibility and change the compatibility mode and try each one and also try running wow as admin sometimes helps too... Please rate
Turning on internal webcam
go to device manager, look for imaging devices, expand it. can you see your camera? does it have an error?
Finding wi fi
Is your wifi turned on? If it is click network connections on the toolbar and look for your wifi
Aspire z5600 keeps turning off
You could have an overheating issue. most computers get hot after a small period of time and that heat must be dissipated. To do this, the computer uses fans and heat sinks. These need to be cleaned of dust and dirt or they will clog and fail to remove heat from the system, forcing it to power down.
My computer turns off when playing a game for a while
Your pc is likely getting hot. You could have dirt and dust on the video card or clogging the fans. When you are gaming the pc works extra hard, drawing and rendering images, so that produces heat. excessive heat must be dissipated by a cooling system, and over time, the cooling system must be serviced. You'd need to get some compressed air and clean the fans. but you may also need to re-apply your thermal grease and thermal pads. If you are not sure, take it to a shop.
The dvd player stopped working
Don't bother trying to fix. Just buy a new one. Quite easy to replace. Just make sure that the power is unplugged and you make good contact with chassis inside PC case before touching any of the circuit boards to prevent a static discharge.
Good luck
How to check weather computer is set to the correct voltage.
If it is present since not at Power Supplies have it, At the back of the computer, on the power supply, you should find a small switch. usually red color.
If you are in the US, you should have it on 110V.
If in europe, then you should have it 220V.
Touchscreen Problem
First, you want to back up your files. That way if you have to, then you reinstallxwithoutcloss.is it a hardware issue?
Touchscreen not working
you can save all your personal data and re-install the O.S. again, or try to go to the computer properties and check if the touch screen drivers are there , if not you need to install it.
Touchscreen not working.
Do you hear a beep when you touch the screen? If you do it is more than likely a software issue, or the cameras are misaligned..
First thing to try is Scroll Lock Calibration.. Press Scroll Lock on your keyboard 5 times quickly, your cursor should move to the top left of your screen, press and hold your finger on it until you hear a beep, remove your finger and itshould automatically move to the top right, repeat for each corner, when it is done the cursor will move to the middle of the screen, and the touch screen should be working
If the computer does not beep when you tocuh the cursor and the cursor does not move when you remove your finger it means your touch is not being recognized... it could be a software or hardware issue, here is one way to find out..
First do a power drain.. shut down the computer and unplug everything from it (including the power cord) and press and hold the power button for 30 seconds.. Now boot the computer into BIOS by tapping F10 on startup.. inside the BIOS touch the screen.. do you hear a beep? if so it is a software issue, if not more than likely it is a hardware issue
A few other things you can try... open the Touch Screen Configuration Tool inside the Control Panel, make suire the touch screen and sound are enabled, select the Troubleshooting tab, click Restore Defaults, try the Calibration function... beyond that you could try System Restore/System Recovery..
Good luck
