20 Most Recent Dell Vostro 1014 Notebook Questions & Answers
Mouse hanging whenever i start my laptop dell vostro 1014
It is time to replace the hard drive for the spot where the mouse drivers are is bad so that means it will not be long before the hard drive stops working so time to back everything up while you can and get a new hard drive
9/17/2018 1:38:38 AM • Dell Vostro 1014... • Answered on Sep 17, 2018
Hi Boss, My Laptop Dell Vostro 1014 Bios Password
Herer's an answer I found with a Google search: Remove CMOS battery. Removing the CMOS battery like the one shown in the picture causes the system to lose all CMOS settings; including the password. To do this, locate and remove the CMOS battery from the motherboard for at least five minutes, then replace the battery and turn the computer back on.
2/17/2018 11:14:49 PM • Dell Vostro 1014... • Answered on Feb 17, 2018
How dell vostro 1014 keyboard can turn on or off?
You can't. The keyboard is always on. The only thing you can do to not allowing the keyboard to work is disconnecting it. If you use a USB Keyboard it might help you.
11/2/2014 2:26:57 PM • Dell Vostro 1014... • Answered on Nov 02, 2014
Cmos password
reset by removing the battries on circuit board
5/25/2014 6:51:14 AM • Dell Vostro 1014... • Answered on May 25, 2014
Display no light
WHAT DISPLAY NO LIGHT PROVIDE DETAILS
5/25/2014 6:39:23 AM • Dell Vostro 1014... • Answered on May 25, 2014
Factory reset 1014
Hit F2 at boot and then Alt+F or Load Defaults menu option. Here is a link to the manual - page 64 ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_vostro_notebook/vostro-1014_Service%20Manual_en-us.pdf
4/8/2014 8:16:06 PM • Dell Vostro 1014... • Answered on Apr 08, 2014
2answers
Missing opareting system
When you saw "restart to load windows" are you restarting with a windows 7 DVD in the drive? If so you may have to press F12 as it boots in order to invoke the boot menu and choose DVD as the temporary boot option. Then follow the instructions for installing windows. If you did not receive a DVD with purchase the recovery partition was on the drive which may have been wiped with active kill - you could order or borrow a DVD or install Linux.
4/8/2014 7:38:21 PM • Dell Vostro 1014... • Answered on Apr 08, 2014
Missing operating system
Goto BIOS and do restore defaults then restart and see if that works.
3/31/2014 3:52:26 PM • Dell Vostro 1014... • Answered on Mar 31, 2014
2answers
Cannot log in using control-alt-delete on Dell Vostro 1014
It sounds like this, indeed, is an issue with one or more of your keys. Check for obstructions that may be preventing your logon combo keys from fully depressing. Also check the full board for keys that may be 'stuck', especially in and around the mouse pad area and space bar. I think it's possible to configure your bios to recognize external devices, such as a USB keyboard, during start-up, but not certain. Have you tried to access bios by using the function keys (f2, f8, etc...) while booting?
12/16/2013 8:55:31 PM • Dell Vostro 1014... • Answered on Dec 16, 2013
2answers
Shift and cntrl keys are not working .Please help
It might be that you have by mistake turned on the sticky keys on the system. Sticky Keys is an accessibility feature designed for people who have difficulty holding down two or more keys at a time. When a shortcut requires a key combination such as CTRL+P, StickyKeys will enable you to press one key at a time instead of pressing them simultaneouslyI would suggest you to check whether the sticky keys are turned on. Follow the steps mentioned below.a. Click on Start and click on Control panel.b. Click on 'Accessibility Options' and in keyboard tab make sure that there is no check mark near 'Use sticky keys'.c. If there is a check mark then remove it and then click on Apply.Also check to see if anything is stuck under keys - cleaning the keyboard using a vacuum cleaner (AT VERY LOW SUCTION) could help
10/24/2013 11:20:49 AM • Dell Vostro 1014... • Answered on Oct 24, 2013
0answers
Plugged in not charging and continuously battery
I had a Dell laptop that would not charge. I replaced the power pack and it worked for a while, but the problem came back. So I tried wiggling the connector at the computer when plugged in and it started to charge. Dell said that the connection on the mother board was loose or worn and needed a technician to fix. I taped the connector in place so that it charged. However, first use a volt/ohm meter to check that indeed the voltage output at the connector that goes into the computer. Look on the power pack for the output voltage and make sure it is delivering what it says it is supposed to be. Just be aware that the output voltage is DC not AC so set the meter to read DC Volts. Hope this helps.
9/13/2013 9:35:26 PM • Dell Vostro 1014... • Answered on Sep 13, 2013
How i fixed this problem
More information is required to solve this.
9/7/2013 2:52:39 PM • Dell Vostro 1014... • Answered on Sep 07, 2013
Reset bios password battery
remove your cmos(round,silver color, resembling the one in wrist watch) battery in your motherboard and put it back your password will reset
8/26/2013 4:37:28 PM • Dell Vostro 1014... • Answered on Aug 26, 2013
Touchpad unlock
Please hold down Fn+F6 key or hold down Fn+F3 key.
7/26/2013 1:44:59 PM • Dell Vostro 1014... • Answered on Jul 26, 2013
Base system device
Tareq,You can click the link below to download the correct drivers for your system. You must first install the chipset drivers before installing any other drivers so that the hardware will work properly. This system only shipped with one Audio Option.Dell Vostro 1014 Drivers Download Page.http://dell.to/14pFNE8Thank You,Dell-Jesse LDell Social Media and Communities
6/25/2013 6:41:36 PM • Dell Vostro 1014... • Answered on Jun 25, 2013
Bootmgr missing
You need to have a operating system's disc because you would need to load the bootmgr from it. Insert the disc and start your computer. Your computer will ask you to boot to the cd. Hit enter and run a start up repair so that the missing system file will be added.I hope this helps!David
6/22/2013 9:38:20 AM • Dell Vostro 1014... • Answered on Jun 22, 2013
Netbook blue screen
You need to reformat your computer again. It known as the blue screen of death.
6/20/2013 3:15:35 PM • Dell Vostro 1014... • Answered on Jun 20, 2013
Keyboard function key
i dont know
6/8/2013 8:40:39 AM • Dell Vostro 1014... • Answered on Jun 08, 2013
Dell Vostro 1014 Notebook Logo
51 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Vostro Dell
  • Vostro Dell
Most Popular Question
cannot log in using control alt delete
  • Computers & Internet
